Common(?) vRS 'hesitation'
That price is for exchange!
  • Replies 87
  • Views 14.4k
Found one on Ebay US for NZ$150 posted - compared to NZ$300 locally.
Also pulled fault codes:
Right then..
VAG-COM Version: Release 311.2-N
Control Module Part Number: 06A 906 032 HN
Component and/or Version: 1.8L R4/5VT G 0002
Software Coding: 11500
Work Shop Code: WSC 78393
Additional Info: TMBUR41U748747490 SKZ7Z0D2402187
1 Fault Found:
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
According to a quick web search this points to MAF or a boost leak. And I'm pretty sure it's not a boost leak!
Right then..
1 Fault Found:
P1128 - 35-00 - -
sounds like your on to it there rob
New MAF arrived yesterday so I fitted it and cleared the fault codes.
Started the car and all was smooth and lovely.
Started the car cold this morning and it was not right at all! Not as bad as it was, but hesitating, stuttering, generally playing up :(
Once the car had warmed up after about 15 minutes it was barely noticeable.
So, what to check next?
I'm notsure but is it possible that the ecu is re-learning that the maf is now working
I'll see how it goes over the next few days - at least all of the fault lights have gone!
Well it ran a lot more smoothly last night, but the check engine light is back.
Running okay but with hesitation at almost exactly 2000RPM.
I'll pull the fault codes again tonight and re-check all of the hoses.
Well I've found the source of my problems - the TIP had come off at the turbo end :doh:
I have the same problem, noticed after remap, switched back to standard found it was still there just not so noticeable. I think I have found a cure, replaced fuel pressure regulator with 4bar one last week and haven't noticed any hesitation since.:thumbup:
Yea my Rs suffers from this as well, more noticable when cold (first few minutes of driving really) but occassionally crops up when warm.
1) Car model
Octavia Vrs
2) Month/Year
September 2003
3) Does it suffer the hesitation problem?
Yes
4) Remapped or not?
No
5) If 'Yes', by whom?
N/A
6) Other engine mods?
None
7) Any 'cure' been tried (successful or otherwise)?
Nothing tried yet
8) Any other info?
None
My 2003 (03) VRS estate ha sthe same feature/fault normally happens a minute after starting from cold (when the fault happens I hear the climate control fans slow down to a stop also). Put my foot down and loose all power for a second, almost feels as if the car has stalled.
1) Car model
Octavia Vrs Estate
2) Month/Year
2003 (03)
Yes
4) Remapped or not?
No
N/A
None
None
8) Any other info?
Dealer had a look, they found nothing wrong with it.
Yeah I was getting the same problem at cold on my Mk1 at about 2k rpm. Although I just slung in a pipercross panel filter and this seems to have relieved the problem. I don't think that this may be directly linked as I had unplugged the N75 & MAF cleaned the contacts while I was fighting to get the airbox lid back on. So i think that it may be the case that something is just fitting better.
  • 3 months later...
Having problems too - has got noticeably worse since fitting a CAI (but was there before) - only does it in 1st and 2nd when cold - clears pretty much when warm.
So the recommendation is to clean the MAF and TB? - what do I need to use?
1) Car model
Octavia Vrs
2) Month/Year
2001 (Y)
Yes
4) Remapped or not?
No
N/A
Just CAI - but hesitated before then
None
8) Any other info?
No - have tried 95 and 97 RON Fuel - no different.
