(!) symbol on dashboard intermitent flashing
Hi there..
I have a P Reg. Felicia 1.6 GLXi with intermittent (!) symbol flashing on the dashboard. The car still drives OK and the light appears to be influenced by movement of the stearing column / throttle control. Could anyone offer any advice as to what the (!) indicator is a warning for and possible problems other than a dodgy connection:confused: ? Unfortunately I do not have access to a Felicia Owners Manual...
thanks to anyone who can help:thumbup:
Simon
Hi.
Sounds like the brake warning light.. probably caused by low brake fluid level..
Or a dodgy handbrake switch.
Moved to a better section.
Thanks...had the brakes pipe / shoes etc. replaced about 4 months ago...added dot 5.1 brake fluid reservoir and this has solved the problem... cheer for the feedback
Simon
