how to speed up my car?
Hi, i really like speed i have felicia 1.6 MPI any idea how to make it faster ? thnx
how much moeny you got to spend?????
if you've got about £2000 to spend i would go for throttle bodies.
should give you around 150-160bhp if it's set up properly
did you say two grand!!!!!!!!!
try an induction kit and a de-cat to start with.
and an ecotek fual system
yeah but he said he wants it to go faster!!!!:D
so what dose "doing the throttle bodys" entail?
I'm sure you could get a better engine for it for 2 grand ;) Assuming you're DIYing it :rofl:
Chris
the trouble with DIY ing it on a felicia is that you will have trouble fitting bigger engines because the engine mounts are unique to the the felicia.... may invlove some custom fabrication work too..:) but i can be done..... it just depends on how deep your pockets are!!!!:eek:
you would have something that look a little bit like this instead of your standard intake manifold. plus a few other bits and bobs.
with throttle bodies it would sound meatier than a grilled elephant too:thumbup:
Pedal on the right?? :confused:
:rofl: :rofl:
It will also helpa steep hill to go down as well :D
V8 in the back. :D Still can't get over that Skud in Czech. :thumbup:
