S3 dump valve
has anyone fitted a S3 oem dump valve,will it be a straight swap:confused:
isn't the dump valve on the s3 mounted in one of the intercoolers??
it looks the same
it probably is the same part then
As far as I know the stock DV is the same as they Octavia one.
It's a straight swap because it's exactly the same part. Only worth doing if your existing one has a split diaphragm.
EDIT: Beaten to it by Ross.
thanks guys yea mine is nakered
