How Can Install New Dual Horn
How Can Install A New Pair Of Horns
The Model Of The Horns Alpex Dual Horns
And Where I Have To Put The Relay That Comes With The Set
Hi - dunno if the setup is like a fabia - but if you're only replacing the horms, you can just take out the old and put in the new - the relay is used if you are wiring in a second set of horns or your old relay is burnt out. The original horns have a relay already in place.
BTW if you're from Dominica - I have a friend out there from the Shillingford-Ricketts family.
HTH
Bas
No I Am From Dominican Republic Thanks Men For The Tip
