Pikey mod done. but what can I expect?
This is the Audi TT vent mod. The part number is 8N0 821 172B and the price was
Dennis is that arch a straight swap or is it just the vent
You'll need to cut the gap out if that's what you mean?
The vent has been cut out of the TT wheel arch liner.
The side mounted intercooler is behind that wheel arch , and it works best with a good flow of cold air over it.
Allowing air through the liner helps this , so when the car is driven hard on hot days it will help prevent heat soak which can sap your power a bit.
It's only going to make a small difference but every little helps
i know what you mean cheers
