oil cap
anyone know where i can get a new oilcap from...
mine seems to have blown off - is that a bad sign??!
They only push in anyhow.
Skoda dealer would be a good bet.
If you have a 1.3 then check any scrap yard for a Felicia 1.3 or an old Favorit - they both use the same caps.
Hope that helps.
They are only £2 or so new (047103085 is the part number that comes to mind but don't quote me on that) - don't forget to order the seal as well. The 1.4 MPi 8 valve Fabias have the same cap on the underside of the engine cover, should you wish to run the engine without the cover.
Assuming that you have a 1.3.
last time i lost an oil cap, it was cuz the engine had just gone bang!!!!!
