Remote boot release
Hi
Not sure if this is a fault or feature; when I hold down the tail gate release button on the remote, the lock on the tail gate clicks and the tail gate 'half' releases, but not fully - I still have to press the boot button in order to fully release it and open the boot.
It's as though the boot has been gently closed and is 'ajar' - enough to hold the tail gate closed, but not hard enough to fully close it.
Sorry if that doesn't make a lot of sense!
Ade
It's a feature, you approach the car with bags of shopping and pop the boot open with the middle button,then all you have to do is lift the tailgate instead of fiddling around finding the button after you have unlocked the car.
Hi
Ade
After unlocking with the remote you have to squeeze the rubber pad under the recess to open the boot - it's an electrical thing common to many continental cars. After a second or so the boot will release. And when you slam the boot down again after using the boot release, it will re-lock after a second or so, with a cheery wink of the lights.
If not, you've got a fault and it's off to the dealer.
Not if you hit the boot release(middle) button on the fob, press and hold it and the boot thuds open onto its ajar position, you only need to grab the boot anywhere to pull it up, you don't need to touch the rubber button above the number plate.
You only have to press the rubber button on the boot if you have unlocked the whole car first.
Except I pointed it out as a fault and there is a TSB for it, but when that didn't work I was told it's a characteristic.
I can live with it I guess.
Mine does the same, opens to the first 'latch' only and then you still need to squeeze the rubber button to open it - fecking useless. Mine went in last week for adjustment. Chris the tech and I then went around every hatch on the forcourt trying them and they were all the same. I am waiting for them to get back to me with an answer from technical.
My Fabia did as I would expect and opens when you press the button - surely that's how it should be.
Having to press the fob and then the boot release sort of defeats the object of the whole thing.
I'm glad mine works properly as it's quite handy at times apart from when something shifts in the boot so it falls out when said middle button is pressed :mad:
Mine sometimes pops out (release), sometimes doesn't. Now I have the way to make it release every time: I press and hold middle button and after it lifts up a little I don't check if it opened but I repeat middle-button-hold one more time and it gets open for sure.
Just tried that and it works. Spot on - thanks :thumbup:
Hi
Thanks for all your replies.
Tried bosnjo's tip - the latch clicks several times as it tries to release the boot, but it still needs the black tailgate boot release button to be pressed before the boot releases from its 'first latch'.
Since I still have to use the black button on the tailgate, I may as well just unlock the car!
Sounds like a common problem but may as well mention it when first service due
Ade
Mine was adjusted but it still seems to not work right all the time. I think if you try to lift the boot straight away after the key fob press then theres more chance of it being open.
I phoned Technical yesterday and they assure me that if you press the button on the key fob you still need to press the rubber button on the boot lid too.
All seems a little pointless to me.
My car (ZZH) and a colleagues Octavia estate (ZYH) both pop the tailgate open without the need to press the rubber button.
Maybe a poll is in order."to press or not to press" :D
Mine pops open.
What would be the point if you still had to press the button to open it?
Sounds like their fobbing people off!!
ive been playing with my boot release and found the following
If you press the button on the key fob you can open the boot from anywhere within 2 seconds. i.e you dont need to press the black rubber not really long enough if you have got arm fulls of shopping:(
After 2 seconds the latch closes over but still leaves the boot able to be opened for upto 45 seconds by pressing the black rubber button.
After 30-45 seconds (was never the same twice when i timed it:confused: )the car locks again the alarm is activated and the boot can no longer be opened
Hope that helps
Carl
Brilliant! :rofl:
Mine pops open and stays open until I shut it again.
It's all pretty inconsistent is it not
Hope that helps
Carl
Same as mine
On our 1.9 Eleg. (06) Once you have popped the boot with the middle button, you can lift the hatch from any position, you don't have to reach under for the button.
Would it be a case that whatever holds the locking mechanism open is falling back into position which means you have to use the button on the bootlid....when you press the key fob on mine I hear a noise (as if something being pulled open), but if you don't lift the bootlid quick enough the noise appears again and have to use the actual boot lid release. Maybe the return spring (or what ever is to return it to its position is too strong and overcoming the opening mechanism).
but whatever you do DO NOT put your keys down in the boot and close it as it will then auto lock, unless you have spare keys handy it will be a big problem,I have NEARLY done this once only
I done similiar in my cousins Polo before. To open the boot he has a habit of unlocking the doors....after golfing one day I opened the boot with the key, put the key in the boot and..........closed it when finished :) Oops
My boss did similar to this in his Audi the other week, opened the car with the central locking (all doors) then only opened the boot, because a door hadn't been opened the car locked itself again whilst he had the boot up.
Put keys on boot floor so both hands were free, found what he was looking for and shut the boot.
The RAC reckoned they could open the car but it would invlovle some crawling around and wire snipping to get in, so we had to wait for the spare key to be delivered from the office! Luckily we were doing some work in a hotel and spa so we sat in the bar to wait :D
To get back on topic, I press the middle button, boot pops and you can heave the boot open, no need to press the rubber switch on the actual boot. No idea if this times out though as I've never tried that.
Mine pops open.
Shouldn't that be '...key fobbing...'
  • 6 months later...
Anyone hear of a proper fix for this that dealers would carry out? I heard about the adjustment but from the above comments it doesn't work.
I have noticed that the little rubber stopper on the right side of bootlid has the dimples on it damaged, whereas the one of the left it perfect....as if the bootlid ain't sitting right or the stoppers aren't.
Just to add my two penneth..... my 55 plate Octy 4x4 estate ........ press and hold boot l;id button and it opens without the need for the rubber button squeeze:cool:
