Best open air filters e.g. induction kits
Majority use the PD160 an replacement filter, but what about those that chose an induction kit? IIRC heat soak shouldnt matter as much with turbo'd cars as it takes in a lot of hot air anyways to spool turbo up?
what do people think of the powertec, or best stick to pipercross or K&N?
Heat soak is a massive problem with turbo cars, this is why the induction kits for the golf and octavia mk1, come either with a surround to stop the the hot air getting into the intake, or they place the filter low down behind the battery away from the engine. dont forget that the air passes thorugh an intercooler before entering the engine, this helps cool the air but if the air is to hot to start with then performance will be affected.
In my experience they cause more problems than give benefits.
Hi
I tried the Pipercross one on my car
I left the PD160 intake on and directed the air to go on it
Gave 4BHP increase and quite a bit of noise
Because I travell ALOT of miles , I chose to remove it and stick to my panel filter
Sarah
