Oil symbol
right the other day the oil sign came up on my milage clock so though agghhh thats ok it tells me when i need to top up so i went go some oil topped it up and the little spanner and oil sign stays
so i done a bit of reading and found out i have to go to skoda to get my clock resest does any one know the combination to reset it my self as i dont want to go to skoda and get charged just to reset it
Cheers:)
Sean.
Its not telling you to top up the oil (it would be the red light on the dash that came on if your oil level was low) what it is saying is that you need an oil change service done at your dealership , or rather , you need one done within the next 1000 miles or 1 month.
Cheers:)
Sean.
What it's telling you is that it's time for an oil service (ie oil and filter change) I'd advise you to either get the dealer to do this or if your able to do it yourself fair enough but not just to reset the service lights.:cool:
Damn ... beaten to it ! :rofl:
If you search on here you will find out how to reset the service light. :)
'Spanner' means it needs a service, however the indicator may be out of sync with actual servicing
'Oil' symbol (in red) means lack of oil pressure
Re: service indicator, read the manual :)
Edit: too slow x 2:(
If you want to know if the oil needs to be topped up, you need to :-
A - Open the bonnet
B - Pull out the dipstick,wipe it (on any old piece of rag,wife's skirt will do fine)
C - Put the dipstick back in again
D - Pull it out AGAIN
E - Look at the dipstick to check the oil level
I know it sounds like a load of hassle,but with a bit of practice, the whole operation can be completed in less than a minute.Honest.
:rolleyes:
A - Open the bonnet
:rolleyes:
...of course on level ground, with a cool(ish) engine ;):D
If your oil (red) light comes on your car is fukd
A - Open the bonnet
:rolleyes:
Make sure wife not still wearing skirt :D
i have changed the oil my self just need the light spanner and oil message to go
