creaking noise solved
Some of you may know that ive been suffering a creaking noise from the passenger side of the car, possibly the glove compartment. Well with the help of my daughter (child labour comes into its own use;)) i got her to poke her head around the areas i thought it could be. first she could hear it in the glove compartment, then underneath, then bingo. the side cover where the fuses would go if it was a left hand drive. A good whack and its been fine since :)
it just goes to show that many a thing can be fixed with a good, well chosen whack!!
Nothing like a VTT.....Very....Technical......Tap :D:rofl: :rofl:
I prefer "percussive adjustment" ;):D
The skill is not in the tap, but knowing where to tap :D
That's the dodgy panel, not the kid!
Before the PC brigade find this thread!:rolleyes:
Please could I borrow someone's child to sort out my creaking dashboard? Driving me nuts!
We had a guy put VTT in a work passdown one day...a contactor wouldn't pull in, the managers were impressed until they found out what it meant :rofl:
Thank God for that - thought I was going to have to have the other hip done :D
Hope this helps (I know it's for the Fabia and you've got an Octy, but you never know!) :thumbup:
:rofl::rofl::rofl:
Chris
i rather call it a slight nudge thinking about it ;)
It's like the old joke about the retired engineer called in to his old firm because nobody could solve the problem in a huge machine there. He went in and put a small chalk cross on the problem part. Then he sent in a bill for $50,000.
When they queried it he said it was $5,000 for the cross, and $45000 for knowing where to put it!
the technical tap did not fix it, but it did help me find the problem. i get this creaking noise from glove box area anytime the car goes over a bad patch. it was loud enough to sound like a suspension creak.
i opened the door and kept banging with my first in the spot pointed in the pic and i could hear the same creaking noise (faintly tho). After lot of poking around and trial and error I traced it to the glove box door. i held the glove box door tight by stuffing the gap with a piece of folded paper and no more creaking noise. i am going to stick some felt tape to seal the gap soon. hope it doesn't resurface!
UPDATE:
After some more driving I found this was not good enough. I opened the glove box compartment and found the source of creaking noise to be the friction between glove-box light bulb OFF lever and the glove-box door. When you close the glove box door, the door presses against this lever to turn the light off. I stuck a small piece of foam on the lever to prevent the rubbing action. I have also placed a thin sheet of foam behind the glove box compartment before fixing it back. It is pretty quiet now - the glove box i mean - not the car. The car has many bells and whistles ;-) One at a time!
16492.attach
:lol i love the techmical guide mate ;)
