Shell V power diesel
First time I have seen any around here ...but a pump has been given over to it in Swindon ...so I thought I would try some to see what all the fuss is about..........WOW engine is more responsive, quieter, smoother and the mpg is up by 3 so far ....the effect was noticable within 15 miles......just have to see if it cuts back on the smoke now :rolleyes:
which one was that at then?
Hya - out of interest (always liked Shell Diesel Extra so far), what fuel do you normally use?
I found SDE to be less smoke, slightly smoother and a few mpg better compared to normal Shell Diesel or others. BPUltimate is too expensive to bother with where I normally fuel up.
Interesting the difference was so pronounced though :)
Near to Coate water
Been through a lot,
tried the Asda/tesco ones, Yuk very rough poor performance.
Esso not too bad, then just by chance tried some normal shell which was smoother and more respnsive than Esso.....and now the V power diesel 99.9p a litre ....at the moment it's working well....and the difference is very noticable
Very interesting results, Rob. I'm impressed at how quickly you noticed a difference - did you fill up from practically empty or is it mixed in with other fuel?
Chris
Chris
There wasn't a lot in the tank (maybe 10 litres) and I put
Near to Coate water
On the marlborough Rd, near the hospital ;) without having to venture into the darkest depths of Swindon or through the Park South Estate :rofl: (well from the A419/M4 side anyway.
I would have to agree. My engine running very nicely and definately better MPG. No one could see much smoke from mine on Saturday in Keswick, when I was giving it a good run at the meet.
Just found a problem with the fuel :rofl: so much more power my engine must not liked it too much and this morning it went into limp mode :mad: (not much power is there) so pulled over and switched off then started it again and it all seems fine, so I might just go back to using normal Shell diesel
:rofl: - to be fair I dont think that will be your problem, worth checking out what the problem is.
Is there an index somewhere showing which Shell garages are selling this fuel? I can't seem to find anything on the shell website. :confused:
I fill my Fabia vRs with the Shell V Power and I can tell a difference, been using it for a month now and there is less 'black' on the back and the engine is quieter and seems to pull better. My MPG has gone up 4 - 5 and I don't really drive any different, I regularly get 50 MPG on the work run now where it was a struggle to get 45/46 before.
I know it's 6p/litre more but after working it out cost wise to MPG, there is none, or very little difference than using the normal Diesel if you use it long term. :)
Ben
none in south wales!
A shell on my commute has some now. It was 7p a litre more.... Sod that. A good dash of millers and I went for the 95.9ppl stuff.... Still getting damn good economy.
Must say i'm suprised at it going into limp mode as a result of a change of fuel generating too much power..........surely it wouldn't change the output by more than 10-15bhp, if that, given than some manufacturers claim 2 or 3 hp increase from changing the air filter?
I've been running the v-power stuff for a couple of months, and double-dosing on the Millers..........I've not gone into limp mode yet (despite finishing off a front set set of michelin pilot sports.......*cough* hooligan * cough*
Apparently it's in my town! Methinks I'll give a tankful a go after this one is up. :)
I picked up the usual pump, put the fuel in then noticed the 99.9p a litre and realised I was filling up with V power derv from completely empty.
Bit late so I figured I would give it a full tank, and TBH the millers + derv extra is every bit as good if not better and a lot cheaper too.
I filled up a full tank of the normal shell stuff last night, and then noticed the V-Power. I think I'll wait till I've emptied the full tank and fill it up with the gold stuff. Hopefully i'll notice the difference and its not all in my head ;)
I'm currently running on a regular shell diesel + millers tank. I don't usually use any shell fuel, but this tank seems to be giving me an extra 3 or 4 mpg over my usual supermarket fuel. No difference in power though. It could be purely I've had more green lights / less stops while driving, but I'm tempted to keep using the regular shell diesel - It's the same price as the nearest tesco too.
