Fuse box
Hi people, ive tried searching the internet for some fusebox information but couldnt find any. basically my main lights have gone off, im pretty sure its the fuse. But the nthing s i dont know which fuse is for the lights hahahaa :(
They are just numnbered and i dont have the manual as the car was 2nd hand
Just wondered if anyone could help me with this problem?
Thankyou
i havnt got my handbook on me now but why dont you just have a look at the fuses and check to see which one has blown then replace it?
if fuse has'nt gone check the relays
pick on up from the scrapyard
A haynes manual would tell you which is the correct fuse. On the favorit, the car the felicia is based on, the fuses for the lights are to the right hand side.
And before getting a new relay, if it's the same as a favorit, some of the relays are interchangeable so you can simply swap some around (only the ones with the same numbers on etc) and see whether that does something.
hello
these are from the haynes book
FUSE 7=RH DIP BEAM
FUSE 8=LH DIP BEAM
FUSE 9=RH MAIN BEAM
FUSE 10=LH MAIN BEAM
FUSE 11=RH SIDE AND TAIL LIGHT
FUSE 22=LH SIDE AND TAIL LIGHTS
HOPE THIS HELPS
cheers people that does help a lot.
Not very technical with cars at all
Thnaks people
  • 3 months later...
hello
FUSE 7=RH DIP BEAM
FUSE 8=LH DIP BEAM
FUSE 9=RH MAIN BEAM
HOPE THIS HELPS
hi
i have skoda felicia 1.3 GLI of 1999. My car starts well so no battery problem but it still display battery sign on board. Please let me know, its a fuse problem or not? if yes where is fuse location in skoda felicia and which fuse number is for? i dont have manual. if not a fuse problem what may it be then?
That happened to me in my Favorit just 3 days ago, but the relevant fuse (which had simply worked loose in its holder) covers lots of other stuff so the indicators stopped working and the rev counter indicated a constant 2400.
hi
The fuse box is located under the passenger facia. If you look you will see an unlockig nut,unsrew it and the fuse box drops down and is exposed.The fuse for the the socket/cigarette lighter.instrument panel lighting and radio lighting is number 22 brown 7.5 amps.This info is from the felicia manual.
  • 9 months later...
Hi all
I'm having a similar problem with my 1999 Felicia though in my case its the air blower that's not starting. I've changed the relevant fuse from the manual but no change. I'm not sure if its a different problem responsible or if the fuses in my car don't correspond to the manual.
Any advice would be great
thanks
Edited by FelRace
