Post Rolling Road Day Discussion and Pictures/Video
i will be there(work permiting)tho tom said his standard one made 156 so its not a first:D
  • Replies 106
  • Views 7.5k
FWIW I got 156bhp in my standard Fabia at an independant rolling road too! :)
Forgot about that - which RR was that again Tom?
Steve
i think the question has to be,is 180-185bhp a realistic output from a remap alone?gtjunior's didn't make this and that had the uprated clutch and intercooler,and none of the other mapped fabia's made it either so i wonder if it is possible.
When I had a Fabia at first, it ran standard at 136bhp then 180bhp with Jim at Stars map on it, same RR. At other RRs it was between 170 and 190, then I added a FMIC etc no increase in power at all, just the ability to run for longer at that power.
Then I got a lot more power with a lot less reliability. IMHO a remap will be worth it, just make sure it's not generic or your looking around the 170bhp mark which wouldn't be worth the effort as Awsomes are some of the best rollers in the country, transmission losses seem more realistic there. eg my 4wd shows transmission losses of 70bhp, which the car doesn't make till 2k revs but it still moves ????
not bothering with a remap,as the standard turbo isn't going to be there very long:D
Id like to thank Steve also for organising this, cheers mate :thumbup:
I just got back, avec le rear anti roll bar :D
Heres my run, look at the tourqe spike :eek:
Had a good day, was really nice to put some more faces to usernames :thumbup:
cheers
john
was a good day out even in i didnt run the "propper car" and had to settle for a remapped fabia still old smokey joe pulled thru.....
i think i need to challenge skud's title as the smokeiest fabia of the day tho
will post the figures when i get em back off my brother
Yer would have been good to do a sidebyside "pull" with someone behind filming, but i had places to be and roll bars to collect.
Maybe a feature to be added for next year ;) Who has the smokiest fabia? :rofl:
lol well i have the camera and screen mount ;)
What did you get :D
Here you go:
Here you go:
Very very nice pull on that. Beautiful :D
Infact, probably the best I've seen on a diesel.
how come it only runs to 3k?
you should get it done again when you get 10k under its belt ;)
There was an Octavia vRS on Chipped UK's rollers last week and here's the graph.
It's not a very smooth curve due to the car trying to come off the rollers.
my interweb skills are limetted to say the least:rofl:
so is your spelling also :rofl:
my power doesn't seem too good , but the torque has gone up by about 25lbft , its certainly quicker than it was , but i was disappointed by the result , but not as much as Sharky was
Honda figures: Max torque is 251 ft/lbs @ 2000 rpm on the 2.2 CTDi
thats a good effort then :)
got a pic of my brothers 200 quid remap
whats really odd about that is , I have a similar torque output 266-268 , but 20 brake less :confused:
Well BHP is a function of torque and RPM so after the Max torque value your graph will have dropped off. So at the RPM where your Max BHp is occuring will have less torque than a mapped one so hence less peak bhp. If that makes sense. :confused:
I recon it will be summat to do with the dragon box not holding the boost right up the rev range.
the Dragon box doesn't adjust the boost , the peak torque is in exactly the same place 2-2.5k rpm , the max power peaks slightly earlier though
i have about 180lbft at max power which is at a lower rpm (3.8k)
whereas that graph shows 200lbft at max power (4k)
:confused:
:confused:
i dunno then, sounds abit random :confused:
Presumably it might be less in a figure, but probably holds better.
my torque was 280, but my power was 157..........
just depends on the map/engine ect.........
Cheers Steve.
Well Mine made 125 at the wheels with 240ftlbs.
oilburninnut. Could it be possible the actuator has been played with? Your plot is similar to 3fs jnr where at 3.5K the torque seems to hold for longer?
got to agree there , very high figures for a standard car , although i don't doubt what Oilburninnut says that he hasn't done anything to it , just a bit suss :eek:
