DIY Clutch Fit + extras
yep should be hopefully :D
  • Replies 107
  • Views 6.8k
  • sorry matey, was tired last night :lol: probably why i missed the joke in there
Its here, thanks very much mate. :thumbup: Can get the car back together now :thumbup: good man :D
_____
john
The Buxton special will soon be tearing up the Wakefield tarmac once again....woo hoo! :D
Is the lube thing just an "aside" or is it actually related to the thread topic? :rofl:
Yer its high temp resistance greese for the input shaft of the gearbox, you cant just use normal greese apparently, as it wont withstand the high temps and melt off and contaiminate the clutch plate
___
john
if you'll read back towards the begining of the thread you will see that most people just use a bit of copper slip grease, or nothing at all. The copperslip stuff has a low melting point of about 175 ish degrees. A clutch can get temps of up to and over 400 degrees C. With the low melting point of the cooperslip stuff it eventually turns into a sludgey type paste and pics up all the **** etc etc and then you can sometimes get drag or judder due to the plate finding it difficult to slide on the input shaft.
The sachs stuff, and it is in every clutch kit that we seel is designed to withstand these high temps, has a dust resistance so it doesnt turn ****ty and the sachet that you get is the correct amount you need for instalation of a clutch. Your supposed to put it on the input shaft, put the plate on the shaft, taket the plate off, wipe off any excess and then put the plate and fit the clutch up.If you leave too much on then as soon as you start the engine, the centrefugal force will force it from the centre of the plate towards the outer edge of the plate ( towards the friction lining). If this happens and there is enough on the lining the clutch will slip from the off and it wont be long before you need another new clutch as you have just cooked the one you've installed. ;)
Hope that helps matey :D
_____
john
No worries matey, you need any help, our works contact number is 01788 822353, EXT 235. Thats the technical fitting and warranty department which im in everyday, monday to friday except wednesday when im at tech college doing a mechanics course ;)
It's OK - I was trying to slightly funny but that didn't really come across did it. :D I had read about it's intended use, but the way it randomly was mentioned made it look like perhaps it was for some other use
:rofl::rofl: Dirty bugger :thumbup:
I almost used K-Y to fit the cupra bushes - then went for washing up liquid which worked a treat...
If I had used the former - I would never have heard the end of it....
KY helps so many things slide in where they shouldn't go!
I mean like cupra bushes on a fabia :rofl:
sorry matey, was tired last night :lol: probably why i missed the joke in there :doh:
UPDATE:
Box is back in, one miles stone out of the way, now just got to rebuild the front suspension :D
Thanks for the help so far from everyone, especially dan (spaniels FR) Thanks :thumbup:
john
:woot:
:mw:
:smrbow:
No worries matey ;) big up to you for attempting it :D I know how easy clutches are to f*ck up, and with the cost you will have paid for it its the last thing i want to happen ;)
You clean the box up too?
Yup, Feeling much better now, clutch is all bleed up and i have a nice peddle.
Yer gave the box a nice clean :thumbup:
UPDATE:
start motor on
subframe back in
consoles back on with cupra bushes
bottom arms back on with powerflex bushes
arb back in place with new brakets and powerflex bushes
dog mount back on
clutch bleed up
drive shafts bolted back on with new bolts and tourqued up
gear shift cables back in a corretly adjusted
box filled up with oil
Tomorrow should see
battery back in
air box back in
all remaining brakes bleed through
tt brakes fitted if they arrive :mad:
oil change and filter
write standard map back on car for beading in of new clutch
all wheel arch liners back in and undertray on
wheels back on and the all important first run out :thumbup:
whoooo whooooo not long now.
Am knackered off to sleep ;)
______
john
Did you use an axle stand / jack to keep the engine up on the gearbox side whilst the gearbox was out? Not sure how to manage that with my car on a 2 post lift. Might have to make a frame up to hang the engine off from above.
Yup, used an axel stand and a block of wood.
On a ramp thats what they would do, use an engine hoist bar. Basically abit of box section with a sling in the middle :thumbup:
Well ive finally managed it, shes back together and runs like a dream. the clutch feel is exellent.
The cupra bushes etc have really stiffened up the front :thumbup:
Not really pushed it yet as i am bedding the new clutch in, but will write a full report once ive had a proper go.
Many thanks to all the people who helped and a special thanks to spaniels Fr for the grease and guidence and to sarah @ awesome for arranging the speedy delivery of my clutch :thumbup:
Well am knackered now so am off to get some well earned rest. ;)
And to top off a brill day the postman brought me the bargain of the century 312mm brake kit :thumbup:
____
john
Well done matey! :thumbup::thumbup::thumbup:
Nothing like doing it yourself - enjoy the feeling of satisfaction - you worked hard to earn it.....
I wonder how much you saved (at UK prices)?
Bas
Bas
Thanks basil, I worked it out to be a saving of around £500.
the best saving is got to be the brakes :D £80 for calipers, hangers, and green stuff pads. then £50 for some discs :thumbup:
Next project is going to be the turbo :thumbup: Watch this space :D
cheers john
all fitted and finished then john?
the 312's make nearly as much difference as the arb:thumbup:
Yup all done :thumbup: Get the cupra bushes on yours mate......... BIG difference ;)
The front end is now as solid as a rock, these no wobble at all :thumbup: Ive got cupra rear console bushes, powerflex arb bushes and powerflex front TCA bushes.
Just waiting for the discs then the brakes will be on :thumbup:
Your coilovers are in stock at KW, give me a shout when you need them and ill get them sent over ;)
cheers
John
shout:thumbup:
shout:thumbup:
Ok mate, ill pm ya later on ;)
