Scratched Door
I was reversing my black Furby VRS into my drive yesterday, & our
Try Tcutting it, working along the scratch to clean it out. Then look at a touch up kit if you feel confident enough to do it yourself.
If you go to an expert then I would give it a good coat of wax to protect it until its fixed.
are the neighbours really that bad?
Have you had a word with em,or are they that sort that'll just give you loads?
Use the paving stone to beat the ignorant gits to death :)
Bit harsh :eek: but if they are that bad.....GO FOR IT! C.J.
Thanks for the T-Cut advice, I will give it a try.
Regarding the neighbous there is no point talking to them as they intended this to happen. So I don't want to give them the satisfaction of knowing they succedded. However I have got rid of the paving stone & if another one returns I will insert it into a one of his orifices.
... if another one returns I will insert it into a one of his orifices.
:D make sure it goes in sideways, with the jaggedy edges sticking out :thumbup:
If it's there paving stone you best return it.....
...through lounge window preferably :rolleyes: only joking but I bet you wish you could.
T-cut should do the trick if its not down to the metal. Follow with a good buff up with your polish of choice. Auto Glym red label resin polish is good.
Out of intrest, what do your neighbors drive
