Felicia 1.3LX Instruments
I have installed a Felicia Dash into a modified Mk1 VW Golf with no problems at all. My question is: where can I get a proper wiring diagram for the instrument panel? It has 3 - 10pin connectors at the back (white, yellow & black). I'd like to know which goes where. Eg: Earth, fuel sender, oil pressure etc.
I've managed to get most of it to work but I'm not quite there yet and the coolant temp shows midway even on a cold engine. Should I fit a resistor to lower the voltage? Any ideas?:confused:
Welcome to Briskoda.
I'm afraid I don't have a solution to your problem but I respect anyone who has fitted a Skoda Felicia dash into a modified Mk1 Golf with no problems at all!!!
The Haynes service and repair manual has good electrical wiring diagrams that seem to be the original skoda diags. I have scanned the page, hope it helps
Cheers STOPAN! I'm sure i'll manage to figure it out now. By the way, Rich, thanks for tha compliment... it really was as if it was meant to be there. Just had to drill 4 holes and slight mods to the air ducts. Took less than 2 hrs to finish the job.
