Fabia Fault Codes
Hey, I bought a fabia yesterday and thought i'd do a scan of fault codes. Can anyone please shed some more light on these two?
VAG-COM Version: Release 311.2-N
Control Module Part Number: 6Q0 909 601 C
Component and/or Version: 02 AIRBAG VW5 0006
Software Coding: 12338
Work Shop Code: WSC 13765
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
Control Module Part Number: 6Y0 820 045
Component and/or Version: Klimaanlage X0760
Software Coding:
Work Shop Code:
1 Fault Found:
00818 - Sensor for Evaporator Outlet Temperature (G263)
30-00 - Open or Short to B+
Thanx for your time.
Paul
Hiya.
You'll probably get a better response to a question this specific in Skoda Support / Fabia.
Welcome to Brisky!
The Airbag fault may be as a result of the battery being disconnected at some point - clear the fault and see if it comes back and if it does, you can pursue it.
The second fault is the infamous evaporator temp sensor IIRC which will mean your air con is not blowing very cold. You could get a dealer to fix it, but it's 3 hours labour if you follow their procedure and remove the dash, or you could follow Mr Apogee's excellent guide here and DIY it :D
Chris
