Problem Connecting to t'internet ??
Have an ethernet wired PC upstairs(Vista Ultimate) and a wireless laptop(Vista Home Premium).
Was connected through an orange livebox but it was temperamental at best so I changed to a BT Voyager 2500v which has been working flawlessly for the last month.
Switched the PC on yesterday and it was showing problems with the network connection
I go into the network centre, and for a while it shows an 'unidentified network' with limited connectivity and if I try to repair the connection it then shows that I have multiple networks, with one being 'Unidentified network' and the other being 'network 2' but neither have any more than local access.
The laptop still works fine via the wireless connection. I have tried a system restore but that made no odds, the only thing I can think of is that I installed Photoshop CS3 the night before the connection went tits up but I cant imagine thats got much to do with it??
I did an Ipconfig from my desktop and got the following,
Microsoft Windows [Version 6.0.6000]
Copyright © 2006 Microsoft Corporation. All rights reserved.
C:\Users\Derek>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Desktop
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : home
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : ULi M526X Ethernet Controller
Physical Address. . . . . . . . . : 00-13-8F-C4-EE-48
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::e8db:ae71:5b2a:7c2d%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 09 February 2008 19:13:21
Lease Expires . . . . . . . . . . : 10 February 2008 19:21:24
Default Gateway . . . . . . . . . : 0.0.0.0
192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 150999951
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.2%13(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 7:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
And an IP config from my laptop and got the following:
C:\Users\Derek & Sharon>ipconfig/all
Host Name . . . . . . . . . . . . : Laptop
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-C0-A8-E5-F8-59
Link-local IPv6 Address . . . . . : fe80::c72:1314:1ec2:1399%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.3(Preferred)
Lease Obtained. . . . . . . . . . : 09 February 2008 16:54:11
Lease Expires . . . . . . . . . . : 10 February 2008 17:55:27
Default Gateway . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 234930344
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Ethernet
NIC
Physical Address. . . . . . . . . : 00-16-D3-64-7C-A7
Description . . . . . . . . . . . : isatap.{AD9603EE-08F5-475C-8500-0DB66EAAA
32C}
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.3%12(Preferred)
Tunnel adapter Local Area Connection* 9:
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e66:1022:2ab1:c177:a63c(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::1022:2ab1:c177:a63c%10(Preferred)
Default Gateway . . . . . . . . . : ::
Any ideas, Im confused but that doesnt take much :D
Well, the ethernet on your PC seems to be connected, because its got a IP address lease from DHCP..
One thing that doesnt look right is it has 0.0.0.0 as a preferred gateway as well as the router address.
can you ping other machines?
ie:
ping 192.168.1.1
which should reply as its your router
and 192.168.1.3 is currently your laptop.
Agree with Col - default gateway should be 192.168.1.1 and if it's picking 0.0.0.0 then nothing will be able to get out of the box. If you have 2 networks shown, then it may be worth deleting both and letting it create a new one :D
Chris
I Pinged 192.168.2.2 and 4 hops <1ms
Ping Statistics
Packets: Sent = 4, Received = 4, Lost = 0
Then Pinged the laptop with the same results, only a slightly longer time 99ms.
Can you ping Google from each machine (or do a traceroute)?
Chris
100% packet loss and timed out for that, just going to try deleting the connection.
(works on the laptop)
Sounds like none of the packets are making it out of the LAN then (if you have the default gateway as 0.0.0.0 then it just uses "broadcast" to send packets which means they'll only get as far as all machines on the LAN). When you have the new connection, make sure the default Gateway is 192.168.1.1 and all should be well.
Chris
Hmm, wont let me delete the network only disable, diagnose etc etc.
Should i put in the default gateway through the TCP/ip bit on the existing network.
Strangley it says multiple networks but whe you go into network connections its only actually showing the 1, my lan connection.
Yeah try changing it on the existing connection and see if it fixes it. The other settings looks fine.
Chris
Pretty confused now :confused: Put in the manual settings and couldnt work out what to put my IP addy as in TCP/IP settings, so set it back to automatically obtain while I posted on here on the laptop.
My daughter crawled in and played her favorite game (Push the buttons on dad's PC) and the computer restarted :mad: and its started working again :o
the ipconfig looks like this now
Lease Obtained. . . . . . . . . . : 09 February 2008 20:46:57
Lease Expires . . . . . . . . . . : 10 February 2008 20:47:00
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.2%10(Preferred)
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e66:f7:355:c177:a63c(Preferr
ed)
Link-local IPv6 Address . . . . . : fe80::f7:355:c177:a63c%8(Preferred)
C:\Users\Derek>
I'm scared to turn it off now :D, thanks for the help. :thumbup:
For manual settings you'd want to enter these:
although the value of the IPv4 address doesn't matter too much so long as it's a 192.168.1.x address it'll be fine.
Glad it's all working now - you'll notice your ipconfig output no longer has 0.0.0.0 has the preferred gateway so it knows that it needs to route through 192.168.1.1 :thumbup:
Chris
