flashed at red light!
got flashed by a static camera on an amber/red light, well i think i did :s only flashed once if it did. whats the penalty? points and fine??
3 60
Yes, 3 points and £60. Your license will also be endorsed with a TS10 offence code.
That said, if the light was red, it would flash but they normally dont flash on amber and some are setup so that the camera is only enabled after red has been showing for a period of time, say 1/2 second.
thought so, wouldnt of said it was red, might just of been my imagination. whats a TS10??
TS10 is the endorsement you would get for failing to stop at traffic signals. It brings three points.
so 3 extra points?? 6 all together? just done a quick check on net and it says the flash twice, im certain it only flashed once! fingers crossed might not of flashed at all! knowing my luck i'll get banned :(
only 3 points total.
IIRC (they go off all the time in London*) they only flash once, they do not need to go off twice as they are not recording your speed (a speed camera takes 2 photo's) just that you have gone through the red light, so one photo is enough.
* this is from others going through red lights not me BTW!
oh well, **** happens, im still alive :D
They need to go off twice.
Once to show you behind the line and once to show you past it.
:iagree:
check out PePiPoo: Helping the motorist to get justice great site for ermm indiscretions:D
Erm, I will beg to differ there.......
The Peizo strips are just past the white lines on the ground so how would the camera take a pic BEFORE you have crossed the line?
Steve
Steve
what i'm sure he ment to say...as with me :D is once your triiger the strip just past the line it's takes 2 piccys once to show you triggering it and once to show your direction of travel from what i can remeber
need to go off twice, to proove that you went through the red light and hadn't just pulled up over it/ stuck slightly over it due to traffic. Most red light cameras are also speed cameras when activated. Do a search on google for red light cameras, alll the photos show 2 images. I am paranoid about red light cameras, at say 200 yards and they are green do you slow down to a crawl just in case? they always seem to cahange just as i am about to cross the line :rofl: If you only think you saw a flash and only one at that, then the odds are it was light reflecting and catching your eye rather than a flash, no point worrying about it you'll know in 14 days :(
