Plug and play help please
Hi all
I've searched but if I'm honest I'm still confused.
I've got a 2002 vrs and I've just got a MFD D.
I put it all together with a plug and play cable, turned it on and put the supplied code in and it said the code was wrong.
So I contacted the guy who sold it to me and he said that the safe pin was probably not connected as the code was definately correct.
So I took it all apart and checked the safe wire, which IS powered by the
P n P cable.
But it still won't accept the code.
Do I have to switch any wires or should the plug and play cable take care of any wiring issues?
If there are no wiring issues I guess it's a code problem, any advice will be wholeheartedly welcome.
careful if you get it wrong I think 3 times you have to take it to a dealer or something.
Try speaking to VRStu, who should be able to help there.
Thanks for replying, I posted this on VWNavi too and stu has replied on there.
I think your best option is to go to a dealer and ask them to get you a code - unless you want to send it back.
Certainly sounds to me as if the code is wrong.
Right, I sent the unit back to the seller and bought another one from a UK seller. Went to his house and said that if it didn't work straight away I would'nt buy it. Connected it to my original wiring, put the code in and sorted one working MFD. So I was right all along it wasn't my wiringrolleyes.gif.
I need to check a couple of things with you lot now though?!
What number is the Gala setting supposed to be? It is currently set to 48 and the tyre size is 1355.
I take it these aren't the sizes I should have?!
What should they be for a 2002 Octavia VRS?
I've replied in your other post.
Yes seen that.
Perhaps I should add a link to the other thread to stop double posting.
Many thanks for your help Stu.
Need some help... - vwNavi
I hope I haven't broken any rules by posting the link. Apologies if I have.
