312mm brake upgrade
You wouldn't want t be grooving OEM discs...
They will deform and crack where the grooves have been cut into them due to the heat. Also if the grooves are too wide they will have a negative effect on stopping power rather than just keeping the pad surface clean.
I'm using the pads which came with the kit and they seem more than adequate! The real test will come at the 'Ring sometime this year :)
What does the 180bhp Leon Cupra use?
they use 312mm same as octy vrs and others. ;)
