Cruise Control
Hi all, was hoping to put cruise control on my motor on the cheap as money is a luxury at the moment as a few will probably know, but all the part numbers I have found aren't recognised by any of the VAG main stealers. Was just wondering if anyone out there would have an up to date parts list to allow me to do this. It's probably the stealers not wanting to sell the parts as they want the money to fit it but just checking in case they've been superceded.
Thanks in advance.
Big K can supply and fit it for
If you really want to do it yourself your Skoda dealer can get the parts for you - except for the wiring loom needed between the fusebox and the ECU. That is available through another Briskoda member for
the main wiring loom (between the stalk and the bulkhead connector is NO longer available from skoda dealers only can source from vw dealers ONLY.
I stand corrected, K. (The VW part numbers can be found in our Links section.)
Thanks fellas. Much appreciated once again
