No response from controller
Righto just got VAG-COM and cant get it to work with the octy :(
Done the test as it passes but get CAN: Not Ready
When ever i try to access something i then get what it says below in the attachment
Anyone have any ideas?
I wouldnt mind but i managed to scan through my brother Ibiza last night with it fine
19623.attach
try disconnecting your battery for a while then attempt again.
thanks for that will give that a go later on
Which flavour of Octavia are you using it on?
Being CAN I'd guess a Mk2. :)
It could be a MK1... the test result will show 'CAN: NOT READY!'... which is fine on a mk1.
Let's start all over here...
#1 Which interface hardware are you using (i.e. what does the label on it say)?
#2 What do the 7th and 8th digit of the VIN say?
Sorry its a MK1 so 1U chassis
The interface is HEX-USB + CAN
Then the CAN not ready is normal since the 1U doesn't have a diagnostic CAN. So the real question is why can't you communicate with the cluster? I assume you are able to talk to other modules just fine?
No thats what i dont get.
I tried to do the auto scan and it fails. Try's 3 times on each and then moves on to the next but every time i go into test the interface it will pass
Ok, now we are getting forward. :)
What message (exactly) do you get when using Options > Test?
I get as below
Port Status: OK
Interface: Found!
Type: Ross- Tech HEX-USB+CAN
Version:1.78
Status: Ready
K1: OK
K2: OK
CAN: Not Ready
That's fine. Since it worked in your brother's Ibiza, the logical deduction is that there's something awry with your Octy. First, check that the cable is fully seating in the socket.
-Uwe-
Well thats what i though as like you said it worked fine in an Ibiza (6K)
Ill check the socket as its in a stupid place and not the easiest to to secure properly
Well i tried it again today and it works fine so god know what was happening with it
hi. i don't know but it seems to be a problem with vagcom licence. your cable is an 704 like mine... in the beginning my cable shows this and after that, the cable died...
(sorry for my language...!)
bye
bye
If your cable was a copy and not a genuine cable then it may well have had a firmware update which killed it.
Mine is working now anyway
I HAVE THE SAME PROBLEM TOO
MAYBEE I DID NOT CONNECT IT PROPERLY :rolleyes:
LAPTOP RECOGNISES LEAD AND THE LED LIGHTS WHEN I CONNECT TO THE CAR BUT IT SAYS ABOUNT THE CONTROLLER.
WHAT IS THE CONTROLLER?? IS IT THE ECU???
Please turn off your caps lock, it is considered shouting on an Internet Forum. Thanks.
The controller is the electronic module to which VAG-COM is trying to connect. No communication to any module could indicate a number of problems.
For more assistance, we need much more information. What type of interface are you using? Are you sure the drivers for that interface were properly installed? Did you go to [Options] [Test] and verify that the interface was working?
yes everything tested ok on the test but when scanning various addresses for modules i get the no response from controller apearing.
i have tried changing the com ports etc on device manager but still no good.
Have you tried contacting your diagnostic hardware supplier?
Hello I have the same problem getting no response from controller every time i try. My cable is not ross-tech original. It just says OBD-II on the adaptor. The led works ok when I connect it to the car and the interface test looks ok. I'm using VAG COM 409.1 release. Any ideas?
