2001 fabia hub nut removal HELP
HI
I'M HOPING SOMEONE CAN HELP ME I'M REPLACING MY LOWER L/H SUSPENSION BALL JOINT AS IT'S KNOCKING AND CREATING A HELL OF A DRONE BUT THE HUB NUT IS THE ORIGINAL ONE AND ITS NOT 12 SIDED BUT APPEARS TO REQUIRE A MASSIVE ALLEN KEY AM I RIGHT OR JUST BEING STUPID IF I'M RIGHT WHERE THE HELL DO YOU FIND AN ALLEN KEY THAT SIZE??????? ANYONE WITH ANY IDEAS OR GUIDANCE WILL BE GREATFULLY LISTENED TO. THANKS,
JOHN:confused:
Hi and welcome to Briskoda:thumbup:
Where are you based? I've got an allen key set that would do the trick.
Welcome John.
Please could you turn off the caps lock as it is considered shouting in an interent forum.
Please refer your question to the appropriate section where it will recieve the correct replies.
welcome to briskoda
Davy
