Bigger Lens
I'm thinking of getting a bigger lens?
What do you think of this?
A compact, handheld photography is possible 600 mm equivalent of the super-telephoto zoom lens Too super-hope regions of 140-600 considerable mm are achieved by the lightweight design of 127mm only in the total length and 620g in mass in 35mm seal conversion. Too super-hope zoom lenses of 600 considerable mm that can reserves be taken a picture can aim at the shot with power according to various angles by light footwork, and expand the taking a picture area greatly
  • Specifications :
  • Focal Length :70-300 mm (35mm size reduced 140-600mm equivalent)
  • The lens consists of: 10 group of 14 sheets (ED lens 3)
  • Angle: 18 ° -4.1 °
  • The shortest range: 0.96 m (MF use) * However, in the shortest time AF range 1.2 m
  • Maximum magnification shooting: 0.5 times (35 mm equivalent size reduced 1.0 times)
  • Nearest neighbor shooting range: 26 x 35mm
  • Drawing feather item: 9 (circular aperture)
  • Maximum aperture ratio: F4.0 (70mm) - F5.6 (300mm)
  • The minimum diameter ratio: F22
  • Filter size: φ58 mm
  • The maximum diameter x Length: φ80 x 127mm
  • Weight: 620 g
  • Lens food LH-61E, lens cap LC-58C(58mm), lens rear cap (LR-1)
For just over just over £200 deliver is it worth a punt?
Might be best getting one with VR or some other stabilisation. What brand of camera / lens are you thinking of?
It wouldn't be me.
Hand held at 300mm is going to require at least a shutter speed of 1/300s or higher in order to provide blur free shots, and at f5.6 will need quite a bright subject. A max aperture of f4.0 (at 70mm) isn't that good. If you feel you want to experiment with long telephoto I'd just get a 250 or 300mm fixed lens.
I got a 50mm, f1.8 Nikkor lens for my Nikon d70s and hardly use anything else. Excellent for portrait and scenery alike.
Have you read kenrockwell website?
I'll check it out :thumbup:
personally , i would leave the lens where it is,, glass for your camera is worth spending every last penny on IMO, you can spend all the money in the world on a great camera and then have a £100 lens stuck on the front of it and wonder why your piccys look bad,, working the other way,, you can have a £300 camera, and a £500 lens and you will say WOW to your shots far more often! :D
