Engine Light On Again
I will keep this a brief as possibe . . .
Engine management light came on the other day , after a quik phone call to the garage they advised me that i could still drive the car (as long as it was running normal) , no loss of power ect and that the fault was prob down to a faulty sensor , anyway 10 mins later it went off .
Took it in today for them to check it over and the guy said it was showing the fault on the computer plug in thing but it was now cleared , however sods law its come back on this evening on my way home , rang them back and basically cant get it in til next friday :( but still say its ok to drive , unless it starts to feel rough
What should i do , still drive it or not :rolleyes:
vRSphil has kindly arranged to meet me later to plug in his VAG to see whats up with it . . . fingers crossed :thumbup:
This happened to me on my vRS TDI the other day (Sunday ), light came on and refused to go out, but car drove perfectly normally. Rang Skoda Assistance who were going to send usual RAC guy and then got a call 20 mins later from them saying that due to nature of problem they would prefer to send a fully qualified Skoda technician to look at it but wouldnt be able to come until Monday morning, fortunately I was not working Monday so said ok.
Mechanic turned up at 0815 in the morning ! and diagnosed a blocked sensor tube (apparently said sensor monitors the pressure either side of the Cat and can get blocked with sooty particles which screws the readings) Problem resolved by blowing compressed air though the relevant bit and Hey Presto ! all now ok.
Credit to Skoda Assistance for recognising that engine lights on vRS TDI's seem to require more 'know how' than normal, and credit to the guy who turned up so early in the pouring rain :)
Edit: forgot to add, if its under warrenty get Skoda Assistance to come to you rather than you going to the garage ;)
Keep the driving to a minimum until VAG-COM sheds a little light on the situation, the CEL is of course there for a reason. DO you have something in writing from the dealer saying it's ok to drive?
i can't believe it mate. Must be something up. Maybe a faulty sensor.
Well i know what it is now , according to vRSphils vag.com there are 2 faults . . .
1st one is down to a " exhaust pressure sensor 1 "
2nd fault is " central convienience malfunction 0010 " whatever that is .
At least i know what to tell them when the motor goes in tomorrow morning
CHEERS vRSphil , owe you one
Do you actually have the Scan results in full?
Exhaust pressure sensor isnt uncommon. Either the sensor is knackered (more than likely) or the vacuum pipes have become blocked.
Conveniance faults are well worth clearing and forgetting about. these later cars seem to store hundreds of them and basically if there is no obvious fault I usually clear them.
Yep , pvRSphil has e-mailed me the 4 x pages with everything on (think its the full print off)
I was going to ask what the Conveniance Fault was in full.
VRStu , all it has is . . .
Component: LIN BACKUP HORN H07 9001
Component: NGS n.mounted
Component: IRUE No Answer
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 2
Reset counter: 57
Time Indication: 0
Then this was the first fault . . .
1 Fault Found:
001137 - Exhaust Pressure Sensor 1 (G450): Implausible Signal
P0471 - 006 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 1
Fault Frequency: 14
Reset counter: 40
Mileage: 16612 km
Time Indication: 0
Date: 2000.00.00
Time: 14:42:19
Freeze Frame:
RPM: 0 /min
Torque: 144.0 Nm
Speed: 0.0 km/h
Pressure: 42.6 mbar
Text: -42
Text: mbar
Text:
I had my 'emissions' warning light come on 10 days ago, followed a mile or so later by the 'DPF regeneration' light as well. Called out Skoda Assistance/RAC and found Exhaust gas pressure sensor fault and DPF regeneration required.
We dealt with the latter on a 15 mile road test and the RAC man then cleared the 'emissions' light and said all was well.
Last night; the emissions light came on again, at least it stayed on after starting the car! Drove to work this morning and no further lights came on, phew.
I've the car booked in with my dealer for tomorrow (Thursday); so we'll be able to compare notes. :thumbup:
Will do , mines in at 08.00 as the doors open , funny thing happened , after i left vRSphil about an hour after the D.P.F light came on for about a minute then went out , very strange things happening now , see what they find tomorrow
Nothing to worry about there then. It's common to get that fault on the interior sensors if you scan with the door open.
The emmisions one is probably a faulty sensor.
cheers VRStu , been in today with the print out, cars booked in for next friday to get it hopefully sorted .
Dealer has it 'Fixed'. :thumbup:
Turns out the 'emissions' light was on for 'an intermittent DPF fault' and not either of the Exhaust gas sensor or connection pipe blocked. Its likely that this is a hangover from 10 days ago when, although the RAC man had cleared the warning light he had not reset the fault core record.
Anyway; dealer says light is off, nothing to replace and he advised that I drive in 'DPF Regen' mode on my way home on the M'way; he actually offered to take the car out on a drive this afternoon to do this, but as I know what needs to be done and I go on the M'way myself I said "Don't bother".
Fingers crossed. ;)
Lucky you , had to get the R.A.C tonight to mine , same fault again the exhaust pressure sensor , back in tomorrow to get them to have a look at it , doesnt feel right when its running . The R.A.C guy did all the checks with the V.A.S thing and it only showed the above two faults , he recommends taking it in A.S.A.P
Lucky you , had to get the R.A.C tonight to mine , same fault again the exhaust pressure sensor , back in tomorrow to get them to have a look at it , doesn't feel right when its running . The R.A.C guy did all the checks with the V.A.S thing and it only showed the above two faults , he recommends taking it in A.S.A.P
:sorry::sorry: Sorry to hear you still have problems. Rough running is a fair sign that you have something up.
Good luck getting it sorted.
Argh !! I spoke too soon. :eek: Started the car this morning and the emissions light did not do out! :mad:
This is despite doing the 15 miles M'way I use for my commute at 'DPF Regen' speed of 1,900rpm in 5th (57mph) on the way home last night; as advised.
Oh well; better call my dealer in a while. :(
Argh!!
Gutted mate, hopefully it's nothing too serious :(
Seems to be loads of problems with this , the R.A.C guy said that its a common thing with VW/SKODA at the minute .
The problems seem to be getting more frequent as the DPF cars get older and accrue higher mileages.
Another reason VW are jumping onto CR technology PDQ.
Took my car to my dealer this morning and found out I have a faulty 'Exhaust Gas Pressure sensor'. The part is on order and car booked into my dealer for Friday to fit it and they will check and clean the air pipes to the sensor at the same time.
Usefully, I got shown the Workshop Guide/Manual for the exhaust system for the PD 170 engine with DPF. As is said 'a picture is worth a thousand words' and I now have a fuller understanding of how everything works. :thumbup:
I actually got caught in a M'way traffic jam last night and took about 20 mins to go 2 miles! This got the DPF light on and warning message on the maxidot. I was almost home, so this morning drove to work in 'DPF Regen mode' (1900rpm/5th gear) and the DPF light went out within 11 miles. Good to know that this system works and that it is probably the EGP sensor fault that is causing the DPF to soot up more quickly than it ordinarily would do. I hope.
:confused: ... but won't the CR engine have a DPF as well?
Got my replacement EGP sensor fitted on Friday and it has brought my car back to full health.
Two things I noticed whilst I was running it with the faulty sensor were that;-
1. The engine seemed to want to cut in on 'regeneration' very easily with, for example, the tickover coming up to 1,000rpm at the slightest provocation, and
2. The miles to next service prediction had dived. That is; having had the car serviced at the beginning of April and covered 350-400 mile the prediction was an expected 18,500 miles. As soon as I got the first EGP sensor fault (that the RAC man came out to) the mileage started going down at an alarming rate, showing only 10,000 miles to service by last Friday; when I had only covered about 850 miles since it had been done. Having had the sensor changed and with only covering a limited mileage over the weekend I am relieved to see that the prediction is up to 10,900 miles by last night and, I hope, will continue to climb over the next week or so.
