• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
tyre noise? wheel bearing maybe?
Sign in to follow this
Followers 0
10 posts in this topic
Hi all,
Driving from about 32 -35mph I hear a whuring sound from the front of the car. I think its coming from the wheels/one wheel maybe. Doesnt matter what gear I'm in and as soon as I drop below or go above those limits the sound is gone! Any ideas?
Share this post
Link to post
Share on other sites
Had a problem with mine, it was uneven tyre wear on the outer edge of the rear tyre. They were worn but not down to the indicators.
Changed front to rear and had new fitted to front no problems since.
1 person likes this
Share this post
Link to post
[quote name='sweep' timestamp='1346538947' post='2919050']
[/quote]
THIS.
I had the same issue when i bought my VRS and the rear tyres were 'stepped' giving a whirring noise anything over 30 mph.
Change the front tyres to the back and see if the noise changes or goes away. Its a quick and free fault finding exercise.
Check the wear on the shoulders of the tyres when you have them off and check the lateral play in each of the wheels by wriggling the wheel left and right to see if there is any excess movement that may indicate a possible bearing going.
Niall
Share this post
Link to post
This is so weird, think i have the same problem but i swear its coming from the front passenger side. Started hearing it last night. but mine sounds like more of a nail/rock in wheel, (checked all 4 wheels and there seems to be nothing there).
Share this post
Link to post
I've been having exactly the same issue with mine. Since been low, the front tyres have worn unevenly, so I've swapped front and rear tyres. I had the whirring noise at 25mph. I put the spare wheel on the front drivers and problem solved.
Now I know what it is, I have put the alloy back on and will jut keep check the tyre regularly. I thought maybe the tyre had a
slight flat spot or something, but I'm no expert! Glad others are suffering with the same problem :p
Share this post
Link to post
[quote name='boylers11' timestamp='1346625445' post='2920111']
^^ sorry for the crap typos, I'm on my phone!
[/quote]
Hopefully not also driving at the same time, that's called multi-tasking. LOL
Share this post
Link to post
I had a similar problem to this (sounds like it at least) - it would start after a mile or so of driving at 60-70mph, and would last another several miles. The noise was relevant to the speed. New tyres on the front didn't solve the problem, but the garage who swapped + installed new tyres identified that a brake calliper had seized on.
Since I got that sorted, the problem disappeared. Something worth checking out any way? :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
