• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Alarm type on superb
Sign in to follow this
Followers 0
9 posts in this topic
Hi
Could anyone tell me the type of alarm I currently have on my car. It is a 2011 superb elegance 1.8 TSI?
Many thanks in advance.
Share this post
Link to post
Share on other sites
It's mounted under the bottom of the windscreen, I think on the opposite site to the air-intake for the HVAC. It's riveted to the bodywork.
The alarm unit contains the controller, a battery backup (rated for 6 years) and an alarm siren. I think the alarm siren 'vents' or sounds into the wheel well but I'm not sure as I haven't actually seen one.
The interior monitoring is via ultrasonic sensors mounted in the roof console. If you have a sedan, you have two sensors. The combi/wagon/estate has three sensors as the interior is longer.
Door switches will also trigger the alarm. There is no glass break sensor.
Other things that will trigger the alarm:
- disconnecting a trailer while the car is locked and armed (requires OEM trailer control module, not a generic after market);
- a significant voltage drop in the car battery (i.e. someone trying to remove the battery);
- opening doors, the boot or the bonnet/hood;
- interference with the ignition switch (for cars without KESSY). This can include attempting to force the ignition lock without a transponder key near the RFID reader;
- there is a tilt sensor that can detect the car being towed;
There is a button on the lower section of the B-pillar, drivers side. Pressing this button before locking and arming the car within 30 seconds will disable the interior ultrasonic motion sensors and the tilt sensor. The reasoning for this is if you leave a pet in the car, or are having the car towed.
Note: leaving the sunglasses storage thingy open will block and interfere with the ultrasonic sensors, reducing their effectiveness
Share this post
Link to post
Hi all and Happy New Year!
I was wondering if you'd recommend the factory alarm over an aftermarket canbus alarm (on the car's own remote) like Viper 39xx? The factory alarm doesn't have shock or outside perimeter sensors. Can the factory alarm be controlled from the maxidot to close windows when keeping pressed the close button on the remote? Or else?
Share this post
Link to post
Happy arbitrary calendar overflow to you too.
The alarm itself has nothing to do with closing the windows by holding down the key fob, but you can turn this feature on by Maxidot or VCDS.
I personally don't think car alarms achieve anything, people here just ignore them and walk past as there are too many false alarms. If it was an option, I wouldn't have optioned it but it came standard so meh.
Share this post
Link to post
Havent activated anything on MaxiDot but if I hold on "Unlock" button on remote then it opens all windows and when I hold "Lock" then it closes all the windows.
I myself consider factory alarm enough and those perimeter things can really be annoying. Factory alarm could IMHO be louder tough.
Share this post
Link to post
Factory alarm has tilt too (more reliable than shock), and does have perimetric. Perimetric means if any doors / bonnet / boot are opened it will trigger.
Were you looking for something more than this?
Share this post
Link to post
I was looking for shock like another car hits mine while parked or the thief knocks on a tire to see if the car has alarm (I have now and it blirps once if you kick a tire or punch the car, or stay very close, it has two settings for shock and perimeter)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
