Superb Combi Electric Rear Door - Closing from inside the cabin
I finally had some time to play with VCDS on my new Superb.
I know some of you (especially the Taxi-ists) have been asking if the button next to the gear stick can be used to close the door. By default, it does not, however with a simple VCDS change it can.
You will need:
- VCDS cable with a valid license and a computer
1. Connect VCDS cable and turn on ignition. Do not start car. Open VCDS and select address "6D-Trunk Electronics":
2. Select "Security Access":
3. Enter the secret magic password "12345" and click "Do It":
"Dark Helmet: So the combination is... one, two, three, four, five? That's the stupidest combination I've ever heard in my life! That's the kind of thing an idiot would have on his luggage!"
4. Success!
5. Select Adaptation and then select the relevant channel (highlighted below). Choose "Activate" and then select "Do it".
6. You may also wish to turn off the beeper. You can do it one of two ways.
Option 1: Select "Volume of warning signal in automatic operation" and choose "Not active" . Note it's not actually a volume, just an on/off.
Option 2: Select long coding, then clear the option "Tone Generator Installed"
Notes:
- There are a few other things you can do in adaption like change the pitch of the warning tone (default is 1000Hz) and the duration of each 'beep" (default is 0.5 seconds
- You can also enable closing the door by the keyfob, see the picture in part 5 above and the rest is obvious
- Note on the two options: "Touch function for closing" requires you to hold in the button until the door is closed. If you release the button the door motion will stop. "Tap function for closing" just needs a single push on the button to close the door. I'm not sure what happens if you activate both options as I didn't try it.
Edited by wokwon
Thankyou :kiss:
this is something I looked into 2 years ago but VCDS at that time was unable to active it and the only solution was the (expensive) Kafatec kit, I then successfully forgot all about it.
Just activated the tap function for both the button and remote and they work perfectly. :beer:
I have added the guide to the VCDS Adaptations. How do I ……
  • 4 months later...
Looking at various site VCDS are not cheap to purchase. Circa £230 -ouch.
Are there any VCDS owners in the Aberdeen area that I could meet, and activate this function for my boot? ...alternatively I will be moving to Oxfordshire later in the year so I could meet someone in that area from December.
Please PM me if you can help.
Thanks.
Gents
Thanks for your advice so far.
I'm hoping to meet up with someone on Sunday to add this function to my boot lid.
Having read the superb combi vehicle manual, I can't see where the VCDS socket is located. I take it is located somewhere in the glovebox or passenger or driver's footwell?
Paul
Edited by pmk76
The diagnostic socket is in the driver's footwell near the door.  It's just forward of that little storage compartment outboard of the steering wheel.
Thanks Wokwon.
A question...a visit to my local VCDS owner didn't make this happen;
Went into 6D, Security access, balloon tip said "12345". Entered it, said "Accepted"
Back into coding, Activate right setting, Do it => "Error Security code"
Anyone?
There is a time limit for the security access code, it’s only something like a minute or two so you need to be quick.
This worked on my MY11 Suberb combi. Many thanks to all, especially Darius for his help and VCDS.
Anyone?
A follow up on this one, anything security-code related needs to be accessed with a genuine Rosstech cable and genuine software. My local VCDS guy was running a beta version software and that's the reason why it didn't work. He re-installed his official version and now it works great!
  • 7 months later...
Hello!
Is this option maybe available for the hatch version too ?
:ph34r:
No, AIUI only the combi (estate) have been available with the electric option.
This worked great. Thanks
  • 1 year later...
You will need:
4. Success!
Notes:
Any idea how to do it for new SuperbIII ?? Thanks.
Not currently available yet.
  • 6 months later...
OK. This was managed today with Vag Can Pro team.
Works forme fine. Here is the video:
  • 5 months later...
Anyone got the code for programming internal button for closing hatch on superb MKIII?
To Enriquez:
Would be possible to share the procedure how to enable the rear tailgate closing from inside please. I have tried on my Superb MKIII today but no luck.
Many thanks
  • 4 weeks later...
On 16/02/2017 at 19:46, tdipd said:
To Enriquez:
Many thanks
You need VCP
The file is not shareable as it is specific to the dongle used to download it.
https://onedrive.live.com/view.aspx?resid=3AE6945C79E4C9E!6636&ithint=onenote%2C&app=OneNote&authkey=!ADQH2YqqqP0zcUU
"With VCP it is possible to change the data record of the tailgate control unit so that you can then close the tailgate also by means of the button in the centre console as well as via the remote control.
The data record can be downloaded from the VCP file manager with a valid maintenance period and uploaded to the control unit 6D.
As with all other files from the File Manager, the files can only be used with the VCP dongle with which the file was downloaded. Thus, it is not possible to send the file to another VCP user!”
So just to be clear, this is NOT a case of simply ticking a bit in the coding or an adaptation change, you are installing a new file onto the controller...
Thanks a lot for advice. I had a bit of time yesterday to test it and is working somehow. The issue I have is that the tailgate is working but after some time it has issue to close (pressing the button inside or on the tailgate doesn't work). Problem is most probably on my side because I'm not familiar with VCP and there are several files which could be uploaded but have no clue which one is the right one. I can find the right folder according to the unit number but not assign the right file. Could you help please?
Many thanks
PS: Superb is limousine MY2016
What channel to select?
Found it. The pictures were nor loading.
Thanks anyway. :)
  • 4 months later...
You will need:
4. Success!
Notes:
I haven't got there images. Can you send me link for it?
