Tyre Pressure Monitoring fault
Hi All, 2017 150 diesel 4x4 DSG, with about 70,000 miles on it.
Repeated tyre pressure warning, but a gauge confirms the pressures are all correct?
Any thoughts, please?
Are the pressures all correct if you stop as soon as you can when the warning shows. In a safe place. Check when hot that there is no sticking brake caliper or bearing going and the hub, wheel heating and a tyre expanding. The warnings are not always a loss of pressure / circumference.
Thanks. Good thought, but I set them all to 2.5 Bar cold, zeroed the pressure monitor, drove it round the block, and parked it up overnight. Next morning, as soon as I started the engine, I got the bong of doom and the light. Stopped the engine, hopped out, and tried all the tyre pressures again. All still at 2.5 Bar.☹️
Repeat.But, With a longer drive.
Wife's taken it to Carlisle this evening (about 40 miles away. The light came on again. She re-set it when she got there and she's on her way home now. I'll report back!
Could be a failing bearing/ABS sensor/ABS ring or wiring. From memory the car uses info from ABS sensor to work out if a tyre is flat. Maybe worth getting it scanned in case a fault code is stored or if faulty which wheel/wheel sensor it is
Alasdair
It uses the sensor to see if the circumference / rotations changes up as well as down. So not just loss of pressure since being set. An increase can trigger the TPMS. And all tyres losing pressure might not trigger the TPMS.
Thanks both.
Re. the longer run, it came on when the wife was driving to Carlisle. She re-set it when she was there, and then it did NOT come back on on her trip home.
Re. getting it scanned, I have OBDeleven, so I'll try that at the weekend and see what it says.
Have a good check of the tyres. My old Seat altea warning used to come on due to a tyre being slightly out of round. I kept resetting and checking but didnt notice tyre at first an assumed it was a sensor but after a few weeks car developed a wobble you felt through seat and one was slightly deformed. I jacked each wheel up and lowered onto a flat board with tyre just touching then spun wheels and found one was about 1cm out of round with a weird twist in it. Expensive day as the tyre service pointed out the age of tyres and said I needed all four as if one had gone the chances are the others may follow. I trust the tyre place. They are decent and have been using them for at least 40 years.
Alasdair
Hi All, Just a quick update. OBDeleven gave two fault codes:
C102D00 and C1146F0
Do either of those mean anything to anyone, please?
Hi,
A quick search on ross-tech.com forum gives following possible issues:
  • VCDS coding modifications on ABS module
  • Wheel speed sensor calibration issue
Otherwise, each time you've adjusted tyre pressure, did you reset the TPMS on the MMI? It may sounds stupid, but better start getting rid of very simple and costless things.
Thanks Bap.
Yes, TPMS reset. Given that the error message isn't the same each time, it's either "right hand front tyre" or "TMPS fault", I'm leaning towards the right hand front wheel sensor. It also says "unable to store values" (or something like that) on some occasions when I try to reset the TPMS, it also points to a fault. I'm certainly not brave enough to try any VCDS coding, so it's not that! It does have an aftermarket towbar with dedicated electrics (not installed by me), but it's had that for several years and it hasn't been a problem.
I'll leave it a bit longer and see if the right hand front tyre message is consistent every time. I think there's a way of using OBDeleven to monitor live data? I might try and go for a drive to see if it can display the data from the 4 wheel sensors?
So the car is the best part of 9 years old. Have you completely discounted the possibility that the TPMS sensor is failing/faulty, possibly due to a weak lithium battery inside the sensor ? These batteries have a typical lifespan of 5 - 10 years. If the sensor is at fault you would be well advised to replace all four sensors for obvious reasons.
Op has not said whether vehicle has direct or indirect TPMS - more likely to be indirect, as direct type is usually a cost option.
If indirect type, there aren't any sensor batteries as the TPMS data comes from the ABS wheel sensors.
I agree with warrior its probably indirect so reckon failing abs sensor/bearing or perhaps wiring. I assume any break in signal from sensor would confuse system and put low pressure warning on. My old Seat used to randomly warn me but tyres were fine. Cause was a failing bearing and sensor.
Alasdair
Thanks all. Yes, it's indirect. The only thing that makes me hesitate to swap the ABS sensor, is that I'm not getting an ABS or ESC warning. One thing that might be worth me adding, is that over the winter, we had the winter tyres on, and there IS a very slow puncture in the right hand front tyre, so it was setting off the warning (quite legitimately) every few weeks. It still says the right hand front tyre is low, even now, that we have the summer tyres on, (and there's no loss of pressure), but it also alternates that with "TPMS fault".
C102D00 and C1146F0
my skoda have the same problem. can you tell me how to fix it? thanks
Clear codes and If all your tyres are correct pressure reset TPMS and if they return it points to a failing ABS sensor or dirt between sensor and ring or damaged wiring etc. With VCDS I believe its possible to track down the exact wheel sensor thats causing problem. Not sure with OBDeleven. Daughter has same on her Volvo due to failing wheel bearing but its puting up ABS warning as well.
Alasdair
I wish I could, but I haven't managed to fix it yet! To be honest, I haven't tried. It's a low priority job, and trying to patch-up my son's 25 year old Freelander is at the top of the queue at present. I'd change the ABS sensor on the front right wheel, but what's making me hesitate, is the fact that there are no ABS faults showing.
Alasdair
Yes, OBDeleven does that. You can also set it to display "live data" and go for a drive. It's definitely the right hand front ABS sensor that is giving the inconsistent readings.
If its failing or dirty/damaged wiring and giving a slightly sporadic signal it can cause tyre pressure warning as car thinks a tyre is slightly soft but not drastic enough to trigger ABS light.
Alasdair
Thanks. I'm certainly hoping that's the case, but surprised that a poor signal would trigger a tyre pressure warning fault, yet not trigger an ABS warning fault? (The latter being more safety critical). I was wondering whether perhaps to trigger a tyre pressure warning it needs much less of a difference in wheel rotational speed than for an ABS intervention? I'm just guessing though!
Think your guess is correct. Read this on a vw transporter forum
Why there is no ABS light
The ABS and TPMS computers have different sensitivity thresholds. A tyre pressure fault can be triggered if a sensor briefly misses a few pulses or detects a minor rotational difference. However, the main ABS system requires a more severe, continuous malfunction before it triggers an active ABS dashboard warning.
I would change sensor or remove and clean it and check wiring to it as there not that expensive although I would assume if it was a wiring fault the ABS light would kick in too. If that doesnt cure it it may be a failing bearing or failing/dirty magnetic ring in bearing.
Alasdair
Alasdair
That's very interesting indeed, thanks! I might risk another sensor then. As you say, they're not silly money - even genuine ones!
Last couple I fitted were febi ones as I had to replace bearings and destroyed sensor when removing as they were seized in. They were around £12 each and no problems so far Give it a few days of penetrating oil before trying to remove.
Alasdair
