Both Bottom Front Bottom Lights Have Condensation.
Recommended Posts
MidlifecrisisT,
 Different set up on a Monte Carlo compared to a vRS.
You should not have that with your type of Sidelight / DRL units on a vRS.
I take it you have your DRL's deactivated, (Switched off) so that they are not always on when the car is running,
(& only work as sidelights when you switch them on.)
but really even then they should not have condensation in them.
Edited by goneoffSKi
Link to comment
Share on other sites
MidlifecrisisT,
Arent they leds on a vrs?
Having then on or off wouldnt make much difference to drying them out as leds run cool and dont emit much heat.
  • Like 1
Link to comment
Hi George
Mine are always on. Not deactivated them but it has crossed my mind.
I've noticed what appears to be condensation a few times now (only on Drl's) not main headlights, But has cleared up after a good run. Maybe a have a gap/crack somewhere then! More money then if they need to be replaced haha.
Link to comment
Hi George
Not just you, mine do this as well. I was under the impression it's normal (as per the instruction manual).
Edited by Gumby
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
