• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
octavia fuses / fusebox
Sign in to follow this
Followers 0
16 posts in this topic
hi, ive been sent here from somewhere else.
anyway,
basically ive got one with an electrical leak. some bright spark (maybe me, maybe not) pulled out all the fuses.
anyway the diagrame in the book is lhd and nothing like the actual box.
we can i get the right diagram?
[U][B]the skoda diagram[/B][/U]
[IMG]http://i28.photobucket.com/albums/c220/dave364634/Image135-1.jpg[/IMG]
[U][B]the actual box[/B][/U]
[IMG]http://i28.photobucket.com/albums/c220/dave364634/Image133.jpg[/IMG]
[U][B]my diagram[/B][/U]
[IMG]http://i28.photobucket.com/albums/c220/dave364634/Image134.jpg[/IMG]
[U][B]engine cover[/B][/U]
[IMG]http://i28.photobucket.com/albums/c220/dave364634/Image136.jpg[/IMG]
top left to right:
in the skoda diagrame numbers go
[code] 8
5 9
1 3 6 10
2 4 7 11 etc[/code]
where as the numbers on the actual car go
[code]20 16 12
21 17 13
22 18 14
23 19 15 etc[/code]
also the numbers in the bottom section run differently.
ive been sent the link
[URL]http://www.briskoda.net/forums/octavia-i/fuse-box-layout/88051/[/URL]
but none of the numbers on the car fusebox match up with the numbers in the book. i realise there 'mirrored from lhd to rhd, but none of the number functions add up (ie the wipers are 24 and not 21, or that full beam is 18 and 19, not 15 and 16).
help!!!!!
if anyone cares ive been sent from
[URL="http://www.talkaudio.co.uk/vbb/showthread.php?t=240550"]octavia fuses - Talk Audio Forums[/URL]
cheers. :thumbup:
Share this post
Link to post
Share on other sites
anyone?
ive been sent
[IMG]http://www.yournav.com/forum/uploads/post-7293-1170281125.jpg[/IMG]
but the problem with the above is, that if you look at the top left on your photo where the 2x 15amp fuses are, they do the dip/low beam. if you look in the book (#17 and 18) they should be 10amps.
:confused: :confused: :confused: :confused:
Share this post
Link to post
What are you trying to do?, put the fuses back in your fusebox, except that you don't know which power fuse to put where?
Headlamp dipped beam is typically 55 Watt which will need a current of around 5 Amps continuously, if both were on the same circuit then the fuse would have to take 10 amps continuously, so for a single dipped beam use a 10 A fuse and for two running through the same fuse use a 15 Amp. The same applies to the main beam circuit. If you divide the watts by the voltage (typically 12 in a car) you will get the current Amps that is required.
Share this post
Link to post
The diagram is a mirror image, just reverse it.
Do xenon headlights have 15A fuses instead of 10A?
Or maybe whoever sent you the photo had uprated the headlight bulbs, blew the fuses so uprated them - a common thing a lot of people do. :rolleyes:
In any case just reverse the diagram and fit them back in that order, it is confusing though, how hard would it be for VAG to produce a LHD & RHD book?? :eek:
Share this post
Link to post
Why, unless there's a striking load (like older household flourescents), would Xenons need higher wattage fuses, since they only draw about half the current?
Share this post
Link to post
Thats why I'm asking, i know xenon only have a 35W 'bulb' compared to a 55W halogen, but they first have to power the ballast then they have to arc the lamp itself.
I seem to remember (on here i think?) somebody kept popping the 10A fuse after they had retro fitted xenons.
(mine run fine on the std 10A fuse though)
Share this post
Link to post
Is this what you are looking for?
[img]http://homepage.ntlworld.com/denis.werb/Fuses.jpg[/img]
Share this post
Link to post
does anyone know which is the fuse for the airbag light on the dashboard?i don't know for the skoda but i'm sure that for the VW is the number 15 5Amp light brown,is it the same for a skoda octavia TDI '00?many thanks
Share this post
Link to post
The airbag light is a LED, it draws a very low current and would not need a fuse. What's the problem with it?
Share this post
Link to post
well the led is on,something wrong with the airbag i didn't mean the fuse for the led but for the airbag sistem.should be somewhere?i'm been to the garage be4 and it's been reset but after 50 miles it was on again sorry but i don't throw £25 everytime i pop in the garage and waste my time........i know also that i don't have an error code if i use the vga.com...what should i do cut off the led and good bye?
Share this post
Link to post
Hi there - on the subject of fuses, I'm wondering whether the cd changer in the boot is fused, if so which one - its mysteriously stopped working and doesn't appear damaged - fuse????
Thank you, burto
Share this post
Link to post
Got a message on the head unit Burto? If so, and it's either "Surface" or "Mechanic", remove the magazine, count to ten, refit it, and leave the car for a bit usually works.
Share this post
Link to post
Hi
I managed to get a clear fuse box diagram with the numbers for all to see.
Hope this helps.
Share this post
Link to post
SO was it fuse 42? The radio works fine, just the CD player is dead?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
