ExAudiSi
Members-
Posts
1,495 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by ExAudiSi
We currently have a Polo GTI hire car while waiting for SWMBOs TT to go in to the bodyshop. It has Bridgestones on too and they completely ruin the car. The engine is very quite on the move and all you can hear is tyre noise. It's so bad that you can't hear the stereo, mind you that isn't particularly good quality either.
Thanks for both of your replies. Somehow I manage over 12k miles per year, not sure how I do that though! The school run is generally a straight run there and back with no stationary traffic. Neither of the two diesels that I've had have gone into limp mode with this type of usage, can be a bit chilly though as the A6 just manages to get up to temperature as I'm coming into the drive in this weather. The A6 averages about 35mpg and we also have a Mk1 Audi TT and this averages about 29mpg on the mostly the same types of journeys. These are calculated from brim to brim fills over 12 months.
I am planning on changing my Audi A6 2.7TDI Avant shortly for an Octavia vRS. I've driven a TDI estate belonging to a friend (thanks Jon ), but most of my journeys are pretty short, (school run and weekly shop), probably about 10-15 miles and I always have a nagging doubt in the back of my mind about the DPF blocking up. I had a CC 2.0 TDI before the A6 and it seemed to do a regen quite often, although I have never actually noticed this on doing it. So the question is, what mpg can be achieved in the real world driving a vRS TSI? Is 35mpg achievable this type of usage? I would be looking for a car with sat nav, heated leather and cruise control. I think that the 230 version is just about in my price range, is any of that kit standard on those, or are they the same spec as the 220? Also, is the 230 worth looking for or should I just look for a TSI?
wipers not switching off problem solved
ExAudiSi replied to benterrier's topic in Skoda Octavia Mk I (1996-2004)
Glad my old post helped you. The rear wiper motor probably has screenwash inside it. It's a pretty common issue unfortunately, but easily fixed with a replacement motor. Stripping and cleaning the old one may work for a while, but I replaced mine with new and the problem never came back while I owned the car. -
You've lost me now???
Thanks for that I've only seen translations like that for Geordie until now I never used to change sump plugs either, until relatively recent VAG group cars (Mk1 A3 onwards) where the sealing washer only comes with the plug.
Probably a silly question, but have you been to your local dealer or TPS? I don't remember them being massively expensive and at least they should be able to supply the right one.
Spotting an BBZ vs AUB from an advert
ExAudiSi replied to isambard's topic in Skoda Fabia Mk I (1999-2007)
My Mum has a low mileage BBZ engined 1.4 16v Fabia. I think it she is probably its second elderly owner and it drinks oil like its going out of fashion. It now also blows out blue smoke on start up if its been stood for a while. Normally I would assume valve stem oil seals would cause this, but because its only done 39,000 miles I'm also wondering if the oil separator on the back of the block needs cleaning out/replacing. -
Replace oem xenon ballast with universal
ExAudiSi replied to TrondOstli's topic in Skoda Octavia Mk I (1996-2004)
Number 9 is not just the leveling control unit, it is also the ballast for the xenon lamp. Number 8 is the igniter. -
It may depend on which side has failed as I think that the passenger side also controls the self leveling. -
The wire that energises the magnetic clutch rubbed through and broke close to the back of the compressor. Once the garage found the cable and spliced it back together all was well.
Just replace the fob part with the buttons (assuming that you key is the flip type). The part of the key with the blade also has the transponder for the immobiliser and doesn't appear to have been affected as it will still start the car. The fob part with the buttons can be recoded without a trip to the dealers.
Saltburn is by the sea, but that looks like its been in it!
I've bought some pattern wishbones once before, can't remember the make though, with the intention of fitting TT bushes to them. I took the rear arm bushes out and the hole was a fraction larger than in a genuine wishbone meaning that the new TT bushes were not as tight as they needed to be and slid in and out of the hole on the car when in use. I then bought replacement bushes and then refurbished my old wishbones. Pattern wishbones are probably OK as they are, with their own bushes, but not necessarily for upgrading with bushes meant for OEM.
Wheel Nut Caps - what size 17mm or 19mm
ExAudiSi replied to octtyvrs82's topic in Skoda Octavia Mk II (2004 - 2013)
Before you dash off and buy some from eBay, check out the price from the Stealers/TPS. I nearly bought some from eBay for my A6 at £20 for the full set, but checked out the price at TPS first and got the full set for less than a tenner!! -
age old question about seats
ExAudiSi replied to xantiaman's topic in Skoda Octavia Mk I (1996-2004)
...and Mk1 A3 and Mk1 Seat Leon. -
Assuming it is the same as other VAG headlight switches, turn lights off. Push in and turn toward sidelight position. This should release the retaining clips and allow you to withdraw the switch.
Bilstein b4 dampers? Which ones?
ExAudiSi replied to WoodieGuthrie's topic in Skoda Octavia Mk I (1996-2004)
I ran B4s on my Elegance TDI with vRS springs, so I went for the sport suspension type and they worked pretty well together. If you fit lowering springs, don't for get to get shorter bump stops too. I used vRS ones. The difference in wheelbase between normal models and the vRS is probably down to the lowered ride height altering the angle of the trailing arms on the rear suspension. -
Did the replacement stat fix the problem? My mate has just bought a Seat Leon Cupra and got the EML on and the same fault code as this. Replaced the CTS with a genuine one, and cleared the code, but it keeps coming back and the gauge shows cold most of the time. He's got it booked in for the cam belt, water pump and thermostat in the next week or so, but just wondering if the new stat will fix the problem.
As its a TDI, this could be down the the vacuum pump as the servo doesn't use manifold vacuum to provide assistance.
Interior lights flickering on and off
ExAudiSi replied to sesachc's topic in Skoda Octavia Mk I (1996-2004)
Dodgy resistor on the panel light dimmer perhaps? -
I have a 2008 CC TDi 140 with the panoramic sunroof and don't find the seat too high, or the mirror in the way. I am 6'2" and I would assume that the roof would reduce the head room somewhat. Not had any problems with the boot wiring (yet). Had the parking brake switch replaced under warranty and had to have the AC compressor replaced as that failed this summer (another common issue across the VAG range apparently). I find it a great car to drive long distances in and it is the quietest car I've owned.
Now that I have read the instructions its a bottle opener/mobile phone stand :clap:
I got one of those multi tool things too! Didn't spot it had the stylus and screwdriver inside. Thought it was just a pen, ruler and bottle opener Hadn't realised that the bottle opener is actually a phone holder. Suppose I should have read the instructions!
