langers2k
  1. If you can make it to Norfolk, I'm happy to take a look. Just drop me a PM and we can sort something out 🙂 I've tweaked my door eeproms to always use the puddle light and I think they unfold when I open the door rather than on unlock if I remember correctly. I don't think on unlock can be done with this generation of car.
  2. Nope... On the pre-fl MK2 the drl and fog lamp bulbs are next to each other and share an enclosure so it could be that you're thinking of?
  3. That'll be a BCM or body control module. Generally, the following is correct but it may depend on what equipment is fitted. A - 52-pin connector, (black) T52aa: 1 T52aa/1 - Input - terminal 30 2 T52aa/2 - not assigned 3 T52aa/3 - not assigned 4 T52aa/4 - Output for heated washer nozzles 5 T52aa/5 - Output for main beam bulb, left 6 T52aa/6 - Output for tail and rear fog light bulb, right 7 T52aa/7 - not assigned 8 T52aa/8 - not assigned 9 T52aa/9 - Output for turn signal bulb, rear right 10 T52aa/10 - Output for turn signal bulb, front left 11 T52aa/11 - Output for dipped beam bulb, left - Output for gas discharge lamp, left 12 T52aa/12 - not assigned 13 T52aa/13 - Input of rear lid handle release button 14 T52aa/14 - Input of bonnet contact switch 15 T52aa/15 - not assigned 16 T52aa/16 - Input of reversing light switch (not valid for vehicles with automatic gearbox) 17 T52aa/17 - Input of rear fog light switch 18 T52aa/18 - Input of light switch - terminal TFL 19 T52aa/19 - Input of light switch - terminal 58 20 T52aa/20 - Input of light switch - terminal AFL (only for vehicles with automatic driving lights activation) 21 T52aa/21 - Input of fog light switch 22 T52aa/22 - Input of light switch - terminal 56 23 T52aa/23 - Input - terminal 31 24 T52aa/24 - Input - terminal 30 25 T52aa/25 - Output for fog light bulb, left 26 T52aa/26 - Output for tail and brake light bulb, right 27 T52aa/27 - Output for tail light bulb, left 28 T52aa/28 - Output for reversing light bulb, left 29 T52aa/29 - Input of central locking switch, in rear hinged lock - terminal 31 30 T52aa/30 - Input of door contact switch - rear right 31 T52aa/31 - not assigned 32 T52aa/32 - not assigned 33 T52aa/33 - not assigned 34 T52aa/34 - not assigned 35 T52aa/35 - Input of heated rear window button (only on vehicles with heating) 36 T52aa/36 - Input of deactivation button of interior monitoring and vehicle inclination 37 T52aa/37 - not assigned 38 T52aa/38 - Input of central locking lock unit, rear left 39 T52aa/39 - not assigned 40 T52aa/40 - Input of central locking lock unit, rear right 41 T52aa/41 - Input of door contact switch - rear left 42 T52aa/42 - Input - terminal 31 - for central locking 43 T52aa/43 - Output for rear window wiper motor and windscreen and rear window washer pump 44 T52aa/44 - Output for side light bulb, right 45 T52aa/45 - Output for high level brake light bulbs 46 T52aa/46 - Output for tank filler flap locking motor 47 T52aa/47 - not assigned 48 T52aa/48 - Output for central locking lock unit, rear left 49 T52aa/49 - Output for central locking motor, rear right 50 T52aa/50 - not assigned 51 T52aa/51 - not assigned 52 T52aa/52 - not assigned B - 52-pin connector, (white) T52ab: 1 T52ab/1 - Input - terminal 30 - for central locking 2 T52ab/2 - Output for rear window wiper motor and windscreen and rear window washer pump 3 T52ab/3 - not assigned 4 T52ab/4 - not assigned 5 T52ab/5 - Output for tank filler flap locking motor 6 T52ab/6 - not assigned 7 T52ab/7 - Output for central locking motor, rear left 8 T52ab/8 - Output for central locking lock unit, rear right 9 T52ab/9 - not assigned 10 T52ab/10 - not assigned 11 T52ab/11 - Output for central locking motor - rear lid 12 T52ab/12 - Output for terminal 15 voltage supply relay 13 T52ab/13 - not assigned 14 T52ab/14 - Output for heated rear window warning lamp (only on vehicles with heating) 15 T52ab/15 - Output for illumination regulator - switches and instruments - terminal 58 16 T52ab/16 - Output for sliding sunroof adjustment control unit (authorisation) 17 T52ab/17 - Output for sliding sunroof adjustment control unit (activation) 18 T52ab/18 - not assigned 19 T52ab/19 - not assigned 20 T52ab/20 - not assigned 21 T52ab/21 - Output for heated front and rear seat control unit 22 T52ab/22 - Output for heated rear window relay 23 T52ab/23 - not assigned 24 T52ab/24 - Output for hazard warning light system warning lamp 25 T52ab/25 - not assigned 26 T52ab/26 - Output for central locking motor (SAFE) rear left 27 T52ab/27 - Output for central locking motor (SAFE) rear right 28 T52ab/28 - Output for X contact relief relay 29 T52ab/29 - Output for voltage supply relay, terminal 50 (without start/stop system) 30 T52ab/30 - Output for illumination regulator - switches and instruments - terminal 31 31 T52ab/31 - not assigned 32 T52ab/32 - not assigned 33 T52ab/33 - LIN bus - windscreen wiper motor driver's side, rain and light detector sensor 34 T52ab/34 - not assigned 35 T52ab/35 - not assigned 36 T52ab/36 - LIN bus - anti-theft alarm system 37 T52ab/37 - Output for deactivation warning lamp of interior monitoring and vehicle inclination 38 T52ab/38 - Output for fuel supply relay (for petrol engines) - Output for fuel pump control unit (for petrol engines) - Output for fuel pump relay for additional heater (for diesel engines) 39 T52ab/39 - not assigned 40 T52ab/40 - Output for headlight washer system relay 41 T52ab/41 - Output for horn relay 42 T52ab/42 - Input for interior light - terminal 30 43 T52ab/43 - Output for interior light - terminal 30al 44 T52ab/44 - not assigned 45 T52ab/45 - not assigned 46 T52ab/46 - not assigned 47 T52ab/47 - not assigned 48 T52ab/48 - not assigned 49 T52ab/49 - not assigned 50 T52ab/50 - not assigned 51 T52ab/51 - Output - terminal 58d 52 T52ab/52 - Input - terminal 31 C - 52-pin connector, (brown) T52ac: 1 T52ac/1 - not assigned 2 T52ac/2 - not assigned 3 T52ac/3 - Output for tail light bulb, right 4 T52ac/4 - Output for tail and brake light bulb, left 5 T52ac/5 - Input - terminal 31 6 T52ac/6 - not assigned 7 T52ac/7 - Input of hazard warning lights button 8 T52ac/8 - not assigned 9 T52ac/9 - not assigned 10 T52ac/10 - Output for interior light (31, interior light/door contact switch) 11 T52ac/11 - not assigned 12 T52ac/12 - not assigned 13 T52ac/13 - Input of steering column electronics control unit - terminal 15 14 T52ac/14 - Input of steering column electronics control unit - terminal 50 (without start/stop system) - Input of steering column electronics control unit - terminal 15 (for start/stop system) 15 T52ac/15 - CAN H, convenience 16 T52ac/16 - CAN L, convenience 17 T52ac/17 - Input of brake light switch 18 T52ac/18 - not assigned 19 T52ac/19 - not assigned 20 T52ac/20 - not assigned 21 T52ac/21 - not assigned 22 T52ac/22 - not assigned 23 T52ac/23 - not assigned 24 T52ac/24 - not assigned 25 T52ac/25 - Output for fog light bulb, right 26 T52ac/26 - Output for side light bulb, left 27 T52ac/27 - Output for number plate light 28 T52ac/28 - Output for reversing light bulb, right 29 T52ac/29 - not assigned 30 T52ac/30 - Input of clutch position sender (not valid for vehicles with automatic gearbox) (without start/stop system) - Input - terminal 31 (for start/stop system) - Input of multi-function switch (on vehicles with automatic gearbox 09G) - Input of direct shift gearbox mechatronics (on vehicles with automatic DSG gearbox - 02E, DSG - 0AM) 31 T52ac/31 - Input of steering column electronics control unit - terminal 15 32 T52ac/32 - Input of alternator - terminal L (without start/stop system) 33 T52ac/33 - not assigned 34 T52ac/34 - Input of voltage supply relay, terminal 50 (without start/stop system) - Input of starter relay 2 (for start/stop system) 35 T52ac/35 - Input of illumination regulator - switches and instruments - terminal 58s 36 T52ac/36 - not assigned 37 T52ac/37 - not assigned 38 T52ac/38 - not assigned 39 T52ac/39 - not assigned 40 T52ac/40 - not assigned 41 T52ac/41 - not assigned 42 T52ac/42 - Input - terminal 30 43 T52ac/43 - not assigned 44 T52ac/44 - not assigned 45 T52ac/45 - not assigned 46 T52ac/46 - Output for main beam bulb, right 47 T52ac/47 - Output for tail and rear fog light bulb, left 48 T52ac/48 - Output for day driving light bulb, left 49 T52ac/49 - Output for day driving light bulb, right 50 T52ac/50 - Output for turn signal bulb, front right 51 T52ac/51 - Output for turn signal bulb, rear left 52 T52ac/52 - Output for dipped beam bulb, right - Output for gas discharge lamp, right
  4. Yes, if I remember correct there is space for two standard rectangular microphones in the light done. There might be a plastic foam there but it just pulls out. What are you trying to do?
  5. Nope, but I think there is space for two if I remember correctly. I think the idea is just to fit one closest to the driver.
  6. Certainly looks like the ECU is out to lunch. Given the other modules (ie: abs) on the drive canbus are present, that suggests the can gateway and its wiring are good. I'd be verifying the power(s), ground(s) and both can high and low wires are happy. First with a multimeter to confirm continuity and then ideally load test too. If that checks out, it points to the ECU being dead. I've just arrived in Kos for a week so I can't check any wiring diagrams to suggest which pins to look at. Makes me wonder if there are some permanent and switched lives, but just one is sad stopping the ECU turning on?
  7. That's very unlikely to be plug and play. Looking in the manual, it has a kenwood specific connector on the rear and includes a lead for standard ISO connectors. A MK2 Octavia will use a quadlock so you'll need an adaptor to convert between quadlock and ISO. You'll also need to run an extra wire as there is no switched ignition feed, the easiest thing is to run a wire to the fusebox and use a piggyback fuse from a switched ignition feed. If you don't, the radio won't turn on and off with the key. I have no idea if it can display parking sensors but the beeps should work regardless of which headunit you have. Finally, you'll also need some kind of facia adaptor as that's a rectangular headunit and the original Skoda headunits aren't
  8. The OP has a MK2 1Z Octavia whereas that video is for a MK1 1U which is why the suspension is different The OP distance doesn't seem to different to this video: When I did this I also used spring compressors to take most tension. My car was also higher as I needed access to remove the seized concentric bolts and suspension arms which made it easier to get a jack and block of wood under the spring mount during reassembly. There is always a risk the spring can fly out but if it's properly seated, it should be OK... Just be mindful of where your fingers are compared to the spring!
  9. Check if there are wires to pins 14 and 15 on the connector. Not sure about colours I'm afraid.
  10. It's also memory as in different positions per key and even different dip amounts per key. I believe you just adjust them and it should remember the position for next time that key is used Non-memory mirrors have no positional feedback so can't do per key positioning and just dip a set amount.
  11. Your son-on-laws VCDS is out of date so you should update and it's not an autoscan Your issue is: Until you can restore communications, you won't get the headlights working properly. You want it see both submodules, like this example: Only then will you be able recode and perform the basic settings. This generation of Superb is known to suffer water ingress so I'd suggest removing the left headlight then checking the control module on it's underside. Make sure the pins are clean and corrosion free. Hopefully that'll restore comms and let you fix this I think the official method is to remove the bumper but if you or your son-on-law are adventurous, it might be possible to get to the module from underneath with the bumper still fitted...
  12. Start VCDS, press autoscan, press start then wait... Then hit copy and use CTRL+V (or right click, the paste) to insert the data in to a forum post: Otherwise, you can hit save to create a new file (make a note of where it saves to!!). Then attach the file to a post by either dragging the file or selecting "choose file" to find the file you saved
  13. When you spec memory seats, you also get a different motor to move the mirrors (extra 4 wires for position) and highline door controllers (to support the extra wires). It's the memory motors and highline door controllers that make this possible, not the memory seats Below is an example of someone retrofitting the passenger side memory mirror to a MK3 Octavia .Obviously you'd need to do both sides and use Karoq appropriate part numbers but the process is the same...
  14. Can you post a full autoscan from VCDS to give us some ideas what you're dealing with?
  15. It's because the windows motor thinks there's an obstruction so stops and backs off... You need to find out what's causing the extra drag so it no longer trips the anti-trap function
  16. Nope... I can't see how an MOT or tyre change could cause the symptoms you've described. An MOT really shouldn't damage anything. Obviously if something is about to fail, for example a brake hose, it could fail during the MOT but that's not really their fault. I guess ABS wiring/sensors can get damaged during tyre changes but that wouldn't explain your issues and is pretty unlikely unless they are super hamfisted.
  17. Sounds like the CAN-bus gateway might be having issues or something lost it's coding/stopped communicating... You need to get VCDS or similar attached to see what's going on. A local member might be able to do an autoscan for you which will help us make more informed guesses.
  18. Something is probably causing excess friction and triggering the anti-trap function so it doesn't chop off fingers... The plastic gears inside the window motor can wear otherwise, there might be something in the window channels. My Octavia's drivers window does it occationally in hot weather...
  19. Check the fuses in the engine bay fusebox. The lighting one will probably have a micro fracture or have over heated causing oxidation 🙂
  20. The indirect TPMS on a Yeti uses the rotation data from the ABS sensors, there are no actual pressures sesnors in the wheels. You just need to check/adjust the tyre pressues and hit the TPMS reset button.
  21. If both the alloy and steel wheels are from Skoda, they should use the same bolts If the are aftermarket, you should check what bolt they need.
  22. Might be worth checking the brakes have been serviced (fresh fluid, caliper seals/slides in good condition, decent pads/discs) before looking to upgrade them. Kenwood made a couple of VW/Skoda specific headunits: - https://www.kenwood.eu/car/navigation_multimedia/navigation/DNX521DAB - https://kenwood-electronics.co.uk/car/oem/vw/DNX525DAB/ Otherwise, the headunit out of a 2015+ Yeti is a good OEM option https://www.briskoda.net/forums/topic/409691-amundsen-mib-std2-infotainment-system-with-android-in-superb-ii/ Mostly depends on your budget
  23. You'll need to compare the two wiring diagrams and see how much of the original wiring is useful. A quick flick through suggests you should be able to reuse power, ground, CAN-bus and the level sensor wires. You might need to make a couple of wiring looms for the headlights as the pre-FL looks to have 8 wires (4 to each headlight) for range control rather than 2 wires in the FL (CAN-bus).
  24. A multimeter will tell you which are ignition switched pretty quickly Otherwise, you can get the wiring diagrams here: https://erwin.skoda-auto.cz/erwin/showHome.do
  25. I believe it's the CAN gateway not sending a signal to the headunit to tell it to enter full standby. Instead it sits there booted ready to go :) The newer gateways send the extra message to make sure the newer headuntis fullyenter standby.
