wharferat
FREEDOM-
Posts
79 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by wharferat
Unfortunately for you, a recommendation to change the cambelt at 5 years or 145,000 miles is not a guarantee that it will last that long. I agree that it is reasonable to expect that it will, & many people will have exceeded those figures, but as in your case, there are also cases where, for whatever reason, a failure occurs before reaching those recommendations.
Dennis Horton & Son Ltd - Lincoln..
wharferat replied to DGW's topic in Skoda Dealers - East Midlands
One of their technicians, J***, could do with some training on customer interaction. I don't know if he is basically rude to all customers, or just women. Over the past year my wife has been in a couple of times with a problem on her car & his reaction is to virtually accuse her of doing something to cause the problem. Whether she has or hasn't been responsible (& she wasn't), that is no way for a customer to be treated. -
Ditto for me, but if you look at the line above it says ECE AS 2022
Windscreen wipers intermittent operation even when switched off.
wharferat replied to wharferat's topic in Skoda Karoq
Interesting link, Berisford, & probably the same dealer. As I said in the opening post, the Intermittent was disabled by the service department when the car first went in for investigation, not in the infotainment system, but I assume with VCDS. It certainly didn't have Automatic/Intermittent wipers when my wife wanted them the other day. -
Has anyone else had a problem with their windscreen wipers wiping intermittently even when they are switched off? My wife's Karoq has been doing this for a month now. At first it was happening after turning right, but more recently it has happened at random times. Even after isolation of the intermittent by the dealer it has still happened at random times. After 2 visits to to the dealer, the first for only an hour 2 weeks ago so they could put her car on the diagnostics computer, nothing found, but intermittent operation isolated at that time, & another today where they have had the car all day & supposedly 20 miles of driving & it did not obligingly spring into life when least expected, the dealer says they can't do anything, & they wouldn't escalate it to Skoda UK, my wife has called Skoda UK & they've opened a case, with a case number & will be contacting the dealer. The person she spoke to at Skoda UK said it sounded as if there could be a wiring loom problem. When this had earlier been suggested to the person she dealt with at the local dealer, he said there is miles of wiring to check & without seeing it happen they wouldn't know where to start checking. Hopefully something will come of this. Interested to hear if anyone else has had this problem, & also if it has been resolved.
My wife's car has still been getting intermittent wipes since the first visit to the dealer. After 2 visits to them, the first for only an hour so they could put her car on the diagnostics computer, nothing found, but intermittent isolated at that time, & another today where they have had the car all day & supposedly 20 miles of driving, the dealer says they can't do anything, & they wouldn't escalate it to Skoda UK, my wife has called Skoda UK & they've opened a case, with a case number & will be contacting the dealer. Hopefully something will come of this. Blorin, maybe you should escalate to whoever is the main Skoda power in Romania? Maybe then something the wheels may start turning to try & isolate your problem. If enough people complain then it cannot be ignored.
The same started happening on my wife's Karoq last week. At first it was only after turning a corner but has now started doing it at any time. Car is into the dealer tomorrow so that they can put it on the diagnostics machine. Personally I have my doubts on them getting an answer that way & suspect it will need an inspection of the wiring in the steering column.
A little puzzled as to how you'll insert the plugs, surely the tyre would need removing from the hub to insert the plug, trying to insert from outside, surely it would just be pushed out when trying to inflate again?
We received an email 23rd August; "It’s still showing in the factory, Skoda have announced there will be some temporary delays in some of the TSI models, Yours is already built though, but is being held at factory for technical data/certificate of conformity." When taking delivery we were assured that the first gear issue had been sorted out & shouldn't be a problem. By that I would assume that all software updates/modifications would have been applied prior to the vehicle leaving the factory.
I've seen a lot of messages in this topic of earlier Karoqs having problems with the engine losing power when pulling away, but has anyone with the latest models had the problem? The reason I ask is that my wife's Karoq, built week 12th August 2019 has had this problem 4 times since she got it at the beginning of October 2019, the most recent being just after the commencement of lockdown. The previous 3 occasions were reported to our dealer & they looked at the car, gave it a test drive, & didn't find a problem. I insisted the dealer logged the reported problem with Skoda so that in the event of others reporting the same fault, at least then there would be a record, & hopefully a fix eventually.
Whenever I've had my car serviced & they suggest my AC needs re-gassing as it loses gas, my response usually goes along the lines of, "Do you get someone in to re-gas your home refrigerator & freezer every couple of years or so because they lose gas?". That is usually enough to stop them pushing that extra service expense. If they persist I point out that amongst other things, I work with refrigeration systems & they are spouting a load of bull5h*t.
Just done the update & noticed a potential problem in the actual maps. Currently the Lincoln Eastern By-pass is under construction, the projected date for the completion & opening is currently May 2020. However, going by the updated maps it would appear that the by-pass is completed & I would assume that means it is incorporated into any route planning.
Had a call a couple of days ago from foreign sounding female asking if I was me, or rather, she asked for someone who was an anagram of my name. When I said there was no-one of that name here & she must have the wrong number, she just carried on, claimed to be from the "Telephone Preferencing Management Service", & was I still getting nuisance spam phone calls, etc. Obviously a nuisance caller, but I let her go through her spiel for a minute or so, then told her I am registered with the TPS, so, Good Bye. This seems to be a new tactic, instead of claiming to be a research call, now claiming to be from something that sounds similar to the TPS in the hope that people won't pick up on the difference in name.
I only got my 67 plate SEL a week & a half ago, so still finding out what does what, but on the first evening while checking out the infotainment system it found my home wifi system, so I logged it in. Then, when checking out the satnav system it said there was an update available, so I told it to go ahead. In less than half an hour the downloads were done. After downloading there was a distinct lack of info as to whether the updates were being installed, but when I checked the following morning it stated that the England South & North maps are now 2018/9. So, if you are fortunate enough to be in reach of a decent speed wifi system, I'd suggest doing the download that way instead of using an SD card & possibly encountering some of the problems I've been reading about.
I got an update from them earlier this year & it installed fine.
For those in the UK, maybe also for those outside, - http://www.satnavdisc.co.uk/Skoda/LATEST-2017-SKODA-AMUNDSEN-RNS315-V9-NEW-SD-CARD-SAT-NAV-UPDATE-EU-UK
Map update for Amundsen (Nov 2016)
wharferat replied to Skeddy's topic in Skoda Rapid & Spaceback (2012 > )
Just done the update to V9 on my Superb II. Card was £44.99 & delivered First Class Royal Mail signed for. For anyone considering buying from there, it wasn't necessary to register as such, & as well as credit card payment, they also take paypal. I had been keeping an eye on that well known auction site & the best price I saw there for V9 was £69, so big thanks to Montieous for the link. :-) -
Liger1956, we were on an Economy 7 tariff, but then the supplier decided our electric meter needed changing. When the day came the engineer only had a single tariff meter to fit, so, as that was all he had, it was fitted. From being on 2 tariffs we went to one, & that was with a cheaper cost per unit than the daytime rate we had previously been on, but obviously not as low as the E7 rate). It may be worth you trying to work out if what you save when consuming electricity at Economy 7 rate makes up for the extra cost of use at the daytime rate (that is if your supplier has higher charges for daytime usage).
It doesn't commit you if you phone your local dealer, or go in, & ask them what is involved in the software update. Here's my experience. I went in today to have the software fix. Before they started work I questioned the Service Manager about what was involved, he informed me that basically it wipes the current software & then uploads a re-written version to the car that has the cheat programme removed. Basically, the original programme with the cheat & any links to it written out. In the initial stages of preparing to wipe the old software on my car, the programme froze & refused to go any further. The dealer started an exchange of emails with SUK & apparently this has only happened once before. Further investigation, & no doubt another re-writing programme will end up being sent to the dealer. I would commend the dealer, Horton Skoda, who did their best to answer my questions before I handed the car over, & then once they realised there was a problem, immediately offered to lend me a comparable car with myself & my wife insured fully comp. At this stage the manager had only been told by the technician that the software installation had frozen halfway, & he was working on a worst case scenario that my car didn't have a viable engine control system. Fortunately, by that stage nothing had actually been changed, so I was able to drive my car away to await a call for another day to get the job completed. When they notify me that a solution has been found, I will be taking my car back. They have assured me that if I do feel that the software update (once carried out) has made changes to economy, performance, noise, etc, they will take the car in & investigate. I know that some posters have reported problems after the update, one of them on just about every thread on the emissions, but from the thousands that have had the update they would seem to be in a very small minority, so I'm prepared to let it happen. The final decision, Linda, is yours.
I've got gas permeable lenses. I tried soft lenses for a few months but didn't get on with them, basically the environment I work in. If any dust or grit got under the lens it would be held in place & end up scratching my eyeball, then a couple of days without lenses for it to stop being sore. At least with the gas permeable there is a good chance grit could wash out as it wouldn't bed into the lens.
Service Action - Software Upgrade EA 189 Engines
wharferat replied to Charade's topic in Skoda Superb Mk II (2008-2015)
Had my recall letter yesterday, "Service Action: 23R6 EA 189 diesel engines.". The engine code is CFFB. The letter promises, "Skoda has worked closely with the relevant, independent authorities to test extensively the software update for your vehicle. Following the completion of this testing, I can confirm there will be no change to your vehicle's engine performance, maximum torque or noise levels. The performance data already published for your vehicle, including fuel consumption values & CO2 emissions will also remain unchanged." -
I had some camcorder tapes transferred to dvd some time back by these people: https://www.video2dvdtransfers.co.uk/ I was more than satisfied with the service they gave, & just having a quick look before posting the link, the website is clear on how much everything costs. I've since downloaded Movie Maker so I can copy sections of video from the dvd's to make compilations of different subjects from them.
I still haven't had the recall. Looking at the sticker in the spare wheel recess, my engine code is CFFB. Maybe they are concentrating on doing the engines by code, starting with those codes with the highest number of engines. I hadn't realised that a 2.0 litre engine from the same manufacturer would have come in so many different variations, https://en.wikipedia.org/wiki/List_of_Volkswagen_Group_diesel_engines
