MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. open attached link to Drive2.ru only springs replace, original Rough Road to Eibach Pro -30mm full set code: E10-79-012-04-22 front: F11-85-042-03-FA rear: F11-79-008-01-HA just note, this set is for 2.0 T*I AWD, but he installed on FWD - in that case rear has't dropped at all still searching the same recipe for front axle
  2. @JeromeUrbain https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/
  3. solution for hatchs - on the rear axle can be installed springs from wagons Eibach Pro rear springs F11-15-007-04-HA (-45mm on AWD) F11-79-008-01-HA (-30mm on AWD; 0mm on FWD) rear looks perfect then, front definitely too low for me any suggestions? another interesting pictures from Russian board https://www.drive2.ru/l/573382395697299820/?m=573499218807751143&page=0#a573499218807751143 springs diff front: rear:
  4. no, in 90% battery were replaced under warranty, links attached above
  5. Great idea i were limited within 40k Euros and FWD costed +4k other options in far 2015 sounded more sweet for me but even now, when power difference(190ps vs 272ps) is more obvious between 2.0 TSI FWD vs AWD (mine has 220ps) i can't decide which option can be removed from the list -> https://www.drive2.ru/l/557894125152633200/ one of idea, in my stupid head, is catch FL in it's last year on the line, cause next model will lose gear stick
  6. measure even without open a bonnet ~7 euros from Ali similar devices, with voltage only, will be cheaper, i searched one with Q3.0 Fast Charge and shown values are correct https://www.briskoda.net/forums/topic/477834-agm-batteries-not-efb’s/?do=findComment&comment=5362969 https://www.briskoda.net/forums/topic/454623-what-have-you-done-to-your-superb-iii-today/page/38/?tab=comments#comment-5370984
  7. how to and what tools
  8. thanks for info! yesterday had to return without unpack :( pictures in product description gave false hope
  9. next ECE 2021 https://www.briskoda.net/forums/topic/486625-columbus-map-update-2021-mib1mib2mib2h/
  10. 2021 for Amundsen https://www.briskoda.net/forums/topic/480367-amundsen-mib2-map-updates/?do=findComment&comment=5465146
  11. http://vw-maps-cdn.lighthouselabs.eu/vw-maps/DiscoverMedia2_EU2_1520_V13.7z http://vw-maps-cdn.lighthouselabs.eu/vw-maps/DiscoverMedia2_EU3_1520_V13.7z
  12. @Jakec no need of visit Škoda portal when direct link is known check dates in tread of previous updates https://www.briskoda.net/forums/topic/481746-columbus-map-update-2020-2021-mib1mib2mib2h/ "Published:" comes later than "Downloadable:"
  13. 17" will fit for winter better 225/55r17 1.5% bigger than stock 215/55r17 your 225/50r17 will be -1.5% smaller
  14. single files http://infotainment.phonostar.de/images/vwag/eur/GBR.zip full database haven't seen for Škoda, db for VW were rejected -> https://www.briskoda.net/forums/topic/480992-sat-nav-worked-no-sd-card/?tab=comments#comment-5403547
  15. ECE 0189 2021 https://www.briskoda.net/forums/topic/486625-columbus-map-update-2021-mib1mib2mib2h/
  16. for Skoda Columbus, Seat Navi Plus, VW Discover Pro, Audi MMI Navigation Plus # ECE 2021 28Gb Version: V03.959.806.GH 0189 ECE 2021 VW portal: http://vw-maps-cdn.lighthouselabs.eu/vw-maps/P189_N60S5MIBH3_EU_NT.7z Files inside: 2020.05.04 Downloadable: 2020.11.08 Published: ----.--.-- Škoda portal: http://infotainment-cdn.skoda-auto.com/base/maps/HIGH12_P189_EU_202045.zip Files inside: 2020.05.04 Downloadable: 2020.10.27 Published: 2020.11.0? Seat portal: - older, 2019-2020 # Rest of World 2021 23Gb Version: V03.959.806.?? 0090 ROW 2021 DevVersion: VW portal: 8Gb corrupted file -h-t-t-p://vw-maps-cdn.lighthouselabs.eu/vw-maps/P90_N60S5MIBH3_ROW_NT.7z Downloadable: 2020.11.08 Files inside: ----.--.-- Published: ----.--.-- Škoda portal: http://infotainment-cdn.skoda-auto.com/base/maps/HIGH12_P90_MRM_202045.zip Files inside: 2020.06.22 Downloadable: 2020.11.04 Published: 2020.11.08 ======= coverage ======= # EU Albania *, Andorra, Belgium, Bosnia and Herzegovina *, Bulgaria *, Denmark, Germany, Estonia *, Finland, France, Gibraltar, Greece, Ireland, Iceland, Italy, Kosovo *, Croatia, Latvia *, Liechtenstein, Lithuania *, Luxembourg , Malta, Macedonia (Former Yugoslav Republic) *, Moldova *, Monaco, Montenegro *, Netherlands, Norway, Austria, Poland, Portugal, Romania *, Russia(European part) *, San Marino, Sweden, Switzerland, Serbia *, Slovakia, Slovenia *, Spain, Czech Republic , Ukraine *, Hungary, Vatican City, United Kingdom, Belarus *, Cyprus * * partially # ROW Argentina *, Australia, Bahrain, Botswana *, Brazil *, Brunei *, Chile *, Indonesia *, Israel, Jordan, Qatar, Kuwait, Lesotho *, Malaysia, Mexico *, Mozambique *, Namibia *, New Zealand, Oman, Philippines * , Reunion *, Saudi Arabia, Singapore, South Africa, Swaziland *, Thailand *, Turkey *, United Arab Emirates * partially ======= instruction ======= 1. download 7z/zip archive from direct link 2. extract content to SD Card or USB 3. insert memory device into slot of Columbus 4. start of update usually is offered automatically, manually can be found under Navi-> Settings !!! note for MAC users -> https://www.briskoda.net/forums/topic/452002-direct-download-links-for-ece-20182019-maps/page/2/?tab=comments#comment-5095042 couple of potential questions are answered in previous posts: Columbus Maps 2020/2021 Columbus Maps 2020
  17. by info in link i posted above, this were made from original blank button
  18. @Rkdee try this inexpensive experiment
  19. I haven't opinion with Kodiak knob, but i have question about our, what is the function of knob? without press break pedal can't move gear leaver anyway :( in previous Sonata i were able move between N and D without press pedal
  20. few pictures: -> https://www.drive2.ru/l/491122983021052184/
  21. @Gleisner95 modify current ones: -> https://www.briskoda.net/forums/topic/483226-fit-switch-next-to-gear-lever/?tab=comments#comment-5426271
  22. open with Google Translate https://www.drive2.ru/l/569978307697705317/
  23. Open link which i posted above, that tread has pictures of bulbs and links to Ali
