AGFalco
Everything posted by AGFalco
  1. Wrong Reg for Skoda head office car? VO is from the ( Severn ) Valley area. Thanks, AG Falco
  2. Two previous owners and no MOT? Ask to see any Service history on ERWIN for the car as well. https://www.check-mot.service.gov.uk/?_ga=2.163191100.1279459482.1616264486-1872168813.1599411086 Thanks, AG Falco
  3. I my 2016 Fabia I can turn them off via the infotainment system. So on car's post April 2018 you might find you cannot turn them off. It's legislation to help the dumb. Some people don't know how and when to have lights on / or off. Had a customer in last week that didn't know how to turn their side / parking lights on. Thanks, AG Falco
  4. Check the engine type again. 1.0 litre MPI can have 75 bhp. 1.0 Litre TSI can have 95 bhp. Thanks, AG Falco
  5. post no 2 then. Thanks, AG Falco
  6. Air only ever comes out of a tyre when left. So if the spare wont get checked regularly then put too much in when is is checked. It is better to have a little too much air rather than too little. I set my spare to the max load pressure for the car. If when you go to use the spare and find it is flat it is no use at all. As a rough rule of thumb, the wider the tyre, the lower the profile, the faster the car goes, the heavier the car is, then the higher the pressure wanted. Slow tractors with big profile tyre = low pressure. Faster lorries with heavy loads = high pressure. Thanks, AG Falco
  7. Παρακαλώ χρησιμοποιήστε Αγγλικά. Thanks, AG Falco
  8. Present version of the 'Highway Code' on page 129:- Tyre Pressures. Check weekly. Do this before your journey, when tyres are cold. Warm or hot tyres may give a misleading reading. Note:- 3 points and or £2500 fine for an incorrectly inflated tyre. ( Per Tyre ) See page 126. This is incorrectly inflated for the load being carried at the time. Tyre Pressure goes up when hotter and down when cold. Tyres will get hotter, when driven, the faster you go, the heavier the vehicle is, the lower the pressure that is in them. When a tyre hits a pothole / speed bump the pressure momentarily increases beyond the maximum inflated pressure limit of the tyre. Thanks, AG Falco
  9. The maximum pressure the tyre can take is 3.0 Bar. This will be marked on the sidewall. You want this pressure in the tyre when it is in the boot. Or at least above the loaded / Eco / High speed pressure that your normal tyres require. If / when you have to use the tyre adjust the pressure down to the same pressure as the rest of your tyres have in them. Thanks, AG Falco
  10. Check Goodyear Efficient grip performance in both version 1 & 2. In the top three in a recent big tyre test. B for fuel efficiency. But the nut between the steering wheel and the drivers seat has the best control over this. A for wet grip. As good as you can get. 67Db very low External noise done on a drive by test. They are also lighter than most tyres in the same size. I like the way Confused.com are confused by tyres. The link above has a tyre size that doesn't exist. But if you correct the size then in doesn't come in that weight rating or speed rating. Anybody managed to buy some average tyres. D Fuel, D Wet Grip and 70 DB noise? Thanks, AG Falco
  11. and mass. Thanks, AG Falco
  12. You will also find some tyre manufactures have a thicker / stiffer side wall compared to other manufactures in the same size. Then some manufacture of tyres make different thickness / stiffness of side wall in the same size. Pirelli only make 3700 different types of passenger tyres. You can find that they can have as many a 20 different tyres in one size. Thanks, AG Falco
  13. No. If the new battery is that bad already is will have suffered some degradation already. Perhaps take the multi meter with you when you swap the battery for a new one. Could the car have a big short that is killing the new battery? Thanks, AG Falco
  14. EFB battery on my Fabia III is 4.5 years old and is showing 12.61 volts using a £10.00 multimeter. Set the multimeter to Volts DC and place the red probe on the positive battery terminal. Then place the black probe on the negative terminal and note the reading. Can you test your multimeter on something else like another car battery or an AA battery. The under bonnet fuse box is a black plastic box just behind the negative battery terminal. It is a clam shell that opens from the left end if you are at the front of the car. Thanks, AG Falco
  15. A Good battery will be 12.8 volts or higher. All the voltages you note are much to low. What batteries did you buy, EFB of AGM? Did you collect the new batteries or were they delivered? Are / were the new batteries charged when received. Thanks, AG Falco
  16. That's part of the Stop Start system. What voltage do you have in the new battery? Thanks, AG Falco
  17. Tape measure? Thanks, AG Falco
  18. If you want the Front Assist to stop braking then just push the throttle pedal. Thanks, AG Falco
  19. Do the Parking lights / horn work without putting the key in the ignition? What voltage is the old battery at? What voltage is in the new Stop / Start Battery? Did you follow the correct procedure for battery replacement? Thanks, AG Falco
  20. NO. Sensitivity can be adjustable via the car's Bolero Infotainment System. See below copied from the manual. ■ Front Assist (ambient traffic monitor. sys.) - Set the assistant for distance monitoring to the vehicles ahead ■ Active - Activate/deactivate the assistant ■ Advance warning (Version 1) - Activate/deactivate warning ■ Advance warning (Version 2) - Activating/deactivating and setting the distance level at which a warning occurs ■ Early - Longer distance ■ Medium - Medium distance ■ Late - Short distance ■ Off - Deactivation of the warning Thanks, AG Falco
  21. If the car is on fixed oil changes then this is 372 days / 15000 KM. in the UK. If you reset the oil change from variable to fixed you cannot change it back. A dealer might be able to do this. An oil change service is different from an inspection service but can be done at the same time, check mileage / time for what is checked. The Inspection service will stay at 2 years but if an inspection is done at the same time the oil service is done it can be reset then. This is for mine:- SKODA Fabia III (NJ) 1.2 TSi (CJZD) 01.2015 - 01.2017 Maintenance / Repair manual / Service indicator reset (2014 - ) Service indicator reset Vehicles with keyless entry system: Close all the doors Close the boot/tailgate Close the bonnet Oil service reset: Press and hold button (1) Button 1 is the trip reset button marked ' 000/SET' Turn the ignition on 'DELETE OIL CHANGE' appears on the display Release the button Select 'Reset oil change interval' Press and hold button (1) The system is reset. Inspection service reset: 'DELETE INSPECTION' appears on the display Press and hold button (1) If necessary: Turn the ignition off Repeat the procedure After turning the ignition off and on again Press and hold button (1) for 2 seconds 'DELETE OIL CHANGE' appears on the display Release the button Page 1 of 2 Press button (1) again The system is reset. Hope this helps. Thanks, AG Falco
  22. Sometimes you can push the bumper back in to shape with the help of a heat gun / hair drier to soften it up first. It won't be perfect but you can make it look better. Heat from inside and not to much. Practice on an unimportant part of the bumper first. Thanks, AG Falco
  23. I'm talking about oil temperature as displayed on the MFD. Thanks, AG Falco
  24. Sounds a little low to me. To help mine warm up I have now blanked off the top radiator grill. There is a post about this. I now see low 90's C after 12 miles, I was getting low 80's C. Thanks AG Falco MFD Multi-Function Display
  25. The Temperature gauge is not accurate by design in the car. If you look at the engine oil temperature reading in the MFD you will get a better idea. Mine after 12 miles can still be in the low 80's C during the winter. It can be above 100 C in the hot weather when being used. After reading your other posts I don't think you have a problem except that it is cold outside. Thanks, AG Falco
