Everything posted by nickytheshaft
Infotainment Upgrades
Yes mib upgrade is the best option. Therefore you won't get wireless android auto or carplay, the units are not meant for it. They are dongles for wirelessly but won't recommend theme as they have speech recognition delay and don't quite understand what you say on Android auto. I can't pronounce for Apple carplay. Stick with the mib upgrade and wired connection. It works Great and charges your phone at the same time.
High Mileage Club
2.0 Tsi 2014 vrs combi 87000 km 6 speed manual Front brake pads Tyres
Poor cornering
My 2014 tsi vrs handles great. Can take roundabouts and corners at hight speed. I am on stock suspension and 17 inch eaglr asymmetric 5's You should check your wheels alignment and suspension condition
MIB 2.5 Retrofit minor issues
Ask pab, he is the expert here
Teyes CC3 2K
You will see the options but it won't do s...t the RAISE canbus has limited interaction with the car. Mainly streering wheel control, climate conbtrol, drive options, reverse camera and voila, don't expect anything else. If you can go with crappy phone calls and limited acces to the car settings, these units are in deed very good for the reste, no doubt. But if you want to retain all the functionalities, they are juste not ready yet. And for android auto on the stock unit, you may also need to change the usb socket. Contact @pab567 and ask him about it, he is the expert here
Teyes CC3 2K
Yes stearing all the wheel function and others will work. You will have limited access to car settings but car status will not show, so tmps will not work. You can get a usb sensor and wheels caps to have tyre pressure. Also voice recognition is not working on the units for android auto. It will not understand what you are saying. It is the greatest drawbacks. Honestly if you really want Android auto, go with the 150 pounds or contact pab to see if he can fo something for you. It will be hastle free and you will retain all the car functions.
Teyes CC3 2K
No car tyre pressure monitor will work with an Android head unit. If the unit can read the car status then it will show the low pressure alert. This said, My previous unit could not read the car status.
changing columbia head unit skoda octavia
Man went past this Post, @pab567 can help you with the retrofitting. Send your unit back and Contact him. The USB port is the yellow plug for data and you must send 5v from the unit to the quadlock in order to power the port. As far as I know, only Alpin makes such an adapter. When I was on my Android devices, I had to build my own in order to have the USB port work. Splice and re-pin the USB power from the unit and pin it to the quadlock
MIB1 android auto/ car play solution
yes. the black connector is the car DAB antenna, plug it to the fakra then the cable to the usb dongle. You will have DAB reception without having to stick the antenna on the window. It is cleaner and more efectiv this way
You can also find the cables on amazon but more expensive
This is the type of cable. https://fr.aliexpress.com/item/1005001659837763.html?spm=a2g0o.productlist.main.1.67d232787xMof2&algo_pvid=6d4ddc40-3d89-4de6-a119-376b0ef0cc31&algo_exp_id=6d4ddc40-3d89-4de6-a119-376b0ef0cc31-0&pdp_npi=3%40dis!EUR!1.62!1.07!!!!!%402100baf316865569603067012d0774!12000017752774608!sea!FR!914286551&curPageLogUid=jibJKlRNp8nz you connect the fakra to the blue connector to use the car stock gps antenna and to the black connector to use the car DAB antenna. Fo rthe DAB, you need a DAB usb dongle something like this https://fr.aliexpress.com/item/1005004457357387.html?spm=a2g0o.productlist.main.11.44ed6caeJpwl8F&algo_pvid=e121ecd3-8713-4c44-84c0-1e9c4add3a91&algo_exp_id=e121ecd3-8713-4c44-84c0-1e9c4add3a91-5&pdp_npi=3%40dis!EUR!27.75!18.03!!!!!%402145274c16865572199086139d0744!12000029238336337!sea!FR!914286551&curPageLogUid=Yp4AVJaFfUll
The unit in the glove box become useless ad you unplug the quad lock from the unit to plug it to the Android one. O. The other hand, if your car has Stock gps, you can use a fakra adaptor to hook the car gps antenna to the Android unit (works great). The same goes for the dab antenna, fakra to the USB stick format and you are good to go. Only the microphone can't be used as the car had a powered mic
You can see my earlier comment on these head units. If you décide to go this route, stay away from the 2g models and go at least for the 4g's
Speedometer problem
On my 2014 vrs it is standard. Maybe only in France...
Does your stock usb work? if not then check the huge poste on android head units, another user and I poster hox to rewire the plug going to the head unit. when you press the driving mode button does it show up on the screen? + how is the call quality?
Speedometer problem
This should be standard no? at least it is on mine. speedo and rpm swype every time on startup
Speedometer problem
Strange, normaly it under reads by about 7 km/h... Maybe a VCDS coding can solve it
Air blower smells and car steams up when it is warm outside
Yes you should leave the ac on everytime your closet your Windows. Mine is always on Auto. It will dry the air in the car. The fuel consumption doesn't change a lot, for me it is insignificant. On the highway at 130 km/h I an between 7.1 and 7.8 l/100. Do that, change your filter every year and use an a cleaning kit and you will be good
yellow = usb blue = gps antenna black = dab antenna grey = screeen conenctor. As said, you will loose a lot of functionalities and retrofitting would surely have been cheaper.
2818 ŠKODA Octavia VRS TDI just bought
Wow I was not aware of that!!!! I just learned something new
Hi, I don't think there is a bigger cup holder There is a repair guide on briskoda, I got mine here. 37 mpg seems a good consumption imo. It is about 6l/100 on my 2l TSI I get 7.2 to 8.5 l/100 on the highway at 130 km/h
Reverse camera
what does this interface achieve? what I did was cut off the rca, add a pin to the positive wire of the camera and put the pin in the qhadlocl + a little codding abd voila, camera works you can also use this if you car doesn't have the blue connector https://fr.aliexpress.com/item/1005003882902507.html?spm=a2g0o.productlist.main.23.78d21481h9sV6i&algo_pvid=f33cbf69-793a-450a-9151-0e3c9af808e9&algo_exp_id=f33cbf69-793a-450a-9151-0e3c9af808e9-11&pdp_npi=3%40dis!EUR!7.21!5.4!!!!!%402100b0d116843062584832826d0742!12000027381704930!sea!FR!914286551&curPageLogUid=W4y6pojE1sdD
Reversing Camera OEM
i assumed there where 2 sizes as the seller has both on his site and asked to check. One thing odd thought, my car is the 2l vrs ordered 04/2014 ans delivered 08/2014 and I have the old handle. I am sure it was built after 05/2014 (but we are getting off topic) A question thought. My camera is 720p as I had an android device supporting ahd and 720p screen, the picture was superb. i then retrofitted a MIB2 amundsen with a 8 inch screen and analog video feed. The picture is so so . Does the unit struggle to go downscale the camera? will going to a 480p camera improve the picture quality? Thanks
send your details to ApertureS and see. You can also measure your handle and see is it is the old model like on the link. Be carreful, ols models also have 2 different types of plugs. Only way to know is to check behind the trim. Here is an example of old model handle https://fr.aliexpress.com/item/32570611045.html?spm=a2g0o.cart.0.0.5863378dS2ZewP&mp=1&gatewayAdapt=glo2fra
Reverse camera
You have to measure the size of the handle as well as the plug. Here you have the different options https://a.aliexpress.com/_EJLYs2z
