thamestrader
Everything posted by thamestrader
  1. The OBD port crops up on the Mk7 Transit forum where the recommended solution is to relocate the real port out of sight and fit a dummy with wires that don’t connect to anything in its place.
  2. This is quite a critical factor. Brother has 64 plate Yeti manual 2.0. TDI 4x4. At the same time I had a 2,0 TDI Touran DSG. Both cars same VW 140bhp diesel- the Yeti struggled to better 50mpg -the Touran would easily do 65mpg, I did once manage 73mpg on my 50 mile commute home on the M1. Sorry not a Karoq.
  3. Towbar prep was not something I could firmly establish from Škoda as being or not being on my car. The Plate with the weights has GTW which indicates it’s homologated for towing. I didn’t need the cooling upgrades (fan and grille changes) it’s a 2,0 TSI so no doubt has them as std. it did require all the wiring cables which suggests no Towbar prep. The delay was for one cable, I have wondered if that was the cable that’s fitted as std for Towbar prep now, which was perhaps why it was in short supply. Total cost was £1740, same price as the local dealer - I’d use Richter over the dealer for any job that requires removing and refitting the interior. It might seem expensive but a 2.0 TSI Sportline with towbar was over the RFL £40k threshold - so it was more cost effective to do a retro fit than buy an ex demo that had been built with the towbar, they are also rare although there was one available at time albeit another 4k over what I paid for mine.
  4. I've been expecting to post this summary since early June, but parts on back order delayed fitting until today. Richter Automotive in Milton Keynes had fitted the towbar to my previous VW in 2014 and so I went to them again. I ordered from Richter Automotive, in May, the supply and fitting of a Skoda Electric Swiveling Towbar, identical to what would be included on a factory order. I have to compliment Richter Automotive on the customer service and workmanship. Due to some electrical parts being on back order with Skoda the fitting was delayed by 10 weeks, Richter's Maxine kept me updated regularly and when the parts finally arrived shuffled other jobs around to fit my Karoq in on the first date I could drop it off. Its a big job requiring rear seat removal, rear bumper, boot trim and many pieces of internal trim to route the wiring from front to back. My Karoq was completed by the end of the day, everything was neatly back in place no mess, no rattles, however due to circumstances beyond Richter's control the towbar would not deploy. The CANBUS coding supplied with the towbar to activate deployment when the switch in the boot is pressed was incorrect. They have contacted Skoda/VAG for the correct coding and will come to my home to update the CANBUS coding when they receive it. The exact same issue had occurred with an ID Buzz swiveling towbar the previous week, so I am confident of a successful resolution.
  5. I’m in the same boat. I’m finding mpg is improving as the overall mileage goes up, but it’s only done 3000 miles to date. I can get 50 mpg on a run, but around were I live it’s about 25-30 due to lots of roundabouts linked by 70 mph dual carriage ways. Our Fabia 1.2 110bhp DSG is better on local runs but on longer motorway journeys it’s not really any better than the Karoq.
  6. Yes it’s easy to use a brush too. My previous car had 16” alloys, our Fabia has 15” alloys - the 19” are so much easier to clean.
  7. What’s the maximum load capacity of the Karoqs roof bars as I’d have thought that would be important. i don’t think the Sportline rear seats are easily removable unlike the Varioflex seats which are designed to be removed.
  8. I too would have recommended a CTEK charger to maintain the battery, but if mains power is an issue then have you considered a solar trickle charger for example ProPlus Solar trickle charger 12V 1,5W | Euro Car Parts there are plenty of other makes around. The option to remove the battery and put it on a trickle charge in doors is probably not a good ide given modern cars dont like not having a battery connected. Another option is to buy a battery boost pack which can be charged up elsewhere and used to top the battery up periodically without needing a mains power lead. Must be so disappointing to have a new Karoq sitting there and unable to use it. The advice to have the bonnet left open, being ultra cautious myself I would leave it unlocked with a window partially open bit only if your garage is secure.
  9. I have direct experience of the this fault with family members. Cousin has a Seat Ibiza 1.2TSI 2017, actuator fault while still under warranty required turbo replacing as well. Same fault recurred a few years later when the car was out of warranty. Partners sister has a 2017 1.2 TSI actuator and turbo replaced under extended warranty when 4 years old. Both these Fabias are low mileage, typically 3,000 miles per year driven gently, short journeys, never rev’d hard. I believe that is a factor and a weakness with this engine. We have a 2015 1.2 TSI similar annual mileage - two key differences always use Shell V Power petrol and it is driven faster.
  10. I know that the 19 inch alloy wheels are unpopular with some owners due to the lower profile tyres that they are fitted with. However there is an advantage of the 19 inch wheels over the smaller sizes when it comes to cleaning them. There is good clearance around the brake discs, even the larger front discs. I'm able to get my hand, holding a sponge, in between the 'spokes' of my Vega Alloys to clean the whole of the inside rim including the inside edge. As someone who tries to keep their alloy wheels clean without any brake dust baked on the inside of the rims this is a real bonus. It will save me having to remove each wheel in turn every few months for cleaning.
  11. Further to my original reply regarding volume. There is sub menu accessed by swiping do was from the top of the screen which allows config of sound, includes the sat nav announcements and various other sound related parameters.
  12. Absolutely agree, the designed lifespan should be at least as long as the what it replaceds.
  13. Whilst it is a 5 year old vehicle, how many members in this forum have had to have old fashioned analogue dials replaced? In my 50 years of car ownership I’ve never had any issues with traditional dials - the expectation is that the electronic version would be at least as good.
  14. I have used HazzyDayz in Markyate for retrofits, and they used to refurbish car electronic items. Might be worth giving them a ring.
  15. Update touch the destination to delete and slide to the left a red tab with a waste bin should slide in on the right.
  16. Skoda seems to assume that if you want the Infotainment screen on that you want sound as well, I don't so just turn the radio volume right down. Interestingly this does not turn down the Carplay volume. Deleting unwanted destinations if I remember correctly on the main Nav screen touch and swipe left (or maybe right) and a red delete prompt is show touching that deletes it. There are a ;lot of things that work that way.
  17. If it’s a 4WD model then it could be the prop shaft to the rear axle.
  18. On another thread there was mention of using VCDS to alter the throttle operation - from memory it was something to do with linear and non-linear. Sounds like the newer dry clutch DSGs are an improvement over the one in our 2015 Fabia (or perhaps its faulty) and my reservations are no longer valid.
  19. My brother had 64 plate 2.0 TDI Yeti 4WD and 17” wheels I believe, he says my 4WD Sportline has a smoother ride than his Yeti. I don’t find my Sportline to have excessive road noise or a hard ride compared to the Touran I had previously, but I did have tyres at the max load pressures on the Touran. I guess it’s what you become used to. I drive 3 times as many miles a year in a Mk 7 Transit minibus as I do in my own car, Transits are not known for their soft comfy ride!
  20. Touran has headrests that slide back and forth as well as up and down. I had a neck injury which means I always have the drivers seat back very upright. Mine was 7 seater with height adjustable front seats. A 7 seater for just the two of us may seem overkill, but the key criteria was headroom, legroom and comfy seats. The Wet clutch DSGs seem to engage without touching the accelerator so creep without any throttle. DQ381 is very smooth at pulling away, because I feel, it doesn’t require throttle it starts moving when the drivers foot comes off the brake pedal. Having said that there are times when auto hold cuts in, s/s stops the engine, then throttle is required to release the brake and move off. The dry clutch DSG in our Fabia, sometimes doesnt pull away or is a bit tardy - pressing the throttle further causes it to leap forward far quicker than intended😧. My partner had no trouble driving the Touran although she did comment that the throttle required a very firm push, so maybe I was just too heavy footed😂 You mentioned the T-Roc, I tried one before the Karoq, with the upright seating position I need the interior mirror mounting created a large blind spot. Karoq has a significantly smaller mirror mounting, the screen is more upright so consequently the top is higher and further away.
  21. I think I may have identified why I have so much trouble with the virtual pedal 'kick' - I think the virtual pedal becomes a non-existent pedal if the car has been locked with the remote and a front door handle touched to disable the keyless unlock. I tend to always disable keyless unlock every time I lock the car. I stumbled on this when I couldnt open the tailgate with the virtual pedal or the button on the tailgate, it would open with the button on the remote.
  22. Having looked at my Virtual Cockpit screen, it looks as though the temp and fuel displays are physically separate and possibly controlled independently of the central section and this explains why they are still functioning. Which leas me to wonder if trying different Views for the Virtual Cockpit setup in the Car menu might get something to be displayed,
  23. @croquemonsieurTouran ride is softer than Karoq, mine had standard 16” alloys with 205/50 tyres ( Cross Climates). Tourans boxy shape is much roomier, front seats I would rate as some of the best with a long seat back which supports the shoulders as I’m 6’ 4” and had plenty of legroom too. My brother who is also over 6’ could sit upright in the 2nd row. I could drive the Touran all day without aches or tiredness. If the 2.0l TSI engine had been available in the Touran I might not have bought the Karoq. As I mentioned our Fabia has the dry clutch, it’s my partners car she’s quite happy with the DSG operation. I drove it short distances in frequently and when pulling away the dry clutch did not behave the same as my wet clutch Touran did. The Fabia did not creep when the foot brake was released requiring accelerator pressure for the clutches to engage and move away. The diesel Touran with wet clutch would creep and move away after releasing brake pedal on tick over without using the accelerator even on a slight incline. This made driving into the garage much easier with the Touran than the Fabia. Since I bought the Katoq I’ve learnt that the dry clutch would overheat if it engaged while the brake was still applied, the wet clutch is cooled by the oil so does not over heat. I would expect that the dry clutch software and operation have been improved in the 9 years since our Fabia was built. The operation of the DQ381, as mentioned, is big step forward from the DQ250, I just hope it’s as reliable! This has morphed into a Touran comparison😃. Just remembered the Touran had a really effective Ebspacer diesel fuelled heater which could get the inside nice and warm in 5 minutes handy on a frosty morning as if would clear the windscreen in that time. I may miss this when winter comes…😕
  24. There may be another parameter to consider. 2WD Karoqs have Torsion beam rear suspension, whereas 4WD versions have a multi link setup one may be naturally quieter due to not transmitting so much road noise.
  25. I suspect the Varioflex seating might not be compatible with 4 WD system, as it probably increases the size of the transmission tunnel. Without the extra weight of the 4WD system the 2.0 l TSI might well be more economical. My ideal Karoq would be - 16" wheels, a decent tyre sidewall, 4WD, a torque convertor Auto (I'm not a fan of DSG), independent rear suspension, no sunroof (I'm a previous owner of a Yeti with a sunroof 💦), 2.0 TSi and Varioflex seating. If the 2.0 TSI engine had been available in an SEL that would have been the spec I'd have chosen; don't need 4x4 - 2WD would be fine, VarioFlex seating I would prefer as its equivalent to what was in the Touran and provides more flexibility, Panoramic roof nice to have but wouldn't choose it, The only optional item I would have chosen was the heated front windscreen. My TDI Touran when pulling out of a junction rapidly would trigger the traction control even in the dry, I've not triggered the traction control in the Karoq yet, given it has an extra 50 bhp on tap I assume its because the 4WD is cutting in, it certainly feels very planted powering into and out of roundabouts - I have 130 to choose from locally! I forgot to mention the virtual cockpit - I quite like it - it just needs a few minor tweaks with regard to on-the fly changes - the old VW MFD allowed you to select the items you wanted to see in rotation. It would be more user friendly if something similar was possible to select which items to show in the centre of the twin dials and rotate thru.
