Everything posted by thamestrader
Fitting Towbar to 2023 Karoq
With regard to the cooling mods they vary from nothing required on the 2.0 TSI through a grill without blanking between the fins on some models to an additional cooling fan and the grill. The towing prep is the cable for the electrical socket for the trailer lights and totally unrelated to the cooling mods. The most important thing with any towbar fitted to a Karoq is the coding for thd CANBUS system. Much of the CANBUS system is now behind a security wall and many dealers are not willing to do changes. Karoqs built before 2024 can be coded successfully, as can 2024 Karoqs, for 2025 & 2026 Karoqs it is less clear. There are towbar fitters who will suggest a bypass relay. This might be acceptable for a towbar for use as a bike carrier mounting although parking sensors will still be active and may well detract the bike, but for actual towing will cause issues.
Skoda KAROQ 2021 - UPDATE SW 270 to 332
Assuming you are referring to the Infotainment system software. These updates are usually Over The Air. What version of the Infotainment Hardware is installed as you would need a compatible software version. My 2023 Karoq has Amundsen system, Hardware Version H25 and Software 0334. Columbus system has different hardware and software version.
Tyre rotation
I’ve never liked the idea of the most worn tyres being on the front which is where you need the best grip for traction, steering and braking. I understand the logic is front end under steer is easy to deal with than rear and oversteer.
Tyre rotation
Look at the sidewalls of the tyres. You need to check if the tyres gave a directional tread usually this is indicated by an arrow moulded on the sidewall of the tyre, the arrow points in the direction of rotation so these tyres can only be swapped between front and back on the same side. Some tyres will have the word Outside on the sidewall to make sure it’s fitted correctly on the rim, the other sidewall will have Inside moulded on it and it shouldn’t be visible when the wheel is on the car. I swap fronts to back every 10k miles to balance out the wear, fronts generally wearing fastest.
All In - anyone cancelled shortly after having a service, did you have to pay extra?
I tried buying the Ain1 plan online in the 30 days before my Karoq was 3 years old but it wasn’t possible, my dealer tried on their system and they couldn’t set it up in advance either. Then a couple of days before the end of the 3rd year it became possible. I’d already had my Karoq MOT’d separately. I think Skoda are missing a trick here the All-in plan should include the first MOT when taken out in the 30 days before the end if the 3rd year.
My ŠKODA App - Send Route
Yet another update. I’ve now had confirmation from Skoda Digital Support, saying they have made software changes. They asked me send a route as guest and then change to primary user, when I did this the route arrived immediately I was primary user.
Further to the Primary user point. Today when I started the car I had to enter email and password, the welcome screen message said my profile had not been accessed for some time. If I didn’t enter it I could drive without Connect services. Initially I got the password wrong it made me Guest again. So being an active Primary user seems to be a requirement.
@chills i didn’t have to anything more than tap the Users icon from the menu, it had guest highlighted and primary dimmed. I touched primary to change the logged on user.
@Rbz5416 Bingo - I wasn't Primary User - made myself Primary, sent a route and it came immediately. Not sure how I became a Guest but it was a least 2 months ago! I don't pay much attention to the Welcome Screen - I will do in future, if it doesn't say Welcome Norman then I'm not Primary User.
@Rbz5416 Interesting I'll give that a try. I've assumed I was Primary user. I have recieved another email from VAG Digital Support this Sunday afternoon. Had to send another route to the car, and then send the App logs to Digital Support. There is a hidden feature - shake your phone and a Support Menu pops up and you can send stuff to Digital Support.
Update 1. ŠKODA Customer services replied Friday with email address of VAG Digital Services customer support. Emailed them and got a reply Saturday evening requesting details of how I was using the function. Replied with step by step details of actions taken in the App and screen prints of each step outcome.
Skoda Karoq 2026, 1.5 tsi, petrol - First oil change when?
I’m guessing you plan to keep the car for many years, so make sure the service interval is set to Fixed so oil and filter changes are every 12 months or 10,000 miles. Nothing to stop you doing oil and filter changes more often though. I bought my 2023 Karoq (in April 2024) with 1,080 miles recorded, selling dealer included an oil and filter service as part of the presales prep. When I bought our 2015 Fabia in 2016 900 recorded miles and 1 year old, from a car supermarket so no pre sales prep, I had my local independent do and oil and filter change immediately. Karoq does around 7000 miles a year and the Fabia around 2000 miles a year both have annual services though.
I too am retired, I am emailing Customer Services. Frustratingly I live this close to VAG UK headquarters for VW and Skoda - the shiny ship's bows looking thing is actually VWFS - but of course you can't go and speak face to face with anyone. I'll report back when I get a response.
Skoda App maps not sending routes to car
Unaware of this thread, in May 2025 I started a thread in the Karoq sub-forum. I have now resurrected that thread as I am again having issues with Send Route and so is another forum member.
Can’t select drive. Only M
Ive just replied to your post on the Facebook Group. Now I see it a dry clutch DQ20, so my comment about DQ250 is no applicable, if you have TSR and ACC is this a 2024 or later car - in which case take it to the dealer, its still under warranty, still has roadside assistance.
Resurrecting this thread as I’ve found Send Route to car does not seem to be working again- even when I try when sitting in the car. I am going to raise it with customer services. For info I have version 8.17 of the App. Cynically I suspect an earlier fix from last year has got lost in the melee surrounding the constant updates issue in the summer.
Simply So Clever
There is a moral to this story too. Few years back four new tyres fitted on the Monday - Tuesday morning start the car to go to work, low tyre pressure warning. Ignored as I “knew” better four new tyres all at correct pressure when I reversed into the garage the previous night. 200 yds down the road steering’s very heavy, stopped got out OSF nearly flat. Faulty valve. I no longer ignore warnings!
Simply So Clever
Couldn’t understand why my Karoq “bonged” at me when I got in this morning. Nor could I understand why in bright sunlight was the map display night mode, when it’s set to Auto. Then it “bonged” again when I opened the door to get out. Light bulb moment - the light switch had been knocked from Auto to Side lights. Quite clever really - never ignore a “bong” I think.🤔
Amazed Skoda has become so BAD..
Thanks - I thought that might be the situation.
Since reading this post I have been observing the DSG behaviour more closely. Now I have a 2.0 TSI 4x4 Sportline so a wet clutch DSG rather than the dry clutch in the OPs car, so my observations may be specific rather than general. The DSG seems to respond to throttle position to decide when to change up, rather than actual speed or absolute revs (until the redline). If I apply a lot of throttle ie over accelerate but not foot to the floor, it can rev to 3000 rpm before changing up, if I ease off a bit it changes up whilst still accelerating, ease off more to maintain the speed and it changes up again. If I pull away gently, in a 30 limit, behind a slower vehicle, with minimal throttle applied it changes up below 2000 rpm but does not go above D4. When the limit changes to 40, slight throttle pressure to increase speed and it changes up only when I ease off having reached 40 mph. It seems driver throttle inputs will trigger DSG gear changes, which is identical to how my previous torque converter autos worked.
@NottsIan I agree with your assessment, something isn't right. I have read that the throttle sensitivity can be adjusted. As I mentioned previously the when DSG adapts to towing it changes up later and down sooner, but it reverts to normal after about two days.
if I use the paddles on mine it displays M and the gear number if I don’t use the paddles to change up the DSG changes up at the redline to protect the engine and gearbox - which is the same as sport mode.
@minsy that is a really unusual behaviour from a DSG gearbox, I’ve driven DSG cars since 2013, currently have wet clutch DSG in the Karoq and dry clutch in the Fabia, previously had a VW Touran with wet clutch DSG never experienced anything like you have described. In everyday driving they have all changed all up between 1500 and 2000 rpm unless the throttle is pushed to the floor when they change up at the red line. I do know that the DSG adapts to driving style: I tow a twin axle car trailer, both the petrol Karoq and previous diesel VW Touran would hang on to the lower gears and change down when easing off on down hill sections for a day or so until they re-adapted to driving solo.
I’ve never heard anyone comment on the DSG changing gear at high revs usually the comment is it changes too soon and they use Sport mode to hold on to lower gears for longer. I don’t suppose you are in Sport rather than Drive?
Big thanks to my agent, not.
The Service Plan is with VWFS they pay whichever Skoda dealer does the service - its not linked to one specific dealer.
