Steviedakota
Everything posted by Steviedakota
  1. Just had 2015 Tsi 150 done, 5 years was the stipulated interval. I looked at the old belt and it looked like it had a LOT more life in.
  2. I've ordered one from Skoda, non camera €150. Quite a premium over that eBay one!
  3. ABS with no surround, prefer the cleaner look and don't like people advertising on my car. :-)
  4. Do you mean 3v3, 2 litre diesel?
  5. I purchased an LED footwell pack from Amazon, cheap as chips and easy to install. Far from OEM but has a nice effect at night.
  6. Erratic issue with the boot handle not opening the hatch (manual opening hatchback). Pressing the boot release on the key fob will activate the opening and then you can open it via the handle. Anyone had this problem? Car is being serviced tomorrow so would like to flag the issue.
  7. 2015 with 50k miles, getting an occasional judder when pulling away in first. Clutch is not slipping. Petrol 1.4 150. Had many petrol manuals over the years (older and with higher mileage) and this would be a first, and no I don't drive hard or ride the clutch. :--) Has anyone had a clutch replacement on the manual, and if so at what age and how much did it cost?
  8. Anyone know if these are easy to replace? Front vents, not rear. Peeling chrome on one.
  9. As above, take the deal. You could go legal claiming a 3 year old failure like that suggests not fit for purpose, but even if you are successful it could cost you a good deal more than £750 to resolve.
  10. Please update us, can you request the official bulletin code from Skoda?
  11. Update: The bushings packed with lithium grease worked (for now). Car suspension is wonderfully creak free, like a new car again. Delighted with that.
  12. Might have to root through the bin to find out! It was down as 3 hours.
  13. My car is now 5 years old, and while it has low mileage it was time to get the belt done. Unlike diesels they don't change the waterpump at the same time, as that resides on the other side of the engine, and is actually quite a complex and expensive unit so is only replaced if leaking. The upside is that it is a bit cheaper than a diesel, €500 from Skoda. The kits includes the belt and 2 pulleys and bolts, and was itemised as €300 on the bill. I asked for the used parts afterward and found that the belt looked like new, and both pulley bearings were butter smooth and play free. I'd say there was a LOT more life in them, but I'm holding onto the car for a while so was happy to get it done for peace of mind. The car also had an oil, pollen and air filter service, and they also removed the wishbone bushings and packed them with lithium grease to hopefully cure the dreaded suspension creak. They seemed well up to speed on the creak and did not charge for this. Free wipers also under special offer, €200 for the above was very fair. Happy customer.
  14. Drivers side handle has started needing a bit of a yank to release, the handle pull has gone a bit stiff, a pity as all the others have that nice gentle pull to open. Anyone had this? Going to spray some GT85 in there see it it helps. There is a small black plastic cover on the inside of the door, the one that rotates a bit, any idea how to remove this to spray some lube in there?
  15. If I missed one thing about the previous 5 series it was the car mats, lovely, deep cut pile units. The Skoda Matt's are very average. So ordered a premier set from carmats UK, hoping they would be better, being a bit skeptical about fit. Online reviews were good so rolled the dice. Well I am delighted with them, deeper cut pile, very substantial, and the fit and cut is 100%, press down fittings are perfect too. At €40 with free delivery they are far better, and cheaper than Skoda mats. Also no Superb name which j always thought was a bit tacky. Would highly recommend.
  16. I know this is a common one so hoping someone can advise as to the procedure for removing the top leather portion to address the creaks inside?
  17. Anyone know how to do this? I can see the plastic screw at the bottom of the door that needs to be turned 90 degrees. I removed the window switch expecting to see some screw in there but there is nothing visible. I also can't see any access around the door handle that might reveal a screw. Totally stumped.
  18. My car is very quiet, but it can always be quieter! So just finished one of the rear wheel arches with one layer of silent coat, then another layer of 5mm closed cell foam. This is an easy job really: Wheel off Remove various torx bolts, some are a bit more awkward than others but they all come out easily. Clean with alcohol then set about the insulation. I stayed away from the dirty area of bodywork around the shock that the liner leaves exposed as I didn't want crud building up on the insulation. Also added some to the liner itself. While it was all exposed I applied some rust treatment (blue coating in pic) to the dust shield and various corroding bolts. Liner on and job done. About 1.5 hours not rushing things. Will do the other side when time permits.
