Everything posted by imart143
Replacement Shocks?
i have normal shocks on karoq without control. 1.5 tsi with 85000 kms. front right was misting, left not, but i felt when dribing that bar is bouncing in front. i tested shocks ant were on 50% of capacity. i changed front with Sachs, man it was another car, much, much more manageable, no jumping, no noises, of course, I also replaced the corresponding bearings and shock absorber caps. I soon replaced the rear ones, which were not so bad, but I like a stable car, so I put Bilstein B4
Service intervals
but, nowadays cars are heavier, faster, brake much intensive, fluid is getting hotter, summer temperature in central europe is "normally" +35°C, brake rotors are bigger. there are lot of reasons why properly mantain brake system. its one of most important system and always had to be 100% functional. changing engine oil is matter of wish but changing rotors, pads, fluid, pipes are the matter of law and security. look i buyed 5yo karoq and braking fluid was NEVER changed. i posted picture but heres too. i have hygrometer fow dot oils, and it always shows less than 1% of water in fluid which is acceptable. but dont wait for that. change it regularly, 2 years no matter of mileage, because this oil is getting old in not opened canister too. opened canster should be used within 1 year.. do your brakes, think about your safety, and of people behind you and in front of you. look at this brake fluid. 5yo.
Brake pad change with EPB
i never hear about that.. ofc it is automatic parking brake, i also have it on my karoq. maybe rather to spend 20 credits od OBD11? some people just use 12V electricity from some battery and 2 wires and drive pistom in or aut.. not a big deal..
so you dont prefere do it manually with small torx bit, just turn it clockwise to the end. after replacing pads, pull parking brake first to pistons go out and then use main brakes pedal to do it on all 4 wheels. i am planning to do that for about 6 months, i buyed ATE rotore and all ate cramic pads. my brakes are on 50% but i like eay that ceramic works. no dust. here s procedure my mechanic describe.. Handbrake: when you tighten the small torx shaft, put back the cylinder and install the pads, put back the housing, do the same for the second wheel and then just get in the car, turn on the ignition and tighten and release the parking brake a couple of times, and it will adjust itself, that means you do both wheels and then only turn on the ignition and the rest. Everything just comes back when you activate the parking brake, it will return the cylinders to the end and you then pump the oil with your foot.
Karoq braking fluid container filter
With a litlle scredriwer around i pull it out, i think it was neer cleaned.. With detergent and hot water old toothbrush and its like a new 🫡
I look in on my container of braking fluid every few months and now noticed, this yellow filter is filled with dirt, and all fluid is sluggish somehow. Fluod was changed 2 yrs ago, how to remove that yellow piece of plastic filter to wash it because soon i will change brakes and brake fluid again by home made system with gravity, but i dont want to put new oil thru this muddy filter. Can it be removed to clean it with brake cleaner or similar?
Recommendations on OBD reader / service reset tool
on my Karoq 2019, 1.5 tsi i had issues to reset service inspection and oil change, oil change i reset with combination of buttons but inspection service i reset thru obd 11. for 10 credits i think which is almost nothing. it is set to 2 yrs and 30000 kms, i dot follow that program, i do it myself at 8000-10000 kms or 9-12 months (urban driving 90%)
- Useless cupholders
Most reliable option (octavia)
go for that octavia 2, 1.9 tdi, do a belt change and other things needed and drive.
Plastic sump plug leaking
10 plugs and tool are less than 10$ you dont change only rubber seal. whole new plug. https://www.amazon.com/06L103801-Removal-Replacement-Compatible-Passat/dp/B0F9KPWKBD/ref=ex_alt_wg_d?_encoding=UTF8&pf_rd_r=17JH5WMZWQ2C8NWT28GQ&pf_rd_p=4e1b46a8-daf9-4433-b97e-d6df97cf3699&pd_rd_i=B0F9KPWKBD&psc=1&pd_rd_w=G9Xr0&pd_rd_wg=YVtPL&pd_rd_r=ee260b5e-eb71-4417-91b9-699f53aed51a&content-id=amzn1.sym.4e1b46a8-daf9-4433-b97e-d6df97cf3699 2€ one piece. https://www.skoda-parts.com/spare-part/06l103801-oil-drain-plug-m14x1-5x22-china-28273.html
Spark plugs
my first change was on 60000 kms, in miles it would be 37000 miles.
- Plastic sump plug leaking
Au revoir, my fellow Kodiaqers!
this is forum where i colected info when had renault. https://www.renaultforums.co.uk/
Are 1.0 TSIs fine with RON91 Fuel (Fuel Lid lists min. RON95)
you wrote its N/A engine, so it cant be TSI, but FSI. maybe you can drive on moderate gasoline. i think in Russia they all drive on RON 92, because higher octane fuel is more expensive. how much HP or kW have your engine? there are some hints: General Guidelines Low Compression (e.g., 8:1 to 9:1): Can often use lower-octane gasoline, such as 87 RON, as the fuel is less prone to pre-detonation. Moderate Compression (e.g., 10:1 to 11:1): Requires a mid-grade fuel, such as 92 RON, for optimal combustion and to prevent engine knocking. High Compression (e.g., 11:1 to 12:1): Demands higher octane fuels like 95 RON to ensure efficient and smooth operation.
Mrs Higgins (citigo emissions MOT fail)
i heard that oil level can harm but never see it. good is to replace PCV valve. probably lambda was faulty..
you dont need any tool to reset service interval.. othervise OBD 11 ot VCDS.
- 1.4 TSI CZDA – Turbo Actuator Fault
VRS Diesel Oil Change
first extract oil than change oil filter if you don have Jack and tools, because always is better that way. you can inspect engine and gearbox for leaks and other abnormalities.. also suspension parts and braakes and tyres..
- Octavia Mk 2 VRS 1.8 TDI 59 plate, low rev rattle
AA Wireless
not sure about ytb music, using spotify works normal.. if you dont have checked unknows sources, app wont even apply on AA display. try to unrestrict battery usange on YTB music, default is balanced.
AA Wireless
Yes, the Huawei P20 Pro supports Wi-Fi 5 GHz, and you can confirm your connection by checking your Wi-Fi network's properties in your phone's settings, usually under Settings > Network & Internet > Wi-Fi. To ensure your P20 Pro connects to the 5 GHz band, make sure that your Wi-Fi network has both 2.4 GHz and 5 GHz bands enabled and that they have different SSIDs (network names).
AA Wireless
here
Replace Steering Wheel
than put leather on it. you can doit yourself, or goto service which is repairing interior. i put this on my karoq wheel https://www.aliexpress.com/item/1005005680456014.html? https://www.aliexpress.com/item/1005009760606619.html?
AA Wireless
first you have tap several times (i think 7 times ) on the bottom where is section "version and permission info" than developer option will be available. it is common gesture for enter additional options everywhere on android phone.
AA Wireless
you have to be unconnected of any wifi network during process. i went to parking of another house to set it up, because i didnt want to turn off home router. you need to be only on mobile data 4G or 5G to connect AA to wifi.
