Alasdair1
  1. Been doing a bit more checking and so far can't find anything worn or loose. Checked suspension bushes, Ball joints, drop links steering and tyres and are all good plus wheels are balanced and no signs of tyre damage or alloy damage. Even put the wheels off my old Octavia on and its the same. Engine mounts seem fine with no obvious cracks or excessive play. Wheels seem solid with no play and bearings are good but still have a wobble when accelerating and worse when about 40-50mph. Seems slightly better on recently surfaced roads so as previously mentioned could it be front shocks? The car doen't roll excessively and seems positive to drive with no knocks or clunks. Also CV joints inner and outer seem solid and no clicks or clunks in forward or reverse at full lock. Really got me beat. I do all my own servicing and repairs but this one has got me. Any pointers would be most appreciated Alasdair
  2. Not sure if its the same as my Fabia but the drivers window motor controls the other windows as well. If it fails then none work. I got mine repaired by someone on here but can't remember the name( might be Breezypete?). Its a couple of components I think a capacitor and a resistor that fail on the Fabia. Put the repaired unit in and no problems. If the motor does control the other windows it could also be a broken wire that comes through near the door hinge. Alasdair
  3. I thought of that but I thought that if the wheels were out of balance why would the wobble disapear when clutch depressed and your free wheeling. Will pop into my local tyre service and see if they can help. They are very good. Been using them for years and no problems. Have only had the car a short time and it started fairly soon after I bought it. Was wondering if it was a shock absorber problem? Its done 100 000 and I reckon its the original shocks. alasdair
  4. Thanks for the reply, Wheel bolts are tight and no movement or sound from bearings. Checked CV boots etc and no splits or noise when cornering. Engine mounts also seem fine. Tyres are good, Its weird it disappears when clutch is pressed and car is coasting? Might be slightly more noticeable when turning corner to left but difficult to tell. Alasdair
  5. Hi there, Have a skoda octavia 1.6tdi 12 plate and have an odd wobble when driving that I cant diagnose!! It doesnt feel like wheel imbalance and the tyres seem good with no obvious damage or misformatioin. You feel slightly through the steering wheel but also through the car as well. Its worse between 25 and 40 when accelerating and seems to almost disapear near 60mph. If I get it up to to a speed when the wobble is bad then I depress the clutch and let it free wheel it seems to disapear so I reckon its only there when there is power to the front wheels/drive shafts? Never come accross this before so any help would be most appreciated. Thanks Alasdair
  6. Cars should eventually warm up to normal temp when idling unless the thermostat is jammed. If theres no coolant in cylinders or exhaust gas in coolant and the bubbles are air then I would think it might be the waterpump. I would check and replace it and see if it helps. It may be that the pump seal is drawing in air or the impeller has failed. Cant think of anywhere else air could be getting into the system unless the pump isn't strong enough to purge it but where did the air come from?? Check the drive belt for the pump as well. Alasdair
  7. Hi there, I got the switch from amazon. https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiQoq3AzNqEAxXdiFAGHXcrDZ4YABAKGgJkZw&ase=2&gclid=CjwKCAiA_5WvBhBAEiwAZtCU7-fUuGIqEA970bsf6t_BV8Pj-7XrQSN02ER_X3r69_BJvt1FE8GzQxoC9HUQAvD_BwE&ohost=www.google.com&cid=CAESVuD2ODbQw4voiM65vAWa3YbiVYXjf6CNCjND_0Px7LktYK2qwuOO13_G4GEsn1R_VcWo1rn53PMj1kqyQZz5MjZzZYEgWdlEG3cIXDP20dmuXwCY88Iq&sig=AOD64_2flMrsUwPrEOmTgNnPFhm2FvQavA&ctype=5&q=&nis=4&ved=2ahUKEwjL6aLAzNqEAxXlQkEAHdD_AwYQ9aACKAB6BAgJEBI&adurl= Hope the link works. It was £12-99 delivered. I use amazon prime so came next day. Alasdair
  8. Just about to do exactly the same on the same model myself as got silly quote from local garages as my friendly one retired last year. Bought a cheap bush puller off amazon. Parts arent that expensive. Was going to reuse the wishbones but they look pretty rusty and as everything else on the car is mint just ordered a new pair for £50-00. Got Febi ones as MOT advise reckoned pin might be worn on arms as well as bush. Got new track rod ends plus ball joints and bushes etc for £60-00 so £110 in total plus puller set (cant rember but around £40-00 which hopefully will get used again. Doesn't look too difficult a job. I reckon local garages looked at the age of car and reckoned everything would be seized or rusted solid and quoted accordingly. I reckon if I can do it for £150 in total its not bad plus I get another puller set to add to my collection. Got the parts I needed from Parts in Motion. Dealt with them a few times and so far delivery is good and everything is correct plus prices seem pretty good as well. Might be worth trying it yourself if theres no-one up for the job. Alasdair
  9. Same here, I sprayed it with WD40 and spent ages pushing it in and out. It was pretty stiff to begin and seemed to stick at a certain point but eventually freed off and no trouble since. Alasdair
  10. If I remember the wipers dont work if the bonnet is open on my 58plate mk2. There is a switch somewhere which may have failed or jammed?? I think mine is under the latch mechanism. Its not easy to get to but perhaps a spray of wd40 might solve it Alasdair
  11. Could also be a weak battery. Mine did similar. Random no start with loads of beeps and warning lights. Battery was failing and down on voltage. Would start the car when weather was warm but on cold mornings no hope. New battery and problems solved. Would still check earth points and get battery checked. Alasdair
  12. Thanks, Had a look at the new ones and cant see any marks. Wll mark up old ones first and compare them if I can get them off. Alasdair
  13. Ah never thought of that. May have to try and remove bolts before cutting to check they hopefully match with the new ones. Have sprayed bolts/nuts etc in a mixture of kerosene and oil for now. Will keep spraying for a few days and try again. May have to use the old blow torch as they are very rusty and seized solid. Tyres on rear are not bad but front are getting a bit worn and needing replaced in the near future so will swap front to rear and monitor until I get the alignment checked. Got to do the front track rod ends and probably anti roll bar bushes as well as bottom ball joints so an alignment check would be advisable considering the price of tyres these days. Thanks Alasdair
  14. Hi there finally getting around to replacing rear swing arms on my 58plate 1.9tdi estate. They are in a very sorry state although still passd the MOT but swing arm bushes do look as though they are just holding on and no more and arms look slightly twisted at the top bushing. Looks fairly straight forward but i cant budge the rear ofset adjusting bolts. Plan is to mark them on the old ones and then cut/grind them off and try to drive them back though the bush then replace with new bolts and new arms. If I replace them in the exact postion that they are in will that be ok or should I get alignment done plus is there any other adjustment on the rear suspension apart from the two top bolts? Thanks Alasdair
  15. I had an old toyota lucida with air bag light on. It was the spiral cable that was faulty but the horn still worked. To get it through an MOT I managed to disconnect the crash sensor unit which turned the light off during ignition and afterwards. I disconnected it as mine was going to be very expensive as it was a Japanese import vehicle. If its the cable I think they are £50-£80 for a fabia. I think they are called clock spring cables. The airbag part of the cable probably failed before the horn and whoever had it before may have disabled the airbag system hence why the light doesnt come on Alasdair
  16. Mine did the same. The small screws that held the switch together had failed. I glued it back together but bought a replacement off amazon which wasn't expensive. Think it was around a tenner.
  17. Not sure but the horn power supply might come from a spiral cable spring in steering wheel that does the airbag as well. If its failing the horn stops or the airbag light comes on. This might explain lack of power to relay and horn etc. Not sure how to check it but if messing about disconnect battery and leave for a while so theres no chance the airbag goes off. Alasdair.
  18. I have an 58 1.9tdi and it did the same as well as an old Volvo940. They both started doing it randomly. Foot would go to the floor but pedal wouldn't return. Pulled it up with my foot and seemed to get better especially if I pumped it. Eventually the master cylinder started leaking fluid which I didnt notice as it was been collected on the undertray and then clutch went completely due to low fluid. It was only when it got winched onto the recovery truck the fluid trickled out from underneath. I reckon that the seals were failing and the fluid was pushing past them. Changed it myself which isn't that easy. Its one of those parts that you can see but can't quite reach. If I remeber correctly its a push on snap fitting for the pipe from the reservoir. I am pretty sure there was a rubber sealing grommet that normally sticks in the old one so you don't notice it and the new one didn't come with a replacement. Make sure the grommet is there before you fit it otherwise it will leak. It could also be the slave but mine was the master. Hope it helps Alasdair
  19. Cheers for the info. A quick update. Havent got it apart yet as need the car. Hope to wedge window up tomorrow to keep me going till parts arrive. By the looks of it looking down from above one of the cables came free from the plastic clip and wrapped itself round the cog that the motor fits into which then snapped off the plastic bits the motor fixes to allowing everything in the door to get tangled and drop to the bottom. Motor fell out when I removed the outer door panel. I managed to free the window eventually and got it to slide up the door but reckon need either a complete unit or repair kit. Might just buy one complete for ease as the old one is in such a mess I dont think it would be easy to repair plus not sure if there is anything else damaged and if I drill out all the rivets I reckon it will come out in bits. Any reccomendation on a replacement. There are a few on ebay but not sure re quality. Alasdair
  20. Might be the connection at the back of the dash. Mine kept displaying weird warning lights so removed dash and the connector was slightly loose. Cleaned it up and reconnected it and it was fine. Noticed the dash had been repaired before which I think is a common fault. Mines an 08 1.9tdi You have to disconnect battery etc before the dash is disconnected or it can activate imobilser as the dash I think is coded to car. Yours may have disconnected itself enough to activate imobilser. If this happens then I think you need VCDS to reset it.?? I would remove dash and check connector. If that doesn;t work then it may be the dash that has failed. There are a few companies that can check and repair them but again may need VCDS to reset once refitted Alasdair
  21. Quick question? As the glass has dropped completely I assume I have lost the original position re up or down or somewhere inbetween. Does it matter when I replace the mechanism on the position of the glass in the door or will the motor work it out? Might sound like a daft question but don't want to put it all back together an then find the window doesnt go all the way up or down. Alasdair
  22. Nothing wrong with that picture. Gives you everything you need to know plus a lot better than I would do. Mines normally a sketch that a 5 year old would do.
  23. Found some OEM ones on ebay for 7-95 for 10 so ordered them. They are the proper ones with the cut outs if you know what I mean. Read online that standard 6.4mm x 1mm dont seem to be as tight. Will see who makes my riveters and get a new nose to fit . Reckon its the cable thats snapped so tomorrow will strip down the door and see. 3.65mm is pretty heavy duty. Must be something to do with strengthing up the door to stop it flexing. Why they changed from bolts I don't know. Not looking forward to it but at least I have it undercover at the moment until my old Octavia breaks down again. Brakes on it this morning but thankfully simple fix. One of these weeks I wont have to work on a car. Cheers Alasdair
  24. On my toyota I used to get a small amount of coolant leaking back into the cylinder once the engine was stopped but once cool the crack would seal itself. To begin with there was a little white smoke but very noticeable. When cold it looked like normal exhaust on a cold day. Eventually it got so bad it hydraulicked the engine. The extra pressure from the exhaust gases may be forcing the coolant out of the expansion hose past the cap and leaving air/exhaust airlock behind. It may even cause a slight vaccum? My coolant did this but the level remained fairly constant. Is the oil cap clean and not emulsified? Mine was always fine as the coolant was leaking into the cylinder and not the oil ways.I would see if a local garage can check if the bubbles are exhaust gases or just air. Hope you get it sorted Alasdair
  25. Thanks for the reply. I was assuming it was the plastic clips but the cable makes sense. Havent had a look yet as its freezing here. Did notice that some mornings the window was down slightly. Same today but when I tried to put it up it went down. Tried pulling it up at the same time as hitting up button and it still went downwards and now seems jammed. Will remove card etc and drill out rivets tomorrow and get a proper look. Just done the window motor on that side which is still grumbling away when I press up or down so I assume its the mechanism.
