Alasdair1
  1. Not injector related but my 1.9tdi did the same. Limp mode all of a sudden with no warning lights. If I stopped and started the car again it seemed to clear the limp mode for a while then randomly it would happen again. Got no fault codes either. It was a seizing actuator/turbo . Not sure on yours but mine is a VNT turbo so either the actuator was stiff or the fins on the turbo were stuck. I sprayed actuator with wd40 and kept manually operating it until it freed off. Been fine ever since. Mine always smoked a little on startup because one of the glowplugs is dead.
  2. Could very well be the clockspring. In my case the airbag light came on but horn still worked. I have also experienced the horn failing first then airbag light. It might be a wiring/connection issue to the clockspring/steering wheel but I am always very wary about airbags. Last thing you want is it to go off while working on it. Check how to disable it or how to remove safely. I always remove battery for a good few hours first. Alasdair
  3. I get that on my diesels when I have changed fuel filter. It takes a while to get the fuel back through hence the beep and oil pressure light until it starts. Did you change the fuel filter when servicing it? Just wondering if its an airlock or perhaps fuel pump problem or if the filter is choked. You could pull a spark plug out after cranking to see if its wet with fuel. Alasdair
  4. I bought a cheap one off amazon. It was only £15-00 . Not sure how accurate it is but it shows if compression is low or if one cylindesr is a lot lower than the others. I got it to check a very old LPG forrklift and luckily it showed all cylinders were about the same and reasonable. Turned out it was the distributor . I got this one but in an orange box, For £15-00 even if you use it once then I reckon its paid for its self plus its a handy tool to have. https://www.amazon.co.uk/gp/product/B07RTY7Q1R/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
  5. Not sure on the votage when cranking engine. I have in the back of my mind about 9.5-10 volts. Anything less would point to a failing battery or one thats needing charged but if it cranks over at a normal speed then I would assume theres enough for creating spark etc.
  6. If its cranking then the first I would check was if your getting a spark, Next fuel before doing anything else. If it was running well before then its most likely something that you have missed or disconnected/dislodged. Check the strip fuses at the battery and wiring. Alasdair
  7. Are you sure your getting a spark. Connect a timing light or similar to check. I have one of these in line spark checker. Might be that you pulled the main HT lead when changing plugs or distributor problem? Alasdair
  8. An inspection pit is ok but can be dangerous unless you have extractor fans at bottom unless its built with an open end with a sloping floor. Petrol and other vapours sink and can collect at the bottom. One spark and you could be toast! I was going to build a couple of concrete ramps above ground instead and hopefully work out a way of fixing a jacking beam. Alasdair
  9. Did have a look but personally a four post lift for me is what I'm saving for. I dont have the height but I hope to either build a garage or raise the
  10. I had problems with injectors on another car and luckily we have a pretty good perkins engine diesel specialist locally. They only charged me £10 per injector to test pattern and release pressure etc. One was faulty so I bought a recon one. If your getting someone to do the injectors you could get them to replace glowplugs at same time. There not that expensive but can be a pain to get out. Worth a bit of penetrating oil from time to time before trying to remove. I have one on my old octavia thats failed but so far the car still starts. Can be a bit lumpy for a couple of secs and slight smoke when starting in really cold weather. Good call on getting injector loom checked as well before replacing injectors. Alasdair
  11. I agree so far I have had three octavia and two fabia. Only problem I have with octavia body is rusty front wings and also where the sills meet the wheel arch near rear wheels and front wheels. I did the timing belt on mine and the amount of crap stuck behind the plastic wheel liners causes the problem. I removed all of them and powerwashed as much of the inside including the sills as possible and treated with waxoil then also undersealed anything that the liners didn't cover. Be a lot easier on a ramp though. Alasdair
  12. Thats a very nice job. Did it once on an old volvo940 and it drove like new and also lasted for years. Need to do that on my 2012 octavia estate before it gets too bad. The older 08 plate I reckon is now past it. By the time I rubbed it down and treated all the rust its going to be cheaper buying another one plus guaranteed I would find a few holes that need welding which I am not very good at and hate doing anyway. Got loads of space at my place so old cars just end up sitting as parts donors. It is turning into a bit of a scrapyard/graveyard though but has saved me a fortune over the years. At the moment I have 8 various vehicles or so called projects plus 2 on the road. Saving up for a 4 post lift. Alasdair
  13. I had to replace slave cylinder on mine when doing clutch and when bleeding it afterwards found the fluid between the reservoir and slave cylinder was very old and dirty probably because it had been in the pipes/master cylinder after the reservoir for years or perhaps the seals in the slave had broken down and contaminated it. Its fed on mine from the same reservoir for brakes. I kept bleeding the slave until I got nice clean new fluid coming out. Didn't want old dirty fluid in the new slave cylinder in case it damaged seals.
  14. When bleeding slave keep going till fluid is clear again. Mine was absolutely awful. Almost a dirty green/brown colour. Reckon it was the same fluid from new and that would have been over 18 years old.
  15. High chance its a DMF flywheel unless someone else has converted it to solid. Have seen a few posts where folks convert it to solid for reliabilty. I had a fabia 1.9tdi that was DMF and luckily the flywheel was still in perfect condition when I did the clutch so just left the DMF in place. If yours is rattling then reckon its on its way out. You can get a full kit and personally I would use Sachs,Luk or Valeo. Check the condition of CV joints and gators and drive shafts etc and also Wheel bearings while your at it. I did my sons in his fabia and got a cross engine bar that goes across front wings from ebay to support engine and gearbox. Made life a lot easier especially raising box to get it back in again as I did mine on axle stands by myself. Changed a front bearing while I was at it. Not sure what more has to come off for the octavia. I would personally change the slave cylinder while your at it. If its like the fabia its external mounted but push rod and gator are internal so if it fails or leaks then it could contaminate the new clutch. Can't be much original left on your car judging by the pile of bits. Well done, bet it drives like new now. Alasdair
  16. If the internal switch works then I assume the actuator is ok. It could be as said be control module but it may be that the sync of the keys didnt work. I took ages with my Seat to finally get them to work. I only had one key and tried a You Tube method. It was on a SEAT Altea but might work. Put key in ignition and turn to position 2 (dash lights on but don't start car), Leave key in ignition and lock car from inside using door button, Press lock on key fob while still in ignition until red light on key starts flashing. Remove key and unlock car. I did it with rear windows open in case I got locked in. Can't get the wing mirrors to retract but everything else works. Alasdair
  17. If the EPC light is dim or flickering it may be similar to the few probems with an octavia 1.9tdi I have DPF light flickered and was slightly dim as well as ABS and also engine managment light. None were bright but almost half bright. Turned out to be a bad dash connection at rear of cluster that was throwing up random warning lights. There were no fault codes stored. I stripped out dash and cleaned the connector to the cluster with electrical cleaner and reconnected and it cured it. I worked out it was electrical as my octavia didn't have a DPF being a bxe engine. Make sure you remove battery before disconnecting as on the octavia you can enable the engine imobilser if you try to remove the dash. Not sure on the fabia but better safe than sorry Alasdair Before looking at dash Just remebered that there was a small rubber pipe from under engine/removable cover on my sons fabia. Its about 10-15mm and goes from the engine cover to I think rocker/manifold. Not sure what its for. May be a crank/rocker breather pipe but might be worth checking its connected and not blocked.
  18. MIght be the door lock actuator thats failed. Have the same problem on a Seat Altea. Something to do with a circuit board or wiring in the drivers door. Also my 2012 Octavia only unlocks drivers door when button pressed. You have to press unlock again to open others. not sure where the locking control module is. Maybe drivers door or in dash.
  19. reseting cables only takes about 10mins. Worth a try. Also Not sure what linkage you have on top of gearbox but I had a SEAT 1.9tdi bxe with a plastic selector that I didn't realize was seizing and very stiff to get 3rd and 4th gears. It eventually snapped I should have lubricated it. Might be worth a look. The one on my sons fabia is alloy/steel. Alasdair
  20. Good to hear. Had two blow over 24hours yesterday. Going to pick up a coupe today. Unusual for both to go but thats cars for you. Have been using 150% but might try the 220s. Problem I have is seeing verge on the roads around here when cars come towards you with superbright LED. They seem to cancel out halogen plus they just resurfaced our road and theres no markings (been about 2 months) and the tarmac they used seems to absorb headlights and not much grip. I reckon they used the wrong grade as we now have danger slippy road signs for about 2 miles on the corner sections. Alasdair
  21. I use breakerlink or parts gateway. Make sure the quotes include mileage/age etc.
  22. Glad you got it sorted and it wasnt any wiring fault. Shouldnt be too bad a job to change switches. Alasdair
  23. Did he say what had caused the wire to burn out or was it the ignition switch. If it was a wire I would be a bit worried what caused it. Alasdair
  24. the one ordered appeared identical visually but they said it wouldnt work it was Reference OE/OEM Number 6Q1 423 291 A, 6Q1 423 291 E, 6Q1423291H The above 6Q1 part numbers are probably all the same and perhaps newer versions but I reckon they are from LHD as Pete pointed out. .Yours is 6Q2. The LHD ones may fit but not sure. Found a site https://oemwolf.com/search/?search=6Q2423291&search_mark=0 that if you put part numbers in it sometimes tells you its superseded and gives you the new one. 6Q2423291 became 6Q2423291A then 6Q2423291AX . You could also try https://www.stevensvwspares.com/vw-online-parts-shop They are a VW breakers and list 6Q2423291 as from polo hatch 2002/2003. Says stock check required. Alasdair
  25. Might be worth checking and cleaning the connections if its failed again. It could be an eletrical problem. I use a contact cleaner spray. Have had a few problems on older skodas and its been a bad connection.
