Tell
Everything posted by Tell
  1. Seat's showing the June 2022 at the minute which is 21.7 according to the documentation. Its that YY.MM which must be in the file that i'e yet to find. That website is a year behind the VW one. I started this thread off on the Seat side with information on how to do the offline maps with the VW direct link, saves registering: https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib3-satnav-offline.472408/ I reckon it's the NDS file where the YY.MM is why I brought @pcbbc into the conversation since they have a script to read them. I'd have a go myself if it was in there....
  2. @MartiniB Hopefully this link will work for you https://www.seat.co.uk/owners/your-seat/navigation/map-updates Interesting it gives assorted file links for each screen size. Without seeing the release year as YY.MM I'm advising people to stick with the VW direct mib3 map file links since they are always the most up to date for mib2 if you don't have the connect services contract. I suspect @pcbbc would be able to read within the files to find the YY.MM. It must be in there. We have established like mib2 high, mib3 Map files are interchangeable across the Vag brand as expected and for mib3 there is no mapcare issues for Seat as there were for mib2 high e.g.. same status for updates as VW and Skoda. Not sure of Audi. Income generation for map material is via connect services now for the brands. Last time I looked the Skoda download was very old. I'm think similar to your mib2 high offline files, the mib3 direct links can be usefully published.
  3. It could be they are just feeding more data, Inrix via the FM broadcast is showing more data than Traffic Master ever did. As I mentioned before I reckon there is a market in travel data these days so it's bought and sold between providers.
  4. As long as the eBay seller isn't a rip off merchant you will have no problem with any of the three brands they are interchangeable, all recognised.
  5. First the pinning of MartiniB thread by the mod has gone a bit side wise for the last year so the June 2023 files are on this thread If you aren't driving across the breath of Europe use the second file down. If you need all of Europe buy a 32gb Skoda or Seat or VW card, makes no difference they all have a VAG CID on them that the unit will read and say, yes this is a valid map card. You can't use any old SD card. If you buy a new card, just take a copy of it. Then do a delete not a reformat. With the zip file, unzip the contents and drag across to the SD card. Job done.
  6. GB solution if anyone is casually reading this is further up the thread or the French solution above which PCBBC helped out with.
  7. Should have read "did for you"... sure we have AI now that deliberately messes stuff up 🙄.
  8. The French solution to your own disappearing TMC that PCBBC didn't for you. I guess that's only the French solution the GB solution is further up to clarify.
  9. For mib2 standard V12 if a Mib2 high (Columbus in Skoda lingo branding) you can use the latest maps for that. Both solutions on the thread thanks to the two experts on the thread .
  10. Indeed it would be nice to get the TT 5 years for sure (2023+5). I've been working on 2020+5, worst scenario would be 2019+5. You'll have to point out where the TT file server is 🤔. Audi people turn up on MartiniB's threads after doing the AOL firmware update / Mib Tools... I cant say I follow Audi boards but note they have a navigation FeC upgrade when they arrive. Seat and Audi still operating mapcare limitations. Seat / Cupra lifted it in the final period on their production models.
  11. MartiniB you haven't managed to find where the YY.MM is published in those files. Reckon it's not in the ascii readable ones. @pcbbc add our software expert to this. This is the question of which is most up-to-date Skoda, VW or Seat.
  12. The solution is to fix it yourself since the maps are basically a legacy product, not too long to go on updates now. VAG have this ability too drop support pretty quickly as they move from mib 2 to mib 3 in 2020 so pretty unlikely they would have lifted a finger. The official user POI import and destination import went in circa 2020. They keep the map updates going historically 5 years after moving onto the new mib which changes the map updates. Now 3 years into that. Thanks to pcbbc and bigade1 user solutions exist.... enjoyed the narrow lane messages this week on a mib2 standard. I'm sure Traffic Master didn't have that one 👏. It is useful. Swapped the maps over since one knew one was heading into a busy part of the world.
  13. 👍 😍 😉 I normally fumble about in there looking for mib2 standard and mib2 high. Sure stuff gets moved about. There is the answer then. The go to place.
  14. If users POIs you either get all of them or none by toggling on and off. You can create your own user POIs for import with Poinspector. Needs some effort to setup but works.
  15. It's an entry level mib2 as you probably know. True not much on it. Normally you would look on the mibsolution.one web site, Guest, guest. Nothing springs out.
  16. It's in the map files those segments of road which have a set of flags that can be toggled on and off are not implemented in the mib2 standard map files after V12 for Inrix as TomTom cartography files that are used didn't get it implemented. Guess whoever prepares the files for mib2 standard (it's a commercial company) streamlined their systems to just import the traffic master files. V12 were based on HereMaps and included the flags for Inrix. Pcbbc described it in the thread. Why the Ozzie solution also uses V12 for that reason. Pcbbc who produced those two files short cuts the need for mib2 standard tool kit which the Ozzies used in their solution which was got working in the UK. The toolkit approach washed the files through the system whilst those two sets has the washing done for you. Clever guys on the thread.
  17. Why I said visually check for file structure. Short cut.
  18. It's whether it's a mib2 standard which these files are for.
  19. Well if you take a copy of your map card and try the new file you won't have lost anything. What you replace it with unzipped should look like what's on it now on the file structure, if not, it's not compatible. Pass on what an RNS315 is exactly.
  20. How it works. Pcbbc is the expert but it populates those geographical tags and updates them. The radio bandwidth limits the speed that it comes down at. Hence it builds up over a short period.
  21. Mib2 standard the SD based one you need V12 and patches on the thread. Mib2 high, the Columbus one the coding solution will work with the latest maps or anything before. The SD solution you trade latest maps against TMC. You can put it on another Vag card and use the solution that takes your fancy on the day of driving.
  22. The conversation goes on a bit from that point. I guess you look to see what is in the V2 fragments using those tools / code / python against what was in it previously.
  23. I suspect the clue is in here but I never looked to see how he did it... We await his arrival. Too old for programming now 🤣.
  24. @bigade1 and @pcbbc Bigade1 got it working using the mib2 standard tool box and VCDS coding. Pcbbc removed the need for the tool box by recompiling those modules.
  25. @pcbbcon your Techinsat has recompiled some files to make it work in the UK. Are you sure if you don't do the the v2 solution posted above it doesn't knock you onto the other group which would work for you?. The fix might be already here. You use v12 maps linked above plus replace the modules as shown. Might be worth a try. There is a grouping of TMC providers which might include the one you want. Basically VW one's were "free", the others are "pay". If your target is in the pay one then you might be fine. On the mib2 high, if the 15->14 works on the disconnected suspect that the mib2 standard fix will work.
