Tell
Everything posted by Tell
  1. We want all of this stuff if enthusiasts are going to crack taking mib3 maps and getting them into mib2 high maps for the day VAG pulls the plug on mib2 high maps. Need about 15 years on built in maps not 5 years. Where their support is woeful on products. A car will last 15 years, not 5 years as they plan, or less if you need TMC.
  2. Hopefully we'll get an answer that doesn't involve the toolbox and works with the latest version 🤔.
  3. Better not vanish in the next two weeks till I get home.
  4. Going to be the AS platform extended to V12 http://wiki.ross-tech.com/wiki/index.php/VW_Navigation_System_Maps#Platform_AS
  5. They normally twiddle them around in the naming so I reckon MartiniB will find them.
  6. Looking for v12 @MartiniBfor @bigade1special sauce above.
  7. Thats one for @MartiniB I did start looking but with changes in servers. If @bigade1can say what it is then I'm sure MartiniB can find it. The Ozzies were using 8021 we would need 8020 for Europe if that's the last working one we are talking about.
  8. I'm still interested in the mib2 standard solution. My experiment didn't get anywhere. Wait till @bigade1publishes their fix but that if it uses the mib2 toolbox / kit whatever will be fussy to the firmware installed and as you say we are told old maps. I can see as I have said before you could run a two card system if you could use your old card if you needed TMC and the latest maps if not. Depends where you are driving. Mib2 high is a more flexible system to configure into another TMC provider set. It's the way it was setup to do that. On the thread we have mib1 solutions the same as mib2 high (the non SD card system), Just leaves mib2 standard and any pre mib ?. Pass on models prior to mib1. Most youngsters don't see a need for built in satnav using Android Auto / Cap Play so it's not really a concern if your car supports that, it won't affect second-hand value. Others want to be able to get in and drive without fumbling with the mobile phone or are driving in locations where 4G is patchy / abroad. Depends on whether you are in the first group or the second group. I would not trust my mobile device to operate in real time. We await @bigade1
  9. On mib2 standard not that I'm wearing my auditors hat but ID 12 editting into the ID 15 bank would look promising. It's missed out of the non online bank, the 15. But appears on the online bank of codes. That feels to me its being offered if you have the online subscription but not if you don't. You edit 2 to 12. Bit of a synergy going on there. Toss that one in. Whether you need old maps, pass. I'm probably going to be told I'm wrong.
  10. Mib2 high maps are locked down from tinkering the files by the signature, Mib2 standard are not. VCDS locks into coding thats already in those files. The toolbox stuff allows you to fiddle with the material once in the unit if VCDS coding isnt sufficient. For the mib2 high and mib1 standard VCDS does the job.
  11. Scrap... 🤣. The AI that Android uses on word correction these days has a sense of humour.
  12. There are web pages on that but will probably cost you £800 or something. East Yorkshire Retrofit use to sell mib2 highs but now they don't like them. It was a popular thing to do to retrofit a mib2 high inplace of mib1s. You can't pick one up of a crap car place since they have to be prepped so they are no longer linked to the car they were attached to. I'd wait for that Mib2 DIY standard solution. I wouldn't hold your breath on any official solution.
  13. No the download is protected by the sla1 bank of signatures that you see. Whilst @pcbbcthought you can make changes looked at it several years ago and concluded it wasn't possible. It's an encryption method. Clever method using pure mathematics you'd study if you were doing a degree in encryption or pure maths probably. Would be a GCHQ sponsored degree. They can be cracked by brute force methods with Cray computers. That was a few years ago. You have a private key and a public key. The public key is used in an algorithm to test that the files with the signature are valid and unchanged (where the pure maths comes in). The public key used by Vag is known but thd private key isn't. If you sow them up with your own private key the unit needs to know the public key. That is obviously locked in the unit. The weakness was that Vag left a loop hole in the POI import. Any additional code can be added to the POI import and it sales into the unit as being valid code. No signature check is made. Those Mr Bonk group members found this so the toolkit for mib2 standard and high exploit this. The guys have now gone on to produce their own modified firmware identified as AIO, if you check that firmware it has no signature but tumbles into the unit on a POI import then bumps in on the back. I don't think anyone has rewritten a map import on this basis. All the checksums have to be recalculated since it uses them but you wouldn't need the signature check. Clever soles that write the AIO firmware. That's used fairly commonly now. Doesn't please Audi who employ contractors to chase the file releases down. Those toolboxes having got into the unit marry themselves to the firmware using a developers hook. Each firmware release needs its own module written. The toolbox checks whether it has one for your firmware, if so you graft it in. If not a kind mib2 enthusiast may step forward and write the piece of code. That's what someone did for me a few years back. They then added my firmware release module to the release. They may have automated that now. The mib2 high package then gives you retrofitter options. This is where the Ozzie people wanted their code added to give additional functionality. As it is we don't need this for the UK task on the mib2 high unit. Just simple vcds coding is required. These are the public keys in all VAG units. They got published on a web site. It doesn't do you much good though. You can hand crank the logic with that module function. Eigenvalues and eigenvectors or something. A few years ago since I did my maths degree. Thought I'd raise to the occasion and with the help of a crypoto website worked it through. Somebody else fancied changing the primary key in the unit this was before the Mr Bonk stuff came out where you just bypass the SLA1 signatures. The secondary key is in a chip that can't be changed so that approach doesn't get you anywhere. 9a 49 9b 04 8b ae bf ac 83 3f de 81 ba 80 30 93 05 b6 6f ed 54 59 c3 8f 60 f6 10 a9 aa 5a 19 10 05 17 05 8f ea 49 d3 75 e3 f9 e1 54 4e 17 ee c9 c3 c1 dd 7d 30 16 de b1 55 45 fd 9e 18 00 51 22 d6 a1 33 10 95 c0 dd cf 43 a1 c2 fe c0 bc aa 1c fe 48 49 25 89 9e dd 71 b0 d4 08 cf 16 bf 10 e2 e1 bc 70 a3 52 f2 e6 54 0b 60 05 5a a7 52 ec 4a 83 65 f7 68 19 66 f4 d5 46 c7 38 b1 6b 5a 1f 13 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 1e 0b 93 73 dc b4 93 b6 12 ce 09 c4 03 e9 21 fc 9b 4e 97 ce 55 c5 b4 c0 80 ad 17 2d ca 91 4d c1 87 45 52 ca 4a 95 96 9e 61 ff c3 24 a5 91 5b d1 83 80 85 90 8f 99 8f 76 ba 5f b2 09 86 db 86 c1 b5 89 b9 58 75 4e d5 d5 aa 08 af 2f 16 3e 33 a6 c6 46 77 dd 32 e0 98 f0 ec f9 14 6b af 35 05 3c 23 aa 8b a8 76 fb 2d 0c 6e d7 2f 0b b3 dc 77 6e b8 74 14 1c 95 c1 6f ff 0c bb 4a e9 ee 70 a2 3c So yes you can hand check that the unit is going to reject your modified update before you load it up.... as said this was before they found the POI import approach.
  14. That 14 also works for mib1 Amundsen (that will be all mib1 standards with the final map update) as reported on the thread and I suspect the mib1 high as well. Perhaps a surprising finding. If its a mib1 standard without later maps you'd have to update the maps first, I say that since I've got a pretty original mib2 standard map without tmc (~2015). They must have rolled out tmc later since I find it in those copies. Seat we need a file from the early maps to fix when people loose their map card to repair the unit. A mapcare thing.
  15. Reckon you wont get away without coding the head unit on any solution.
  16. It's April 2023 when it went. Yes @bigade1 I'm willing to wait to test it on the mib2 standard that's Amundsen for Skoda folk, Discover Media for VW folk and Seat standard for Seat folk. The mib2 high fix for Columbus, Seat Plus and Dicovery Pro for VW folk is the re coding posted by @pcbbc 32783 is online traffic permitted + Trafficmaster RDS TMC 32782 is online traffic permitted + ITIS/INRIX RDS TMC 15 is NO online traffic, Trafficmaster RDS TMC 14 is NO online traffic, ITIS/INRIX RDS TMC Those work on Audi as well. For that one the golden rule is if you see a two number code in the TMC coding slots it's going to be 14 to go in there. Five character it's going to be 32782 On the last one Pcbbc had a different original 5 character code to David55 but the the fix was 32782. It's just the may VW and Audi had set it up. The example on a mib2 high using Obdeleven Pro I posted above. The 5f menu, adaptions, search tmc. Look at the code. Replace. Reboot unit. It works.
  17. Yes itis is Inrix Inrix took itis over so the files are in the old terms. https://inrix.com/press-releases/inrix-completes-acquisition-european-traffic-company/
  18. Try it. You need to do the long reboot after. You find your 32771 code listed in the tables here: https://github.com/Mr-MIBonk/M.I.B._More-Incredible-Bash/discussions/69 If that doesn't work I'd look at those tables for 32771 and find one with the same option but Inrix / ITIS. You can look inside the file as pcbbc suggested to me. Thats where the Mr Bonk people get the logic and codes from. Had a look at the posted tables seems only suggested model answer... 32782 Mib2\NavDB\mapStyles_eu\0\default\x\navigation_styles_XX_EU.iso and look in folder Ti for file paytmc.json The actual logic is that. Not at home you may find something different but the Mr Bonk posts look like 32782 although that's listed against China 🤔.
  19. Well there you are. I was going to have a look at the mib2 standard that we have and go searching for tmc in 5f although I thought the great and the good on the Amundsen mib2 would have done that. So from your post mib1 standard is kitted out on the map side for that change. May not be the case for the mib2 standard which is why old maps and the convoluted approach since the Inrix provider is said not to be in those maps after TomTom took the cartography over. It was easy enough for me to test out the 14 setting on my mib2 high when pcbbc and I were on the same page. Credit pcbbc to that I flagged my factory set mib2 high was on 15. The chestnut we'd had with retrofitters getting it wrong.
  20. Nifty if it did since it would have to have the radio station names against the ids. Feels like wishful thinking to me. It could say found two but don't reckon it would index out the station name. Hearsay evidence.
  21. Technical note on mib2 high for people that trip into here the tables in this post below cover why other posts elsewhere on the net don't get it to work historically on UK Traffic Master (doesn't work now in anycase) - they were trying the wrong codes. Mr Bonk et all are the enthuast source of all things mib2 high. It covers all TMC codes across the world. For the UK the mib2 high ones are the ones posted above for the alternative service still transmitting. https://github.com/Mr-MIBonk/M.I.B._More-Incredible-Bash/discussions/69
  22. If its a Columbus mib2 / 2.5 it's the above following pcbbc research. You'll know what to put in the tmc field by what's already in it. Then you take one of the two routes. Namely you make the change: 32783 is online traffic permitted + Trafficmaster RDS TMC 32782 is online traffic permitted + ITIS/INRIX RDS TMC 15 is no online traffic, Trafficmaster RDS TMC 14 is no online traffic, ITIS/INRIX RDS TMC (It's so easy with Obdeleven Pro / VCDS coding tool) If its an Amundsen mib2 wait for those instructions to appear on here.
  23. I believe you just do the pcbbc one if your unit is a Columbus 2.5 and don't want to take out a subscription. Namely you make the change: 32783 is online traffic permitted + Trafficmaster RDS TMC 32782 is online traffic permitted + ITIS/INRIX RDS TMC 15 is no online traffic, Trafficmaster RDS TMC 14 is no online traffic, ITIS/INRIX RDS TMC 2.5 Columbus will be like the TT 32782 to get it working again. The latter line above is for Columbus Mib 2.0. Ie. Mib2 only You just search for tmc in your Adaptions in the 5f unit least in Obdeleven and see what it's set at. VCDS Will be the same. Will currently be 15 or 32783. Do the change and reboot the unit. Simple.
  24. The latter which it is. The service collapsed which was being offered across brands. The new pricing model for mib3 is to sell connect services through 4g, the Traffic data on an annual subscription whilst the old model was to cross subsidise it via car sales. I was trying to determine whether mib3 also allowed tmc as well. If it does and dependent on whether the infotainment unit can be accessed via coding then the pcbbc solution may exit for that. It could be that, that has collapsed. Step forward mib3 users as to whether there online data has stopped as well.
