Everything posted by Tell
Columbus Map Update 2021 (MIB1/2 HIGH)
Those are TomTom screen. Mib2 High (Columbus) is Here Maps. You probably needed to post on the Mib2 standard thread (Am... whatever). ;). Your problem is the validation team arent set up to correct towns incorrectly marked up as hamlets etc. They probably sit in India, the Here Maps ones do but have local representation.
- Columbus Map Update 2021 (MIB1/2 HIGH)
On your second method and its got to the point where it's showing Y or Yes against the navigation attributes (Eggnog, NavDB etc) and not Err or an N or No means you are fine to proceed. It's the developers menu. You either leave the engine running or you follow a strict come back to the car every 15 minutes and open the door (the later I do) this forces the Infotainment unit to remain powered up. Power drops every 20 minutes if you don't open the door. Basically I start it off, come in doors, give myself 15 minutes, go back out, open the door, check, go back in the house, come back out 15 minutes latter.... and watch the finishing touches or go back in the house for another 15 minutes. Once it's finished the menu can be a bit ambiguous least on a Seat. Generally when it appears finished give it another 30 seconds or so and power back up using the on/off. That's the retro-fitters method if you are using the developers menu and don't want the engine running. Generally the drain on the battery isn't much so I would worry about flattening it. Just remember to open and close the door every 15 minutes :). The Y / Yes (which ever it is) on the attributes is important since if you see Err / N or No don't start it off since it's done a validation on your file and decided it's not going to work. If you install like this then it will delete the map in the unit and it's then empty or in the Seat case that still uses Mapcare your navigation FeC isn't valid so the map uploads into the unit but is suspended within 30 seconds of selecting a destination and starting navigation off.- Amundsen Mib2 Map Updates 2021
That's definitely mib2 standard and the most recent map is 1520 as per the link. Covers all of Europe. That's the 2021 release to all of the Vag group. Cartography by TomTom. Fits onto the existing SD cards (16gb) doesn't need the newer Skoda 32gb unless you reformat the card to NTFS or alter the sector size from the default to something larger. Neither should you do if you follow the Vag pdf I linked to above. The cult of making it difficult for yourself by going off pista shouldn't be followed. Acres of that on the German community Skoda board... like fitting the wrong spark plugs or lowering tyre pressure to make the ride less bumpy.... Skoda say that release / the one before is for 32gb cards only, that's been found to be wrong. At some point the all Europe map may not fit on 16gb cards and in that case you use a zoned release if planning to drive across those zones or just buy the Skoda 32gb release from an ebay seller. The card is clipped to read only so doesn't grow once put inside the infotainment unit . All good to June 2021 when one looks for the next VAG release.- Amundsen Mib2 Map Updates 2021
If it is indeed mib2 just use the first link in the post namely http://navigation-maps.volkswagen.com/vw-maps/DiscoverMedia2_EU-AS_1520_V13.7z You should always take a copy of the contents of the card before deleting and bare in mind the Mac instructions. Pretty imperative to do that. If a PC best to use 7zip for unzipping than anything else. Mib2 releases run in the sequence of four characters. The above one is 1520. If your release when you press the info button whatever that is on a Skoda is two characters long then it's definitely a mib1 and not mib2. Mib1 for November 2020 was not published by VW, yet to be confirmed that mib1 releases have come to an end, but may be the case. The lack of Skoda mib2 release for November may be related to Skoda publishing six months later than VW. Since there was not a standard mib2 release in June 2020 by VW, the sequences of Skoda's releases may have fallen foul of that. 67 plate would put it at mib2 by my reckoning.- Amundsen Mib2 Map Updates 2021
Generally Seat lags behind Skoda but this time round they got their act together. Skoda slipped a release back from last time round as I recall which meant they could offer something new which was old when VW didn't make the June release. Possibly the Skoda November release was going to be the June VW release but since it didn't happen in June, didn't happen for Skoda in November. All the same standard releases between brands. Skoda has a good library of back releases which has its uses, so not all doom and gloom. I'm not too sure how interchangeable the mib3 releases will be between brands. Needs someone to try it who has a mib3 and can find the import menu and takes a file off the VW server and report back.- Amundsen Mib2 Map Updates 2021
4kb. If you haven't changed it from the manufacturers size it will be fine, but other than you have to take it back to the sector size as supplied. Obviously it has to be the VAG card. When and if VAG pop the 16gb card you just buy a 32gb Skoda card off your favourite e supplier and put it on there. But it didn't happen this release. Dross deleted from the maps as well as new stuff, so the balance is still below 16gb card format.- Amundsen Mib2 Map Updates 2021
It's probably an unusual one for the team or they are not shifting from their belief that it's a village. Might be beyond their scope of what they can edit on their screens. I'd email them next if you feel strongly. Getting all mine throu but then I've never asked for such an edit. Just the normal stuff of missing roads, roundabouts, incorrect street names etc. Just speed limits they are tardy about changing I find. I'd ask you you but then I might get a negative score so I won't which would effect my future edit requests .- Amundsen Mib2 Map Updates 2021
I get road changes in and extra roads. Doing quite well at that at the minute. There were a few month a year or so ago when they were not doing any updates from users now they are. I don't know whether they have a user group or an email option. We know what the issue is, now just a question of communicating it to them.- Amundsen Mib2 Map Updates 2021
I would keep at it quoting the population size of those places (wiki links) and query whether they are using a village label rather than a town / city label. That's what's happening. I'm getting mine thru but I've never picked them up on the size of labels. I think they are Indian staff that do the validation. You probably got one who doesn't know how to change the attribute... wasn't on the screen they use, never has done it. If so they need to refer up. Although I can't believe they can't do that themselves. Just don't know how.- Columbus Map Update 2021 (MIB1/2 HIGH)
It's whether you are a user of maps or a crowd sourcer. You don't need to crowd source to use the maps but if you want to add back something to society you get a login in and contribute. Google also allows you to report inaccuracy as well. There maps are also crowd sourced. The cars going round happens from time to time with all providers. Once set up they will send a car down where there have been major changes they know about to check the precise road layout. It divides into people that moan about digital cartography and say X is better than Y and those that get a login and do something to improve the maps for the common good. That estate that John found had been put on by a crowd sourcer in their spare time for sure. Have a good guess who that was, a retired lorry driver. Suspect you won't find it on Google Maps. There was one estate round here that had been left off Google Maps for ten years (ditto Waze). I put it on Here Maps and TomTom but didn't tell Google for two years as a test of their abilities. In the end I told them with a sharp note to make up for the roundabouts I tell them about but they reject since their validation team is rubbish. By that time an aerial image that showed the estate had appeared previous cloud cover. Mapping companies are dependent on crowd sourcing once they have the maps set up. They do digitally cross check with each other. Run trace checks to see why they have phone tracks and GPS tracks in places they don't expect. Google being a marketing company is good on commercial POIs, lousy on non commercial activities as far as POIs. They don't invest in uptodate aeriel images which is why they lack road details. They can't validate user input since they can't check with aeriel images they don't have which are up to date and as far as the UK is concerned don't know about OS commercial planning maps. Certain amount of validation is run out of Indian operations... logically too remote. Needs boots on the ground.- Columbus Map Update 2021 (MIB1/2 HIGH)
Actually Tomtom did believe me when I came to enter it again today - must have passed their validation with the developers website and plan. Just not as yet passed into their production run. Nah so I keep TomTom and Here Maps up to date but let Google rot .... just to see how long it takes for them to catch up.- Columbus Map Update 2021 (MIB1/2 HIGH)
I would have put those in myself (but didn't btw) but you do run the risk of those bollards. If the aerial image tallies with the developers plans then I reckon it fine to digitise them in. You often get the house numbering on these part developed estates on the OS planning map where the houses are finished and the building block in shown. Then a chunk left grey which you might find on the developers plan and the aerial image of the buildings / concrete down, so digitise that in, then review again for house numbering latter. My pet brown field sites of old steel works . Dark winter month tasks or lock down . Find an executive development today on foot for house numbering and street name. TomTom don't believe me since its not on the OS planning map yet, probably also have old aeriel images. Here Maps do. In the postcode directory already. That's the other validation tool, house numbering and house names. Google / TomTom get street names wrong. Working round the house numbering on the OS maps and postcode directory also points to when the digital naming is incorrect. Oh what fun digital mapping is. Side hobby from a work interest many years ago when I set up digital mapping for planning purposes.- Columbus Map Update 2021 (MIB1/2 HIGH)
The later is not suppose to happen. You could see whether you can navigate onto them. They have the outline sketched of planned routes being built but they are suppose to be excluded. It can be where crowd sourcing people get a bit bloody minded and they slip through validation. Shouldn't be included till open. Tend to think new housing development where they have a barrier up is fine if it's the eventual road and not a thru road - development plan needs to be looked at - if not again people digitise the developers roads on housing estates but not the final road (you see that on Google but most of the where aerial images are incorrectly interpreted). There are a few nut case crow sourcing people that digitise mud tracks as surfaced roads then if they join to an actual road and they get thru validation that's how you end up on mud tracks in rural areas. (Report those to get them out with photographic evidence ideally). OS small area planning maps often via council web sites give the final road layout but may not tell you how it's surfaced, one way systems (obviously and speed). Bollards are shown thou for pedestrian only roads (word "posts")... again a mistake armchair mappers make in linking up roads across estates. Google had its car up a mud farm track locally which is why I see Google drivers bouncing down it . Then the armchair mappers come in see it on Google and incorrectly digitised it as a surfaced road. You notice the armchair mappers run out of steam where there is tree cover or the images aren't good. Roll for weeding out rubbish as well as putting in correct stuff via Mapcreator.- Amundsen Mib2 Map Updates 2021
Any consolation Seat are the same. Fob people off telling them to use a phone app. In the UK you aren't even suppose to be able to update the maps since Mapcare isn't supported. VW and Skoda burried Mapcare some years ago making map updates free. Seat charge abroad via using Mapcare to block updates. Mapcare isn't supported in the UK so either a dealer one off fee for one map (£200s) or if it's the standard system you can use a user discovered "workaround" where you retain one file on the SD card on the new download. If a mib2 high (Columbus unit type) find a retrofitter to alter the navigation FEC. It's a cross we have to bear. Makes you feel like buying a Skoda... Karoq and Ateca come off the same production line but Seat still cobbles it's navigation with Mapcare. On the continent £600 for them to get an extention of Mapcare after the first 3 years that cost then £120. Retrofitter cheaper. Joke. Not sure how the mib3 offer works.
