Everything posted by Tell
Columbus Map Update 2026 (MIB2 HIGH)
Hmmm could be this https://www.briskoda.net/forums/topic/518018-columbus-map-update-2024-mib12-high/page/5/#findComment-5856640 If you have a mib1 they pulled support for map updates. It was a combined release for mib1 & 2 then with the recent releases on, only mib2 is supported. If you get these in a mib1... reading the description above, feels a bit like what you are reporting. You need to revert to an earlier map that supports mib1 if its a mib1 unit. My push down memory pushed it a bit too far down. 😉 You'd think a mib1 high unit would trap a mib2 high only map file being loaded into it. If you are not sure what unit you have mibhelper web site may help. https://mib-helper.com/ You put your software train in and it tells you about your unit.
No but I dont live in Australia. Suggest you look at the Map Creator Here Maps site, register and exam the road(s) in question. They have probably been dropped or there is an open joint. It happens. There is a form of AI that tosses out stuff on inspection then humans check. If it's not spotted and its some desert road (feel like a desert in Australia) a non connecting road at a T junction say that has got split out it would then take the long way round if installed in the car. Think there is a glandulatory thing between their systems as well so things fall foul of that. Once using Map Creator any edits you do you need to come back and check a week later, then a week later to ensure it's stuck and not got separated. Suspect someone hasn't done that so you got an open junction. The bottom row in map creator on the right give you a set of tools to check for consistency to you run along those making sure names are shown, one way streets etc. It also highlights where double tracks are. Open joints you have to visually check. The HereWeGo app gives you an early preview of what has been passed from the developers database (that above) to production so if anything has been fixed and works in that but not released then you know it's been fixed. Some of us, limited few had all the rights to look at the developers database using all the backroom screens. They thought it would increase their productivity but was open to abuse by a limited few so withdrew the developers stuff. Use to be able to call up mobile phone tracks to determine whether roads existed by the passage of the track. Their own workings on road developments etc with were yet open. If you give the x,y coordinates of the start and stop positions I can look at it. Mind you if you are saying that its the whole of Australia that isnt working which you might be, that's a production problem that the Vag supplier has from the Here Maps files not a small cartography error. If you need to go back to a previous version of the Vag map releases you can find that on MartiniBs files but you will need to enable the developers mode on your mib2 high, vcds or Obdeleven and use SWDL screen in the developers mode. You can then load up a previous release. It's the backend tool to the unit. Its a long press of the menu button, one screen opens, keep pressing, second screen then you see swdl. But you will only get this behaviour if the developers mode is enabled. Then with the door open for continuous power start swdl off, do all, play around with the menu buttons. A few reboots during the update, 40 minutes later you should see OK etc across the attributes.... that's if you are up to fixing it yourself with a previous release else you will need a retrofitter or wait till Vag sort it out that's if 433 is completely screwed. PS re-reading feel like 433 is completely screwed unless its the FeCs but if it's a regular unit un touched by a retrofitter then it should work. The navigation FeCs come into it if they are not "life long" FeCs that does cause navigation to shut down. If it's a European import from a retrofitter or you have updated the firmware but that has given you European navigation FeCs, then you need to alter the FeCs to RoW. It came up once with an Australian poster where I got them to alter the FeCs and it started working. They had used the all in one firmware update which landed you with European FeCs. The mib2 high tool kit, there are two, allows you to alter the FeCs, I think I got them to do that to correct it. This one allows you to alter the FeCs https://github.com/Mr-MIBonk/M.I.B._More-Incredible-Bash Documentation in there of the FeCs. Then if yiu have used an AIO firmware update you can probably edit the FeCs in that using the documentation or run the Mr Bonk stuff. If its this somewhere on this site is my conversation with the Ozzie guy who had this issue. You will find it on a search... OK. Went in on the swdl screen. https://www.briskoda.net/forums/topic/518018-columbus-map-update-2024-mib12-high/page/3/#findComment-5829735 Its a conversation with @breaddownunder if you follow that through. May be your issue ?. Saying that if it once worked with RoW maps but has stopped with the update and it's a factory unit not fiddled with then it will be a faulty update if the whole of Australia doesn't work. Ok been round the houses as we say.
Amundsen Mib2 Map Updates 2026
Seems fine, I loaded up both the all Europe and the A2 version. Did the demo drive that the unit can do. Seemed OK. The files have increased in size since the July version posted on the top of the thread. Did a quick check to make sure it wasn't the same file but relabelled. It's still TomTom cartography so no change in TMC not working on the updates. On the positive side, those 20 mph speed limits are in the system. They have a "windows.net" in them as an example: https:/updateportalmaps.blob.core.windows.net/maps/STD2_2610_EU1_2026.zip Well I've used @MartiniB proforma of names and edited in what we'd expect.... happy days and all that wait for the official MartiniB links. They might not all pick up the files: # ECE AS(A1) 2026/27 VW portal: - - Škoda portal: https:/updateportalmaps.blob.core.windows.net/maps/STD2_2610_EU_AS_2026.zip # ECE 1 2026/27 VW portal: - - Škoda portal: https:/updateportalmaps.blob.core.windows.net/maps/STD2_2610_EU1_2026.zip # ECE 2 2026/27 VW portal: - - Škoda portal: https:/updateportalmaps.blob.core.windows.net/maps/STD2_2610_EU2_2026.zip # ECE 3 2026/27 VW portal: - - Škoda portal: https:/updateportalmaps.blob.core.windows.net/maps/STD2_2610_EU3_2026.zip # ECE 4 2026/27 VW portal: - - Škoda portal: https:/updateportalmaps.blob.core.windows.net/maps/STD2_2610_EU_DL1_2026.zip # ECE 5 2026/27 VW portal: - - Škoda portal: https:/updateportalmaps.blob.core.windows.net/maps/STD2_2610_EU_DL2_2026.zip # ECE 6 2026/27 VW portal: - - Škoda portal: https:/updateportalmaps.blob.core.windows.net/maps/STD2_2610_EU_DL3_2026.zip # ECE 7 2026/27 VW portal: - - Škoda portal: https:/updateportalmaps.blob.core.windows.net/maps/STD2_2610_EU_DL4_2026.zip Over to MartiniB.
- 30 replies
- 2
- amundsden
- discover media
- maps
- mib2
Tagged with:
Coded as 2610 on the download release which would be newer than the one @MartiniB has posted up and what I downloaded from that. I'll be told if I'm wrong 😉. The other one was ECE 26 this one is ECE 26 / 27. Will let MartiniB post up the file links but this is different to the one posted up in the summer. Will download the one that better pertains to the UK and test tomorrow. Downloading the all Europe one at the moment. Looks like they updated their library 🫡. Still life in the updates.
- 30 replies
- 2
- amundsden
- discover media
- maps
- mib2
Tagged with:
Mib3 Map Updates 2025.02-06
& on that we have had the November release so we are all uptodate as per @MartiniB 's links. One click back. Mib2 standard appeared early. Mib2 high about in the right window. Nothing new until the June releases before June fingers crossed on that one. https://www.briskoda.net/forums/forum/7-audio-electronics-and-security/
I thought it was all free for Skodas ?. Mapcare is a purchased thing for Seat and Audi. Its governed by the navigation FeC. Unlimited FeC is what you wanted if you haven't got it. The the mib2 high experts found that the brand navigation FeCs are interchangeable I'm blessed with the Skoda and Seat one. Mib Tools high on Github does the trick. You have to pick the right one. The Mr Bonk one. Even if you have the unlimited FeC for a different brand the update works since the update is multi brand. It was the occasion once that the Seat one got dropped on once release so helpful souls took me through the process with Mib Tools. The code for my firmware hadn't been written, so they wrote it. Software patch. The other way is you deploy an All in One (AIO) firmware update. That replaces the firmware and enables all the FeCs you might ever want. Another hobbyist solution. That is the one that Audi folk visiting here for map updates have in the main. Ditto Seat mib2 highs. That brings us on to when the maps wont be produced. The Audi TT went on using Mib2 high beyond 2020 according to @pcbbc which means updates should continue for a bit. Just a question of laying your hands on it. Never say never. Mib1 standard got a 2023 release sold by Audi so if there is a need for it, it will be produced. That version is available in the wild. We might have to buddy up with our Audi friends if they arent on lesser mortal sites 🧡. Those Audi folk with AIO firmware will be looking. Audi owners still pay so the signs of non production will appear there.
Latest Satnav maps
Yes Audi released a not so free mib1 update out of sequence to the free ones. A market must have existed. Mibsolution.one the board that comes and goes had the map on it. Seat folk on mib1 found they could use it using a workaround. I mentioned it on Briskoda and there was success with it. You will find that on a Briskoda thread where success was found. The Audi part code was 8V0060866S. Not sure whether there has been anymore releases. That was 2023 map file. Some three years after the last Vag release. Googling the partnumber you find it's still for sale. This is the SeatCupra navigation resource where you find links to users experience on Seat Mib1s https://www.seatcupra.net/forums/resources/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.60/ If you take the link and taxi back to the rest of the text. It seemed that Seat mib1 firmware needed to be updated to the last release of mib1 for it to work. Release 480. The Skoda mib1 being discussed on the thread where it was tested had a similar release code 490 which is probably why it worked on Skoda. The Skoda success was here with the 2023 maps and firmware update https://www.briskoda.net/forums/topic/511425-amundsen-mib1-maps-update/page/2/#findComment-5904252 Back to the SeatCupra resource I linked above if your read between "DIY activities on the Mib1 standard unit was more..." to Mib3 covers the aspects on Seat's. Read above and round that Briskoda link you'll find more details. Its all there. So yes you can update the mib1 maps beyond 2020 to atleast 2023.
Afraid TMC is disappearing into the mists of time as far the mib2 standard. There won't always be mib2 standard map updates and a mute point as to when they may finish. You can have them with old maps when Here Maps was doing the cartography and the software surgery that @pcbbc showed. Mib2 high maps uptodate with the simple TMC group change to Inrix again as @pcbbc provided and they work dandy. On mib2 standard (Amundsen) using the old maps from several years ago you get caught out by road changes and those new 20mph speed limits. In the end as far as this household was concerned decided it was better to know the indicated road speed digitised onto the map, than old road speeds, with older map but with TMC. Least the driver said that (living in the land of 20mph in built up areas - which people liberally disobey). Keep the SD in the car just in case there is a change of mind so we have both alternatives. My car with mib2 high no issues with the VCDS code change (all on the threads here). New roads, new speeds and Inrix TMC in a Vag car 👍.
- 30 replies
- amundsden
- discover media
- maps
- mib2
Tagged with:
- Mib3 Map Updates 2025.02-06
The screen shows you are on 25.8. You are trying to update to 25.6 so obviously it will not update because 25.6 is not an update it's two months behind. The car comes with over the air updates which are free for a contracted period then you pay to have connected services extended, obviously you have an update. A basic test you do is to read that information screen of YY.MM and you only do the manual update which is what this is, if the manual update betters what you have and you have chosen to save money by not paying for connected services. Hence the manual update. Connect services are not available in all countries and in that case you use the manual update. Your dealer should be able to tell you when connect services for the car runs out or it's in the paper work. Personally I would always pay for connected services. Merry Xmas and Happy New Year.
Why 7zip is preferred as that during the unzipping process other programs can slip in that off character that destroys the integrity check. It has to unpack exactly the same way as it was zipped. Notice MartiniB lists of two different European files in the above. The fix that helps some people is here: https://www.briskoda.net/forums/topic/532756-mib3-map-updates-202502-06/page/3/#findComment-5970567 However, this might not be your issue. Presentation of the files exactly as expected is the key and you don't get any help from the unit if it doesn't read them. Unlike Mib2 standard, you can't pick and choose the internal files and mess about with the download. It just won't take it. The files are signed as a package, and that package is what it's expecting as it does that audit.
You do also get other issues if its not that. Some zipped files un pack at the wrong level so that pdf shows how it should be. Failing that you do get other issues which @MartiniB be has mentioned in the past. Basically the unit gets stuffed so you update the map with a previous history one then it takes the update. Weird. I dont have mib3.
If you look at the attachment on post 1 of here I attached all of the Vag pdfs on how to do it https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib3-satnav-offline.472408/#post-5030964 Vag sites loose some of the information as they reorganise the site. The Skoda map update pdf for mib3 is there. In the thread I reproduce MartiniBs map file links. Nudging it to start is covered but it will just pick it up once you push ignition then the process starts off. Similar to mib2 high map update it has a restart point if you turn off the ignition before its completed. So all of those on and offs sum to 40 minutes or so but get extended by the overlap time of the update. The fly in the ointment as mib2 high is that the unit will do a signature check on the integrity of the files on the USB before it will actually kick off the update. It wont say you have failed the integrity check, just wont do the update. The integrity check is failed if you dont present all files as required as per the pdf. No being clever. No edits. No nothing. No Macs. If you do use a Mac use CleanMydrive to remove Mac garbage from the file once the files are in the drive. Macs put some funny carriage, return line feed combination on to the files. The integrity check will look at the signature on the file do it's own thing and say these have been messed with, but won't tell you that. So file presentation is crucial and has to be exact. Some old 7zip programs can give an issue so updating 7zip is useful. The built in File Explorer of Window 10 / 11 can be used for the unzip. Another source of issues is not using exFat on the USB people have bees in their bonnet and want to use NTFS, dont. Another issue can be the use of usb a to usb c (anyhow the oval one) adapters. Some adapters are not fully wired for data just power. Why the Skoda recommends their Skoda one. Cupra recommends a Cupra badged one. Cheap ebay ones may not be fully wired. If you do need to use a USB a connection, get a reversible pen drive that has both on it or read the advert and make sure it says fully wired.
They are twice a year on the official release as per your weeks. November and June but the files are produced before that then if you are lucky the brands website will show them. Vag and their map production suppliers Here Maps (mib1, mib2 high, mib3) and Tom Tom (mib2 standard) now have their map production streamlined. They have to have it streamlined for the monthly mib3 connected services update. Thus I believe why we saw the November releases months ago way before November. They sat in the fileservers but not wrapped in a web page. It's just how it is now except at some stage mib2 might not be supported but we'll see.
- 30 replies
- 2
- amundsden
- discover media
- maps
- mib2
Tagged with:
Yes the next release will be June 2026. MartiniB has everything uptodate on all his map links. The individual brand websites may not. It's always been like that. The map files are common and universal across the brands, but the brand website may not reflect the available files since nobody has updated the website. It's like library books of old where they have a new book in, its out the back but they haven't put the stamp page on it or the protective cover but you can still read it.
- 30 replies
- amundsden
- discover media
- maps
- mib2
Tagged with:
I'd stick to MartiniBs links. Been using the EU1 one for some time. No issues. Nothing missing.
- 30 replies
- amundsden
- discover media
- maps
- mib2
Tagged with:
I've done a SeatCupra resource on this with links to the software and the radar databases https://www.seatcupra.net/forums/resources/uploading-speed-camera-safety-camera-user-pois.12/ That link provides the details and is linked by the person who wrote the program. It's covers the VAG group MIB2s or less. Some people don't do it like this and obtain knock off databases pre imported to the VAG export file structure. The problem with this is you don't know the source and timeliness of the radar data. The PocketGPSWorld ones you do. Elsewhere on this board people will be using the knock off ones or paid a European company for the VAG file. Pocket GPS world ones: https://www.pocketgpsworld.com/subscription.php On your last one we are talking Mib2 here. If it's not mib3 it's not this. Skoda took out their links to the POI import, as did VW on their website. Seat never had it. You had to use the VW in German web based solution otherwise. Then that was pulled, I moved to Poinspector for the job to do the work of taking published POI files (industry standard GPS file structure) and getting them into the unit. As said there is an Excel macro driven one but Poinspector is more finished. It does handle Mib1 and RNS whatever before that.
- 30 replies
- amundsden
- discover media
- maps
- mib2
Tagged with:
On the first, no. Mib2 allows you to identify POIs in the Vag import format for the system. It does have a feature to warble to support radar camera location but you either buy these pre prepared or do your own importing radar POI files via software to create your own POI import file. Poinspector is one such program I use. You can find it on a Google. Bit like hard work setting up the proforma but once done its easy enough to update. There are other programs. People have an Excel macro driven one. Poinspector being a proper app allows you to zoom into the POIs showing the map position of the POI. You can enter your own POIs and an old Skoda trick I was told which I use is to import my own POIs then save as destinations once shown on the map. Doing that you end up with your own destination library and a blob on the units map. It makes the unit look like a normal traditional satnav. Thus holiday stops etc you routinely use you just mark up or can search for them. Obviously it does take some work but once done you have it. The likes of Google map POIs are hit and miss. Finding car park location with street view, getting the location then importing it to the unit gets the precise place. Car parks for hikes wont be on Google maps. Back to radar pois there are fixed and mobile ones. You can get the location of these but the mobile ones by definition move. Really you need traffic sign recognition (TSR) then the need for radar databases is minor. Only if you want to break the law between cameras. TSR is the way to go. Pass on voice. Mib2 high I believe can do it but I never use it. You press the button and say something. Hit and miss voice recognition isnt something you want in cars. I did try out Seat early mib2 high software app ahead of mib3. I wasnt impressed. That gave you Alexa. They then withdrew the app from the Google playstore. These were Vags early experiments in marrying the two up.
- 30 replies
- amundsden
- discover media
- maps
- mib2
Tagged with:
Unlike mib2 there is no hacking of the unit. Odd files have been found which when run compromise the unit. Yours might be one of them. Given there is zero possibly of unpicking these system if you do a firmware update thats fallen out off the backend of lorry you can get stuck. A previous owner might have done their own firmware update. Vag are trying to clamp down on DIY firmware updates. Yes you might find someone that can get you out of it. But you have no need to look at the meta file and then saving them again you will be compromised by the signature check. This is why vag clamped down on DIY firmware updates. Map updates you can do and are supported but as said not on the very first firmware releases of mib3 in all cases.
And you have to accept that the software can track you else you won't be othered firmware updates / be able to install them. Where people in the past went "dark" and then never got any updated. Failing all this and anybody else's advice you might have to take out a connect services license and dealer assistance to get things going.
Well its either presentation issues of the file, format or that firmware bug that was on mib3s. Are you in an area with connect services. Even if you dont pay the license you do get periodic firmware updates but must be logged in as primary use and accepted all terms. You might then get a firmware update other than that you might need a dealer.
