Tell
Everything posted by Tell
  1. The TMC coding solution only works for Mib high/Columbus. Amundsen thread so not applicable irrespective of the country. How I picked it up.
  2. Answer yes. Mib3 has zonal updates in it. So it is more zoned than mib2. Hence why they have just issued specific zones to RoW. It's based on connected services where the files are zoned so if you did have connected services it updates the map required for the destination. Thus in Europe with connected services you can strike a route between East and West Europe and it will trigger an over the air update. The modular construction of the files. Off line for RoW they just give you your piece.... clear as mud. Offline in Europe you get the whole European file. They didn't bother issuing Europe in fragments.
  3. I see you have been following the threads... no. Its a UK issue with the provider that Vag uses pulling out of the business. It also happened in France. Probably elsewhere in Europe. Where there are more than one provider you can knock it onto another provider but only if the core map file is set up for it. Here Maps you did the TMC group change but once it changed to TomTom cartography for the mib2 standard you needed to wash it through the mib2 standard toolkit. Ozzie mastered this with the mib2 standard tool kit. Im terrible with names... the Briskoda rather sound person... you know who you are... did the same but you needed to hack the maps with the toolkit. Next came the Audi programer and twiddle he recoded the nds modules so you just over wrote those in the map files. Its all on a Briskoda thread but certain amount of chatter about getting Vag to do it. Well Vag won't they dropped it of. They would probably need to pay the other provider. Its self help. I always thought it would be. For the Columbus which is a mib2 high then the solution is the TMC coding change and that just works with map updates. For the Amundsen which is a mib2 standard then it's old maps and the nds file fix. Old maps aren't really that satisfactory where a movement to lower motoring speeds has come into the UK. Without TSR you got the wrong road speed shown. Will edit in some links. Briskoda thread where the solution was posted: Then I reproduced this attributed here on the SeatCupra board... doesn't contain the chat, only the solution. Mib2 standard: https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.388586/page-136#post-5037297 Mib2 high: https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.388586/page-136#post-5035425
  4. Or just buy a 32gb Vag card of Ebay. Any Vag card, VW, Skoda or Seat from a reliable seller. The original older 32gb you might find cheaper. Saves the hassle.
  5. Technically it hasn't been released but found on servers before the web page has been released. It's the normal thing. It seems that the generation of these files has become a fine art. These are still TomTom cartography.
  6. The other one on the logos which Chillout liked (the guru of mib2 hacks) was this https://www.seatcupra.net/forums/threads/station-logo-downloader.465980/ The poster had written a script to scrape all of the media.info logos. The script probably now needs changing to reflect any web page changes. This was in the days of mib2 only. The media.info ones will be more complete than the Phonostar ones. Really for mib2 people. I just do the odd one by hand on the in fill basis. This logo extraction is for that. Mib2 files in the Phonostar database may be useful for your purpose. I dont profess to know Audi systems. Gone a bit off topic.
  7. First paragraph yes. They put dummy code in first, then the real code. The dummy code was to fake a poi import. The hashes intricately have the size of file in them so I reckon you might be snookered. Need that password... best of luck. Anything mib3 more thought went in to stop tinkering. The logos in the phonostar mib2 files are open as recall.
  8. Two things go on here is the password on the SQL database the second one is an SHA lock to stop the files being tampered with. https://en.m.wikipedia.org/wiki/SHA-1 SHA-1 was the one used in mib2. That one can't be home defeated unless you got security service hardware by brute force methods. Vag upped the anti by improving that further with longer keys. Those you see in the mib3 firmware. Currently in bed but i'd be very surprised that the SHA key lock isnt in the radio files as well. Vag got tired of hobbyists hacking the software. Mib2 firmware was only re-written by hobbyist enthusiasts because of a mistake in the turnstile of how POIs were imported in mib2. It was found that whilst the POI part was sealed with SHA-1 against change anything after it slipped in without checking. Only the hashes had to sum. Like someone sliding in behind you on an automated ticket barrier. The mib enthusiast group(s) then wrote all of the mods on that basis. All in one firmware (AOL). You can check whether your firmware is original in mib2 by inspecting for the signature lines at the end. No signature it's modded. Vag closed off this weakness by taking it away. Some people believe this is why poi import isnt allowed in mib3 although it appeared in the first manuals. Phonostar have the manufacturer keys to generate the import. The mib2 public key is the same whether firmware or maps. There is a method where you can hand run the software check in SHA-1 which mimics how it's done in the device. Degree level pure mathematics. Branch of cyptology that was developed within "pure" maths... it stopped it being pure then 😉. I've run that check and found the mib2 firmware is all manufactured with the same private key which will be closely guarded (due to the public key being the same). At that point after understanding how the files were locked up I gave up trying to twiddle with them. Then subsequent to that the turnstile weakness was found in mib2. The toolboxes of putting the green menu in the car all use the same turnstile hack. It sporned the AOL firmware and the in car tool boxes in mib2. So anyhow if you see banks of signature lines in the files that's what they are. A difference in those to the hash row which can be recomputed. Signature rows can't be.
  9. Wonder if you were a registered VW customer whether you'd see the map update or whether they have done their trick of discontinuing a service early 🤔. They have a reputation of that.
  10. You won't be changing mib3 files. Locked down. Mib2 logo files are available and can be imported
  11. If the VW site was still up you would check which VW map files were common between models of mib3. Screen size I believe is a variable. @MartiniB may be able to help. You certainly see some different files published but so far it hasn't been any issue on Skoda and Seat's to my knowledge. That generation hasn't appeared yet.
  12. It should do if that is the correct file for it and the USB is OK and the files are prepared correctly and no MAC was involved without CleanMyDrive... It can take a number of hours if you start and stop... probably presentation. Have you found the VW PDF ?. I put all three PDFs on post 1 here. Check against. All the same technical instructions on presentation. https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib3-satnav-offline.472408/#post-5030964
  13. No it won't brick it. There is validation in the car to stop rogue files being uploaded. It either works or it doesn't. When it doesn't work it's down to incorrect file preparation by not following the PDFs. It's like mib2 high. It's all about presenting the files correctly. A USB C with a built in flashing LED is liked since you see the activity taking place. Im told you get to see 25.6 whilst the LED still flashes. With a LED USB you leave it in till it stops flashing. Reckon it's finishing off the rest of Europe when it's still flashing... something that came to light recently. Don't use a USB A to C adaptor since some of these dont have all the pins connected. Some work, some dont. Issues on the SeatCupra side where firmware updates were found not to work due to this. The seller said common. Yes plugs into those sockets.
  14. I keep on the monthly Window 11 updates and the pre releases so didn't moan for me. May be more forgiving than 7zip. I'd done the test looking for 25.06 which I'd found without issue. In the past thou on genuine 7zip files, Windows built in had messed up the mib3 by not seeing a file... that one with the date in. Think Microsoft have that corrected now.
  15. We are at 410. See top post. That's old stuff. Pass on the question. If you can't upload it to the car, you know about Audi navigation FeCs ?. You need life long FeCs on Audi and Seat cars if it a compatible map. Audi posters here have their navigation FeCs adjusted. Audi boards for that.
  16. Yes Ive been saying update 7zip to people. Unzipping fine for me but that was in the built Windows 11 file manager unzip. On the mib3 ones where there had been a moan or two on the SeatCupra board but I'd had no issue looking at them. It was found that they loaded up fine even with the issue. Normally you dont touch them if they unzip with errors. Going to be Skoda tools they use to zip them. Recommendation update your 7zip or try with the inbuilt file explorer Microsoft tool in Windows 11. Might be in 10. They had updated that tool to work with more diverse files.
  17. Try a different browser. This was Firefox. Some people use custom downloaders that may regulate / buffer the download or not.
  18. No problems here with that link in Windows 24h2. I suspect you have a system issue. Have 900Mbs link but other than that pretty normal and 24h2. Then springs open in the build in file manager unzip. Seat folk have been busy installing it on their mib3s without issue.
  19. By following in the pdf. I attached all of the Vag ones on this SeatCupra post. See attachment on the first post. The Skoda one is there. It's all the same. 64gb usb. Some people like the usbs that flicker so they know something is happening. Poke it in and wait after correctly unzipping it. Although I've given a few tips. There is no update button. It just senses the usb there with a map update on it. VAG uses restart points so if it doesn't complete it will restart next time you use the car. There have been some issues unzipping the European file but surprisingly you can ignore them. A recent copy of 7zip should be used or the internal Windows unzip. I haven't spotted this issue myself. Others have but as said it does update to 25.06. https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib3-satnav-offline.472408/
  20. The delete and re save came up on SeatCupra board. That fixed it for the individual. I think this was where the virtual cockpit display didn't reflect what was on the mib3 unit. They were told to do it and it worked. Basically the logos are in a general mess how Vag have done it not allowing users to correct it as mib2 so its always going to be like that. Only as good as the official database maintained by Phonostar if that's not correct or missing logos then it can't be user corrected.
  21. The other thing that has come to light on the Seat side is the update over WiFi for people out of connect services contract. This occurred after an out of contract person got a firmware update over wifi. After that came a radio logo update. They connected the car to a phone's hot spot and waited. If the car is identified as being a candidate for an update, it can get it that way. Must be handshaking. Fishing for updates. Not too sure how common that knowledge is. They said they had been looking over a number of days leaving it wifi connected. Don't think you'd get map updates that way.
  22. @MartinB OK using that method to look at the files it's actually 2025.06. So it should come up as that once loaded if loaded fine.
  23. If you pay for connect services you will get the update ahead of those that don't pay. Like monthly. Whilst the free ones run later on a six month release cycle. June, November. You pay your money and take the choice. Don't pay and they are a few month older than the paid ones. Anyhow @MartiniB a Seat poster now says that the European one is now available online (free) https://infotainment-cdn.skoda-auto.com/base/maps/OI_P153_EU_202525_Offline-Update.zip The 202525 is inline with your other post for 2025.02 so assuming it unzips fine and no mistakes by Vag should be fine. I'll inspect for 2025.02 in the file later. Leave you to test since I don't have mib3.
